Moderately priced HTPC build. Help, please. - AVS Forum
post #1 of 10 Old 04-15-2014, 11:14 AM - Thread Starter
testudoaubreii's Avatar
Hello everyone,
Have been going back and forth when trying to find the "perfect" HTPC build. I have tried out a Mac Mini (i5 2.5 Ghz 4 GB), but I am not getting any audio to come out of the HDMI to the TV. I went into System Preferences, but I cannot figure it out. The only remote that I can find that works on a Mac that is relatively inexpensive is the Apple remote. It does work for XBMC, but I have no volume control. I also would like to have a wireless game pad that I can use for an NES emulator. I think that it may be easier to just build a Windows machine.
I would like to build my own, preferably an Intel. However, I am open to AMD if that may give me a better price to video quality ratio. I will be using it for XBMC and streaming 1080p files over our network to the other Smart TVs in the house. I may also use it for light audio work and very light gaming (NES emulator lol).
I am looking for a moderately priced set up. I would like to stay around the $400 mark, if not below it. I would like to have a smaller case and the ability to use a remote control for XBMC.
I think that might cover it. Please, let me know if there is any more information that you need to help me out.
Thank you in advance for all help, advice and suggestions.
Testudo
testudoaubreii is offline
post #2 of 10 Old 04-15-2014, 12:09 PM
halfelite's Avatar
Quoted: 21 Post(s)
Liked: 59
you will not beat the intel NUC for the price.
halfelite is offline
post #3 of 10 Old 04-15-2014, 12:11 PM - Thread Starter
Would I not have to buy the storage and PSU with that? I already have an SSD that I can use in the one I build.
Thanks for the response!
post #4 of 10 Old 04-15-2014, 12:14 PM
halfelite's Avatar
Quoted: 21 Post(s)
Liked: 59
power supply comes with the unit. you will have to get storage and ram. But still the best smallest box you can get to run xbmc. even include IR eye on some models for a universal remote
post #5 of 10 Old 04-15-2014, 12:19 PM - Thread Starter
Thanks again.
How much would that cost after factoring in storage and RAM?
post #6 of 10 Old 04-15-2014, 12:27 PM
Kelson's Avatar
Quoted: 190 Post(s)
Liked: 336
I tried to compare NUC with putting together a Shuttle XH61V. There are a confusing number of NUC models. Some come with processors and some without. Is there a good link that makes sense of it all?
- kelson h
The bitterness of poor quality lasts long after the sweetness of the low price is forgotten . . . life is too short to drink bad wine
Kelson is offline
post #7 of 10 Old 04-15-2014, 12:47 PM
halfelite's Avatar
Quoted: 21 Post(s)
Liked: 59
yes the xbmc nuc wiki actually breaks each model out http://wiki.xbmc.org/index.php?title=Intel_NUC
for me I would go with something like the
make sure you get one based on 3rd gen or newers as they are the only ones that handle 23.976 without dropping fps but something like the
D34010WYKH or the D54250WYK if you want over kill
post #8 of 10 Old 04-15-2014, 12:49 PM
halfelite's Avatar
Quoted: 21 Post(s)
Liked: 59
Originally Posted by testudoaubreii View Post
Thanks again.
storage and ram depends. you can run openelec off a usb stick so storage can cost you 10$ ram depends if you want 4 gb up to 16gb. but 4gb is cheap as well. running xbmc off a usb does make for some slow artwork but even then a msata 30gb drive is 40$
post #9 of 10 Old 04-15-2014, 12:59 PM
Kelson's Avatar
Quoted: 190 Post(s)
Liked: 336
Thanks. That's exactly what I was looking for.
OK, so the 34010 looks to be to my liking.
What's the deal with the power cord.
Some people say it comes with and others say without.
Amazon shows a $26 difference for a NUC with a power cord?
- kelson h
Kelson is offline
post #10 of 10 Old 04-15-2014, 01:37 PM
halfelite's Avatar
Quoted: 21 Post(s)
Liked: 59
the US shipments get power cords the out of country usually does not but its hit and miss. you might already own one. you get the power brick but you need this
http://www.amazon.com/C2G-Cables-Go-3-Slot-Notebook/dp/B0000AOWXO/ref=pd_sim_pc_2?ie=UTF8&refRID=0ZEZ9ZHTY7A9CNVW40RA
if it does not come with it or you dont own one. its just a IEC320C5 cable you can find them from 1$ to 15$
User Tag List
