5ghz band dropping - AVS Forum | Home Theater Discussions And Reviews
post #1 of 11 Old 05-01-2014, 11:30 AM - Thread Starter
gilroy222's Avatar
Hello,
My Asus rtn53 keeps dropping the 5ghz band, even though the LCD still indicates its on. I am running the latest firmware. I want to avoid returning it at all costs since it is perfect for my price range. However, this seems to be a very common problem with this router.
Does anyone have an suggestions?
gilroy222 is offline
post #2 of 11 Old 05-01-2014, 01:31 PM
UHD Addict
aaronwt's Avatar
Quoted: 5203 Post(s)
Liked: 3113
Have you tried using different channels to see if that might possibly be the problem?
I use a couple of the RT-N56U routers and an RT-N65U router. But I have not run into any issues with the wireless dropping. I also use the Padvan custom firmware which is much better than teh stock Asus firmware. Maybe there is a custom firmware for your model that might help?
53TB unRAID2--41TB unRAID3--35TB unRAID1a
Sony 65x850C--Samsung UBD-K8500--Sony HT-NT3
XBL/PSN: WormholeXtreme
aaronwt is offline
post #3 of 11 Old 05-01-2014, 05:08 PM - Thread Starter
gilroy222's Avatar
I haven't no. It is currently on Auto I believe. Shouldn't the router automatically pick the best one? Or what channel range should I try? I live in an apartment building.
post #4 of 11 Old 05-01-2014, 08:16 PM
UHD Addict
aaronwt's Avatar
Liked: 3113
Then it's even more important you make sure you are using a channel that is uncongested. Use the program WiFi Analyzer on your cellphone or tablet and it will show you all the WiFi Networks and what channels they are using. I wouldn't expect 5Ghz to be crowded but you never know. And if you have a Roku3 using 5Ghz, the WiFi Direct remote will use the same channel and can sometimes cause issues.
aaronwt is offline
post #5 of 11 Old 05-03-2014, 09:20 PM
72.9.159.100's Avatar
Please use the wifi scanning apps mentioned and post here with your results. Thanks.
72.9.159.100 is offline
post #6 of 11 Old 05-12-2014, 04:50 PM - Thread Starter
gilroy222's Avatar
Hello,
Sorry for the delay. So I performed a factory reset and everything seemed fine for a week. Then again, it dropped 5GHz. I used the wifi analyzer and found that the router was automatically setting it to channel 161 I think, which is the farthest channel it could and there was no interference even close to that channel.
I have tried experimenting with N only mode, 40mhz, and different channels with no success.
The only thing that brings it back is turning the router on and off
post #7 of 11 Old 07-09-2014, 08:46 AM - Thread Starter
gilroy222's Avatar
To anyone seeing this....
I solved the issue by changing the MHZ from "20/40" to "20" only. In the Routers settings if you highlight the MHZ setting, it explains to drop it down to 20MHZ if you experience instability.
post #8 of 11 Old 07-09-2014, 12:25 PM
FX4
FX4's Avatar
Quoted: 138 Post(s)
Liked: 45
Are you certain the 5GHz band is dropping and it's just not something around or near your home causing an interference problem? I know I can't use it around my house. 2.4GHz works fine but 5GHz is pretty much unusable. I suspect it's because I have a power substation about half mile from my house.
FX4 is offline
post #9 of 11 Old 07-09-2014, 01:34 PM - Thread Starter
gilroy222's Avatar
Ya I'm positive. It was happening for about a month. So often in fact, that I could set my clocks to the time of day it dropped lol.
Once I changed it to 20MHZ, I haven't had a single drop. I changed it 5 weeks ago...I just never remembered to come close the post.
post #10 of 11 Old 07-09-2014, 06:05 PM
UHD Addict
aaronwt's Avatar
Liked: 3113
I run all my APs at 40Mhz. There is a huge throughput difference if I only use 20Mhz.
aaronwt is offline
post #11 of 11 Old 07-10-2014, 11:50 AM - Thread Starter
gilroy222's Avatar
Ya I have my 2.5 Ghz band running at 40MHz but with my 5 I had no choice. It still performs considerably better than the 2.5 though. So sacrificing a bit of speed for stability is ok for me at this point.
