First post.... newbie.....streaming help - AVS Forum | Home Theater Discussions And Reviews
post #1 of 20 Old 05-04-2014, 09:16 AM - Thread Starter
gotgrowth's Avatar
OK guys I'm brand new to this .I have never gotten into home theater but I am getting a new apartment and am broke as a joke..... I was told about Chromecast and such things as my new apt will come with WiFi ... From my landlord who lives upstairs.... But no cable...
If I could get away with not buying cable I would love it so I started looking into htpcs. But I don't even know where to start...
Will the signal from upstairs be strong enough for me to use to watch movies and shows, will there be a ton of lag? what equipment would I need?
I wouldn't be opposed to building it myself at all I just want to learn more and cover all the bases before I start. ...
If anyone would help I'd appreciate it a lot
Sent from my SGH-M919 using Tapatalk
gotgrowth is offline
post #2 of 20 Old 05-04-2014, 09:16 AM - Thread Starter
gotgrowth's Avatar
BTW I will be doing no gaming at all and if I did build a htpc it would for be movies shows music and browsing if possible
post #3 of 20 Old 05-04-2014, 12:10 PM - Thread Starter
gotgrowth's Avatar
Anyone
post #4 of 20 Old 05-04-2014, 07:37 PM
kevin g.'s Avatar
Quoted: 329 Post(s)
Liked: 138
Hey gotgrowth...
Streaming via WiFi isn't ideal...but can be done. Your downfall here, will be the fact that he is providing your sole internet connection. There is no telling what else is goin on over his network.
He will control your bandwidth, and possibly your connection times=bad...
Your connection will be subject to whatever he is downloading/streaming/uploading=bad
Also, it is his network, so connecting your stuff to it, will open you, and your sensitive info, to his eyes and ears. There are ways around that, and I'm not saying that this may be the type of person that does this sort of thing...just making you aware.
Good luck. Let us know how it goes.
"Once you learn good English...Can't nobody take it away!"
Xbox LIVE Gamertag: KEVIN G 40
kevin g. is offline
post #5 of 20 Old 05-04-2014, 10:01 PM - Thread Starter
gotgrowth's Avatar
Wow didn't think about that. I know he is pretty computer illeterate and he has one computer connected to the WiFi in his home.... He also has cable so he won't be streaming like I would be..... I will look into getting my own internet ran seperatley but in the mean time can you please help me put together something?
post #6 of 20 Old 05-05-2014, 05:24 PM - Thread Starter
gotgrowth's Avatar
post #7 of 20 Old 05-06-2014, 12:01 AM
Matt L's Avatar
Quoted: 297 Post(s)
Liked: 265
Ideally it would be great if he could provide you with a wired connection, see if that is an option. Depending on the building's setup running a CAT5 cable can be easy or hard. If you go with Netflix or Hulu the faster connection the better, If you use something like Playon based on your computer and feed it to a Roku box you can use the free Hulu. I'm not a fan of Hulu due to the non skippable commercials, but you may not mind them - the price is right.
Matt L is offline
post #8 of 20 Old 05-06-2014, 12:03 AM
cyberyoda0's Avatar
A HTPC would be able to cover all of your streaming needs, but they're complicated and expensive to get started with.  A Chromecast is very easy and cheap, especially with Netflix, Hulu Plus, etc. but streaming local media is a bit tougher.  For that you have to install some media server (such as Plex) on the PC that contains the files you want to stream, download the Plex app on your smartphone ($4.99), and "cast" it to the Chromecast.
If you're looking into building a HTPC, it doesn't need to be top-of-the-line, but it does need some horsepower if you're going to transcode HD.
There are a lot of other options as well, such as the Roku, Amazon Fire TV, smart blu-ray players, etc that can stream and have a decent UI for a lot cheaper.  I'm not sure what your budget is, or exactly what you're wanting to stream, but there are MANY options out there for you.
cyberyoda0 is offline
post #9 of 20 Old 05-06-2014, 08:37 AM - Thread Starter
gotgrowth's Avatar
Thanks cyber.... Im trying to keep monthly fees at or around zero and I currently do not have a computer to run anything off of so I figured going htpc..... To kill two birds with one stone. I might get my own WiFi in my apt so there is no worries but cable is out of the question.. I want to try and get live the for free of possible ...... I could also get a cheaper laptop and Chromecast or something. Butbibdont want junk.... Budget will have to be under 600,or so for everything needed.....
I really could use your help guys
post #10 of 20 Old 05-06-2014, 09:42 AM
Matt L's Avatar
Quoted: 297 Post(s)
Liked: 265
Where do you live? OTA TV is an option in many places. If you opt for a computer for your uses, it does not need to be top of the line, a good basic even used computer will do. You can add a TV tuner card and have a drv - with OTA.
Chromecast is fine but it depends on your cellphone a lot. My favorite media streamer is the WD SMP. Can be had on ebay for $50 or so, can accept a OTA tuner, will work with netflix and hulu and many others and is ready to stream content from your computer if you ever go that route. It also will work with wifi.
It sounds like you want your bill to be very low so I would just stick to the basics and see how things work with the provided wifi. Connect to it with your cell and run a speed test to see what kind of speed you will be getting. 3Meg is about the least that will work with streaming services like netflix. They want 6Meg for HD and more is obviously better. If you stream a lot be aware some, many companies have data caps and your landlord might get a surprise in his bill if your combined usage is over the cap. If you shop for your own internet service be aware that many plans offer low introductory pricing and jump way up after 6 months. Be prepared to play the switching game every year to keep your costs down.
Good luck!
Matt L is offline
post #11 of 20 Old 05-06-2014, 10:29 AM - Thread Starter
gotgrowth's Avatar
I think I rather go with a htpc with a TV tuner..... With ota ..... Any reccomendations on builds and how I would set up ota
post #12 of 20 Old 05-06-2014, 11:05 AM - Thread Starter
gotgrowth's Avatar
New York btw tristate
post #13 of 20 Old 05-06-2014, 11:30 AM
replayrob's Avatar
Quoted: 666 Post(s)
Liked: 626
That covers a pretty large area... how about the zipcode?
“You cannot play God and then wash your hands of the things you created.”
Commander Bill Adama
replayrob is offline
post #14 of 20 Old 05-06-2014, 01:51 PM - Thread Starter
gotgrowth's Avatar
post #15 of 20 Old 05-07-2014, 08:20 PM - Thread Starter
gotgrowth's Avatar
post #16 of 20 Old 05-10-2014, 10:20 AM - Thread Starter
gotgrowth's Avatar
Anyone
post #17 of 20 Old 05-10-2014, 10:27 PM
Matt L's Avatar
Quoted: 297 Post(s)
Liked: 265
If you plug your zip into tvfool.com you will find you have a massive amount of stations available to you.
http://www.tvfool.com/?option=com_wrapper&Itemid=29&q=id%3de1c6d6eb46dc4b
If you input your actual address and info it will give better results, but reception can be tricky in big cities. An outside antenna would serve you best, but if that is not an option you will have to do some research to find one that works in your area. There is a local reception section on this site, you might want to post over there.
Matt L is offline
post #18 of 20 Old 05-11-2014, 05:32 AM - Thread Starter
gotgrowth's Avatar
Thanks Matt I will def look over it ..... Any way you can help me put together a build that would cover all my needs.... Streaming 1080p storing 1080p blue ray reader writer ... Play and store music and web browsing. ?
post #19 of 20 Old 05-11-2014, 08:57 AM
kevin g.'s Avatar
Quoted: 329 Post(s)
Liked: 138
http://www.avsforum.com/t/1302559/assassins-simple-beginner-htpc-buying-guide
http://assassinhtpcblog.com/
kevin g. is offline
post #20 of 20 Old 05-15-2014, 03:14 PM - Thread Starter
gotgrowth's Avatar
http://pcpartpicker.com/p/3KFwG
After overloading my brain I have come up with this. Would you guys chnlange anything?
