Help with AV and network setup in new home (1st post) - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 05-07-2014, 08:45 PM - Thread Starter
aortiz40's Avatar
Hello - My home is currently being built and I am a novice when it comes to AV and home networks, so the information I've read on this forum has been more than helpful. Here is how I envision my home AV and network setup but need some help in what I need to buy to pull it off. There will be 26 Cat6 wires run down to a basement mechanical room from various rooms, along with 24 RG6 coax. The AVR (Denon 2313CI) modem, router, and Directv receiver will all be located in the basement. The family room, which has 3 Cat6 and 2 RG6, will have a 5.1 surround system attached to the Denon in the basement, controlled by RF to IR Universal Remote controller MSC-400. The PS4 will also be in the family room since the blue tooth remotes won't work if it's down in the basement with everything else. Questions:
1) I assume I will need HDBaseT single Cat6/HDMI baluns with 3D support for both the Family Room HDTV and PS4 for this setup to work, correct? I believe this leaves me with one extra Cat6 in the Family Room to either plug into the PS4 for internet or into the TV for internet (both have wireless capability too, not sure which one to plug in to ethernet). Will this setup work? Suggestions for the HDBaseT HDMI/Cat6 baluns?
2) What other networking equipment do I need? Goal is to run gigabit... Do I need a gigabit modem, router, and switch? If a switch, how many ports will I need, does it need PoE, does it need to be managed or unmanaged? I will also need to plug in the Denon, Sonos Connect, and Directv receiver located in the basement into the network as well.
3) Any suggestions for this setup or an alternate setup? Any specific brands or models of equipment that you would suggest?
Thank you in advance for any help, much appreciated!!
aortiz40 is offline
post #2 of 5 Old 05-07-2014, 08:53 PM
Otto Pylot's Avatar
Quoted: 1360 Post(s)
Liked: 853
Are you running your cables thru conduits? To run at gigabit speeds, you'll need a gigabit router and switche(s) if your ISP provides that speed.
Otto Pylot is online now
post #3 of 5 Old 05-07-2014, 11:16 PM - Thread Starter
aortiz40's Avatar
Unfortunately no conduits... Contractually I didn't have input into the how the wiring was put in, just in number of cat6 and RG6 and their locations.
aortiz40 is offline
post #4 of 5 Old 05-08-2014, 12:26 AM
Matt L's Avatar
Quoted: 297 Post(s)
Liked: 265
Your questions are better posted and hopefully answered in the Home AV distribution forum.
http://www.avsforum.com/f/36/home-a-v-distribution
Matt L is offline
post #5 of 5 Old 05-08-2014, 07:02 AM - Thread Starter
aortiz40's Avatar
Thank you, Matt. I moved the post over to the Home AV distribution forum per your recommendation.
aortiz40 is offline
