Roku vs WD Western Digital TV Live - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By gogent
post #1 of 5 Old 06-08-2014, 08:15 AM - Thread Starter
gogent's Avatar
I would like to be able to stream mkv files from my pc via wireless.  I don't do netflix or other streaming services.  Which would you guys recommend.  I'm thinking about the one below.
http://www.ebay.com/itm/WD-Western-Digital-TV-Live-Streaming-Media-Player-WDBHG70000NBK-WDBGXT0000NBK-/261189256869?pt=US_Internet_Media_Streamers&hash=item3cd017c6a5
WhiteSands likes this.
gogent is offline
post #2 of 5 Old 06-08-2014, 09:31 AM
ash_man's Avatar
Quoted: 61 Post(s)
Liked: 31
No matter which solution you go with, doing anything wireless is bound to frustrate you. The very nature of wireless includes latency, something that affects streaming in the form of delays due to buffering, stuttering of the picture or poor picture quality. You might get anywhere from 5 minutes to 45 minutes of uninterrupted streaming, but then it will pop up. If there is anyway you can hard wire, I would suggest doing so over wireless, even with the best wireless routers, its near impossible to escape problems.
BenQ W1080ST
125" Elite Screen
Denon AVR S710W
Paradigm Home Speaker set 5.1 Cinema 100
Harmony 650
Asus Chromebox
ash_man is offline
post #3 of 5 Old 06-09-2014, 04:48 AM
bac522's Avatar
Quoted: 190 Post(s)
Liked: 107
That's bad advice, not all wireless implementations have that problem...I've seen poorly designed Ethernet works have similar symptoms...and wireless does not have inherent latency in it...crappy APs do! I pull 100Mbps easily through my wireless AP with no latency or problems using 802.11n...I don't recall the last time I had a problem watching even my ripped bluray through my wireless networks.
As for the OP's question, I'm not familiar with WD, but I do stream my mp4 files to my Chromecast and Roku wirelessly with no problems, I beleive the WD will be fine, but there are dedicated WD post in this forum you may want to review.
bac522 is offline
post #4 of 5 Old 06-09-2014, 11:49 AM
smitbret's Avatar
Quoted: 325 Post(s)
Liked: 99
Agreed, if there is any way to run a wire, please do so. You will save yourself so much headache.
Are there implementations of wireless that work? Of course, but even when I have been able to set up systems that were able to playback smoothly, it still had problems with response times; FF/Rew are just nasty over wireless at any speed.
smitbret is offline
post #5 of 5 Old 06-09-2014, 11:15 PM
Matt L's Avatar
Quoted: 320 Post(s)
Liked: 290
I own several WD units and several Rokus. For streaming from a computer the WD wins hands down, no comparison. The Roku is not setup to do that and you have to use secondary apps to accomplish what the WD does out of the box. With the WD you give p hundreds of nitch channels but the big ones are there.
As for wireless streaming if the files are relatively small like a DVD quality file it should be fine, anything HD odds are will be quite problematic. Best if wired, second I'd opt for MOCA or Powerline and as a last resort I'd go wireless.
Matt L is offline
