Netgear Nighthawk R8000 Triband AC Router Review and Comments Thread - Page 2 - AVS Forum | Home Theater Discussions And Reviews
 4Likes
post #31 of 70 Old 07-17-2014, 09:08 AM
ligflava's Avatar
Originally Posted by bobsilver View Post
Just heard back from NETGEAR. When the R8000 is an Access Point mode as mine is the light flashes White and Amber as an indicator. NETGEAR also agreed probably not the best indicator and will be updating this behavior in a later firmware.
Are you using your R8000 in AP mode?
Bob
Thanks for the reply and I am. I actually did a hard reset and noticed it was fine in wireless router mode up until the point that I changed it to AP mode. By then I also started a service ticket with Netgear and got the same response you did yesterday.
Netgear has some great hardware, but their firmware definitely leaves something to be desired. I was almost going to pick up the Asus AC68. Still happy with the R8000 though (my wifi range is so much better compared to the R4500 it replaces).
Thank you again.
ligflava is offline
post #32 of 70 Old 07-17-2014, 06:46 PM
lennyr's Avatar
Has anybody connected a USB external drive to their X6, and if so, what model is it? I have tried two drives and it won't recognize either of them.
-l
lennyr is offline
post #33 of 70 Old 07-18-2014, 12:23 PM - Thread Starter
bobsilver's Avatar
Quoted: 108 Post(s)
Liked: 62
I have attached a usb powered drive to my X6. I see the drive in the network area of my net. No issue or anything unusal.
Question is what drives (are they self powered or powered from USB), do you see anything in the USB setup area like the drive showing up at all?
The X6 should work with most any usb drive.
Bob Silver
bobsilver is offline
post #34 of 70 Old 07-24-2014, 09:10 PM
lennyr's Avatar
Bob Silver
I got it to work. The trick was formatting the drive to FAT32 / MBR.
-l
lennyr is offline
post #35 of 70 Old 07-25-2014, 01:52 PM - Thread Starter
bobsilver's Avatar
Quoted: 108 Post(s)
Liked: 62
I received my Nighthawk X6 yesterday. NETGEAR has begun shipping the X6 this past week. The unit shipped with V1.0.1.46_1.0.17 firmware. When booted up there was no notice of additional firmware upgrades. I haven't confirmed with NETGEAR what this firmware has or doesn't have regarding limitations but I will do that this week.
The unit is very sleek. It is larger then the R7000 by about 30%. It is table top or wall mountable. I will wall mount this once I get things situated. I have set it up as an Access Point. This operates as all the latest NETGEAR routers with an easy selection to turn access point on. Then you simply connect it to your network and you are good to go. In access point mode it looks for an ip address from the DHCP server. After the initial reboot I went in and changed it to a manual address so I can easily access it for settings and other maintenance functions.
The first thing you will notice is that the router boots with 3 wifi bands. One 2.4 and two 5ghz bands. You then have the option of turning on Smart Connect in the wireless section which combines the 2 5ghz band into 1 with a common SSID. Very easy and really seamless to do.
All other aspects of the router work as expected.
The hardware is very nice. The unit has a good array of led lights so you can get an idea of what is happening at a glance. My power light is flashing white and amber so not sure what that is about but the router appears to be functioning normally though.
The antennas are interesting. I was in error when I thought they operated on on their own. They require manual intervention to raise and position them. But unlike the R7000 is is clear where the antennas should be placed. They all extend from the case and extend outward about 45 degress from the case. The upper and lower antennas can then be rotated about 45 degrees up and for the top and down for the bottom set.
NETGEAR has said that the range of the R8000 is similar to that of the R7000. Untill I can mount the R8000 in a simalr place I will need to wait to determine that.
But again first blush with the unit all seems very good.
I will report back once I have had a few days to live with the R8000 and report on its 5ghz performance.
Bob Silver
NETGEAR AV Consultant
User Impressions
I have been living with the X6 R8000 for a couple weeks now. I placed it on a printer table about desk height. I have been using the router in Access Point mode. And have set the SSID's to the same as my R7000 so I could switch back and forth between the 2.
My impressions are this so far. Range wise it appears to equal the R7000 in both 2.4 and 5ghz bands. I have a 3k sq ft single story home and it is strong enough for me to roam anywhere within my home and outdoors. I can walk almost 50 feet or more outside and still remain connected.
Antenna placement I have settled on is 90 degree vertical for all 6 antennas. I tried playing with different angles but none seem to make much of a difference. Since the router is exposed visibly the 90 degree position looks best. (actually the router looks pretty cool anyway). The antennas BTW can be angled out and forward and back. Quality wise they are plastic like the rest of the case but feel sturdy enough. I wouldn't lift the unit by the antennas but you shouldn't anyway. And lastly I like that there is little ambiguity about where the antennas should be.
I have been using Netspot on my Macbook Pro to test signal strength and noise rejection. Again compared to my R7000 results are very similar. Switching between the 2 did not result in much of a difference in my case.
The one thing I will say that I have seen is what I believe is an improved response time when using the R8000. When connecting and using the network things just seem snappier. I can't quantify it (and maybe I am imagining it) but things just seem better. Its like some days my network seems to work better then others. Well with the R8000 most times seems to be one of those days. And this could be from the fact that there are 4 cpu's in the R8000. 1 for each of the bands and the dual core for all other router functions.
Load balancing on the 5ghz radios is transparent. The router sets itself up with 1 radio in the 160 channel range and the other radio in the 48 channel range. Since most of all my 5ghz devices are fast devices the router has put them on the 160 channel side. It is my understand that this is only done once when you connect to the net. So I am not certain of the approach NETGEAR used in determining what goes where. I intend to have a follow on discussion with NETGEAR to better understand the R8000 now that I have some real time experience with it.
So my initial reactions are very positive. Is the R8000 worth a 33% price premium over the R7000? Well that really depends on your environment. Id still say if you have a family with multiple users then this is probably the router to buy. Wireless bandwidth goes fast and having the dual 5ghz bands is really valuable when you need it.
Bob Silver
NETGEAR Networking Consultant
post #36 of 70 Old 07-25-2014, 02:22 PM
mlknez's Avatar
Quoted: 215 Post(s)
Liked: 53
Still no QoS there yet
mlknez is offline
post #37 of 70 Old 07-25-2014, 08:26 PM - Thread Starter
bobsilver's Avatar
Quoted: 108 Post(s)
Liked: 62
QOS will be in the October firmware release.
Bob Silver
post #38 of 70 Old 07-25-2014, 08:54 PM
jimbo75's Avatar
Bob Silver
Isn't that always the problem? Firmware is always late and missing features. Everyone should read the reviews on cnet, smallnetbuilder before dropping $300 on this thing.
jimbo75 is offline
post #39 of 70 Old 07-28-2014, 11:34 AM - Thread Starter
bobsilver's Avatar
Quoted: 108 Post(s)
Liked: 62
When you are looking at new technology products like the R8000 software following hardware is the norm. the R8000 uses a new Broadcom chipset and a set of new Broadcom technologies. It is up to the manufacturers to develop the end software that makes these technologies into products.
The R8000 is stable. First and foremost that is key. There have been too many instances where new products come to market and are not stable for many revs. Netgear and others are guilty of this. So when I found that the R8000 hasnt dropped connections, needed a reboot or any other intervention after I set it up I was quite impressed. It has been extremely stable. More so than any other new router product I have used in a long time.
Netgear again decided (wisely IMHO) to focus on stability and add the complex features down the road. This is a far better approach than the alternative.
It really takes about 6 months after a new product hits the shelves to get all the bugs worked out, features implemented and all things stable. Its never a good idea to buy new tech the day it comes out. But Netgear did great on the R8000. If it has what you need today its a solid product that you can rely on. Otherwise you can just sit back and wait for a little while.
Bob Silver
liltalkm likes this.
post #40 of 70 Old 07-29-2014, 08:58 PM
liltalkm's Avatar
Quoted: 202 Post(s)
Liked: 274
Bob Silver
I agree 100%.
My experience with the R8000 has been great also.
(Theater)Speakers: Martin Logan Montis, Stage X, Dual Depth I Subs, Vanquish in ceiling (surrounds) | Processor: Marantz AV8802(A) | Amp: Three Moon Simaudio 400m monoblocks,One Moon Simaudio 330a, PS Audio Directstream | Sources: DirecTV HR54, HTPC, Mac Mini, Oppo UDP-203, PS4 Pro, Xbox One S | Television: LG 77G6P | Remote: Logitech Harmony Elite
(Bedroom)ORB Audio Mod 2 5.1, Yamaha RX-A2050, LG 55E6P, Samsung K8500, Harmony Elite.
liltalkm is offline
post #41 of 70 Old 08-06-2014, 11:33 AM
Dakinbear's Avatar
Does the r8000 extend beyond the r6300
Hi Bob -
I have the r6300 and I still need two wi-fi extenders at either end of my house to get complete coverage.
Is there any way to assess whether the distance of the r8000 is greater than the r6300?
I don't think I need much to get rid of the extenders (which seem to complicate the situation).
Also, just as an aside, when don't they have a way to compare the distance of each router? Couldn't they just put them in a large field with nothing in between and see how far they can go before dropping the signal?!
Dakinbear is offline
post #42 of 70 Old 08-06-2014, 12:23 PM - Thread Starter
bobsilver's Avatar
Quoted: 108 Post(s)
Liked: 62
Originally Posted by Dakinbear View Post
Hi Bob -
The R7000/R8000 routers have greater range then the R6300. Its about 15-20% greater. There are other elements like Beam Forming plus the antennas designs that will help you. I am in a 3000 single floor home and both of these routers cover it. At the edges signal is lower but usable.
I would suggest you look at the R7000. Range wise I think it is better then the R8000 by a little bit. Plus since range is your goal here the big benefit of the R8000 is twice the available bandwidth in the 5ghz range which by its nature has less range then the 2.4ghz band so you wouldn't be getting the benefit.
If there is a way to get a cat 5 cable to another location you can use the R7000 or R6300 as an access point using the other as a router with wireless. This way you could use both devices to get seamless coverage. This is much better then using extenders.
About your question on range testing. Good question but looking at wireless in an unobstructed environment doesn't tell you much. In the end the real world has walls, electrical wiring, other devices that can cause interference, neighbors etc. All of these elements have a lot to do with real range. I agree it would be nice to have a standard but to my knowledge none exist.
So to summarize the R7000 will definitely be better then the R6300 in range. By how much is going to be determined by your environment and placement.
If you are interested I saw a great deal from NewEgg on the R7000 that includes a Chromecast if that is of interest.
Let us know what you do and how it works out. Happy to help you through the process.
Bob
Bob Silver
post #43 of 70 Old 08-06-2014, 06:03 PM
toomanytvstosee's Avatar
Quoted: 148 Post(s)
Liked: 49
the upgrader in me wants to blow the cash on two new R8000's.... The realistic person in me says the two R7000's I have are more than enough.......UGH
Bob, If I am reading your comments from an earlier thread, your saying the router should be in the main area (living room) and the AP in the secondary location?
I have them both connected by Cat6 cable so I am not sure if that matters.
Also, the SSID are the same on both units, should the 2.4 ghz channels be the same or different....... (sorry I just robbed this thread thats probably a no no)
toomanytvstosee is offline
post #44 of 70 Old 08-07-2014, 11:31 AM - Thread Starter
bobsilver's Avatar
Quoted: 108 Post(s)
Liked: 62
The router if you are only using 1 should be in the middle of where the wireless devices are likely to be used. Often that isn't easy so we need to find a work around. In you case where you have 2 R7000 (no need to upgrade IMHO) I would place them at each end third of the house. Again only if you can. The net though with 2 R7000 you should be able to cover a 5k sq ft home. So I doubt you will have any issues.
Use some of the network tools to determine signal strength and noise for testing. Netsp[ot for Mac and inSSIDer home for pc. They will help a lot determining placement.
Bob
post #45 of 70 Old 08-12-2014, 01:27 PM - Thread Starter
bobsilver's Avatar
Quoted: 108 Post(s)
Liked: 62
Updated Beta Firmware available V1.0.0.102_1.0.45
R8000 Beta FW V1.0.0.102
http://files.netgear-support.com/go/?a=d&i=XXBqdeWwAN
Uploaded on: 2014-08-07 10:26:46
File name: R8000-V1.0.0.102_1.0.45.chk
File size: 23.38 MB
Release notes –
(1) Improves the wireless connection stability.
(2) Improves the USB 3.0 IOT and the stability for file access.
(3) Fixes some IPv6 connection issues that happen in certain cases.
(4) Adds support for some IPv6 service over PPPoE.
(5) Improves Time Machine support.
(6) Fixes the issue that may consume more battery power of mobile devices connected to router.
(7) Fixes the issue that disallows multiple port forwarding rules to the same internal port.
(8) Fixes some GUI display issues in the Show Statistics window.
(9) Fixes the connection issue with Sonos speaker.
(10) Removes the detection function for AP mode.
Bob Silver
post #46 of 70 Old 10-14-2014, 09:15 AM
Liked: 0
R8000, r7000 & wndr4500
I've had my R8000 since right after they released. I had started using the Netgears when they rolled out the WNDR4500s. After years of hacking the Linksys routers, Netgear started rolling out some decent hardware that made me look. Plus, after awhile you get tired of always monkeying around with stuff and just want it to work. Used the 4500 for a cpl years though they seemed to brick at 1 yr a cpl times. So When the 7000 came out I was overjoyed at the jump in power and range. With the devices at home becoming more and more WIFI centered I chomped at the bit when I saw the specs for the 8000. Initially after I rolled out the 8000 was a bit disappointed because I lost a bit of range and a few bells/whistles but the power this thing has streaming all the devices we got going is awesome. I am extremely happy with the R8000.
Tim Swartos is offline
post #47 of 70 Old 10-14-2014, 11:44 AM - Thread Starter
bobsilver's Avatar
Quoted: 108 Post(s)
Liked: 62
Hi Tim,
Compared to the 4500 range I experience this. About the same maybe a bit less 2.4g Range. Much better 5ghz range. In fact I find the 4500 5ghz range to be a bit lacking. Compared to the 7000 the 8000 seems very close in performance. I swap between a 7000 and 8000 to compare and they seem very similar to me.
What features are you missing that you want from the 4500?
Without saying something I am not allowed let me say this. NETGEAR is working to unify software and feature sets among the routers. Look to early next year for new firmware that should add back some missing features of early products.
Bob Silver
NETGEAR Networking Assistant
post #48 of 70 Old 10-18-2014, 11:31 PM
Liked: 1
Hello,
So I am currently deployed and need to get an extender. We have decent wifi in the common area but it does not reach into the rooms very good. I was looking at the ex6200, but once I get back stateside I won't have any use for it. Can this router work as an extender while I am here so I can use it as a router after I get home? Thank you.
phifer2088 is offline
post #49 of 70 Old 10-22-2014, 11:50 AM - Thread Starter
bobsilver's Avatar
Quoted: 108 Post(s)
Liked: 62
Originally Posted by phifer2088 View Post
Hello,
The Ex6200 is not a router. It is an wifi based AC extender. A very good one in fact.
When you return it will work with other routers even non AC routers. But again you need a router to use with it. If you want a router you can use as an range extender now and a router later look at the NETGEAR R7000. You can use it in Extender mode now and then as a router. I assume you do not have AC based wifi where you are so getting an AC device is a bit overkill. But if you are looking for a great router solution when you get home then then the R7000 would do you quite well. And the EX6200 has the best range of any extender I have used.
Bob Silver
post #50 of 70 Old 08-20-2015, 04:12 PM
rwheelwright's Avatar
Quoted: 101 Post(s)
Liked: 33
I know this thread hasn't been updated in almost a year so I figured I would add to it. Just got an R8000 today. So far everything works but range seems to be the same as the R700 I just moved downstairs. My issue is that the lower 5GHz band keeps dropping out according to my wi-fi analyzer but the other 5GHz channel and the R7000 5GHz channel don't drop out. I just updated to the latest firmware. Anyone see this before? I watch it. it comes in strong then goes away and 5 - 10 seconds later it comes back and disappears again. Never seen that before. I am using both routers in AP mode since I have FiOS. One is upstairs, the other downstairs. And none of the channels are overlapping. The R8000 is on 44 and 153 and the R7000 is on 161. Channell 44 is the one that keeps disappearing.
Any suggestions?
rwheelwright is online now
post #51 of 70 Old 08-20-2015, 04:19 PM - Thread Starter
bobsilver's Avatar
Quoted: 108 Post(s)
Liked: 62
Any suggestions?
I havent seen drop outs in the lower band buy as a rule you get better performance at the higher channels. When set up that way with Smart Connect the router will put slower devices on the lower band. But range is somewhat better on the lower band but not by much. You could be seeing some interference that is causing your issue as well.
Bob Silver
Netgear Networking Advisor
post #52 of 70 Old 08-20-2015, 06:47 PM
dmarqueset's Avatar
Quoted: 66 Post(s)
Liked: 75
Any suggestions?
I just purchased the R8000 on Aug. 14, 2015. I haven't experienced any drop outs since I've been using it. I have had as much as 3 Blu-ray streams (~23 to 30 Mbps) going at the same time and did not have any pixelation or anything noticeable. I will use inSSIDer and see if I notice any anomalies and report back.
dmarqueset is offline
post #53 of 70 Old 01-03-2016, 08:31 PM
Morpheus_Rising's Avatar
I just bought the R8000 and set it up today. This is my very first router, so I have never used one before. I went to the website www.routerlogin.net and logged in with the default username and password. The instructions tell you have to change the password but not the username. I did change the password. I would like to change the default username but I don't know how. I also changed the wifi network names (SSID) and the passwords (x3). I'm currently using a wired connection to my laptop. I want to add my laptop on wifi at some point but for now I want to add my cellphone. I download network genie and installed it but I don't think I need ReadyShare at this point.
Morpheus_Rising is offline
post #54 of 70 Old 01-04-2016, 02:00 PM - Thread Starter
bobsilver's Avatar
Quoted: 108 Post(s)
Liked: 62
User names are a point of confusion. Some Netgear routers allow you to change them. Others no. Thats the case with the R8000/7000. The real security will come in the form of your password. So choose a good PW and you will be OK.
Regarding your cell phone just add it along with your laptop to the wifi network. No concerns here. Also again set a strong wifi password (Caps, special characters etc) if you are concerned. Another thing you can do is turn off SSID broadcast. What this does is make your network invisible. It can be seen with wifi sniffers but without that you are invisible. Be sure to name your network something you will remember or connecting new devices can be a pain.
The Genie app is a nice to have utility. It will allow to monitor your network and perform basic functions. Its worth the download to become familiar with it. Since this is your first router there is a lot to take in. But for the most part it should operate trouble free. The R8000 is a rock stable router.
Bob Silver
post #55 of 70 Old 01-04-2016, 02:28 PM
Quoted: 875 Post(s)
Liked: 351
Bob Silver
Hey Bob. I sure hope you're right. After having to reboot my R7500 every few days I just went for a R8000. I've read this thread, and it's funny how the R7000 is mentioned but not the R7500. I have a R7000 as a backup.
JoeKustra is online now
post #56 of 70 Old 01-04-2016, 03:30 PM - Thread Starter
bobsilver's Avatar
Quoted: 108 Post(s)
Liked: 62
I used a R7500 as my router for months with no reboot required. Not sure what your issues were. At this point the R7000, R8000 and R7500 are fully baked in the sense that they are all well into their firmware versions so issues are minimal and unique.
I used an R8000 as an access point. Think it ran for 6 months without issue before I replaced it with an R8500 as the AP in my home.
I just replaced the R7500 with the R7000 as the router to test the new updated firmware. Its only days now but so far so good.
Bob Silver
post #57 of 70 Old 01-05-2016, 02:54 PM
Dan0myte's Avatar
Quoted: 30 Post(s)
Liked: 25
I've had an R8000 now since spring of 2015 and no issues to report. Working great, never let me down, no reboots required ever. SecureVault system backup works great with attached USB hard drive, OpenVPN works great, 5GHZ connection & speed has had no issues. I have an access point in a far part of the house and the signal from the Nighthawk is almost as strong as the AP that I'm sitting across from.
One thing I can bring up is the UPnP functionality I guess which has been odd at times and assigning the wrong thing to the wrong device and then missing assigning ports to others that I needed it assigned to. I ended up switching it off and just setting my ports manually and it's fine ever since.
Dan0myte is offline
post #58 of 70 Old 01-06-2016, 09:58 PM
I checked into the settings and looked up things. I found WPA2-PSK (AES) is the best security option. I then wanted to disable SSID broadcasting and got an error pop-up that WPS requires it, so I had to look up WPS. From what I have found it's best to at least disable the PIN option which I did and then I disabled SSID broadcasting.
I then found the 3 guest network options (not enabled) but I configured those with new names and passwords (and disabled SSID broadcasting). I think the basics are now covered. Next, I need to add my cellphone - don't know when to get to that.
post #59 of 70 Old 01-14-2016, 04:58 AM
Quoted: 875 Post(s)
Liked: 351
Hi Bob. I'm now running an R8000. It's a lot faster than my R7500. I am back to having the message to close my window when I logout. I forget how to stop that. The attached devices screen isn't as pretty either. I may enable QoS and see if it works better. I'll give it a few days to see if it fixes the issue I was having with my R7500.
The issue with my R7500: I am using an EX7000 that is allows my computer, AVR, two Blu-Rays and TiVo to get wireless access to the R7500 that is located on a lower floor. Every few days I would lose internet access on the computer. I could change the computer to its internal wireless and gain access. I did find I get my internet access back by doing a power cycle of the router. This operation was 100% repeatable. But if the R8000 doesn't have this issue I will be very happy. BTW, none of my 15 devices has a fixed IP address and 10 have a reservation.
post #60 of 70 Old 01-14-2016, 12:06 PM - Thread Starter
bobsilver's Avatar
Quoted: 108 Post(s)
Liked: 62
Hi Joe,
No idea about the log out issue? When I log into the router and log out via a browser window I jut close the window. That does all I need.
Are you using the Ex7000 as an AP or Repeater? I use one as an AP and have no issues. Seems if its just one pc you are losing internet from its something with that pc. You might try putting in a static ip address and DNS server. If you switch from one network connection to another and it works its something getting refreshed. Is it a windows or mac?
If you are seeing a speed change from the R7500 and R8000 then something was up with the 7500. Unless its because you have more bandwidth in the 5g range. Speed wise they should be very similar. In fact the R7500 even has a faster cpu in it. I had been using a r7500 as my router for almost a year (now R7000). Was fine. That said I used the R8000 (now R8500) as my AP along with a R7000 (now EX7000) as an AP. Worked fine for me. I have 60 ip devices on my network. About 1/3 wireless. As a rule (am old school) I always assign a static ip to pc's that are fixed in the home (not laptops). That way I always know their ip addresses and never have issues with them. Reservation is fine too except you get more control via static like defining dns servers.
Hope I helped in some way Joe.
Bob
ac router , beamforming , streaming , triband
