Wierd Wi-Fi streaming buffering issue - AVS Forum | Home Theater Discussions And Reviews
 3Likes
  • 1 Post By GusGus748s
  • 1 Post By FX4
  • 1 Post By bac522
post #1 of 10 Old 07-05-2014, 06:43 PM - Thread Starter
Quoted: 104 Post(s)
Liked: 34
I have wierd, at least it seems, wierd streaming issue. I was using a 54 MPS wireless router which served my needs just for laptops and tablet. I am getting internet from DSL from local phone company. I decided to start streaming Netflix, Amazon, etc. So I hooked up a Samsung Blu Ray to the wireless network and itt did work for those two. But when I decided to start streaming HULU Plus and M-GO I ran into buffering issues. I figured not surprising considering how old and slow my wireless router is an d maybe those send larger inof.
So I purchased a dual band 300 MPS NetGear router and set it up no issues. HULU Plus and M-Go now work with only minor hick-ups. But now, with the faster server, Netflix is constantly buffering!!! It's so annoying we can't watch it.
I contacted NetFlix and, of course, they blamed my ISP. So I hooked up the Blu Ray player to my router by a cable and absolutely no problems. It streams beautifully. But my wife is not real crazy about the network cable running across the family room floor.
I will run the cable through the basement if I have to. But I would still prefer using wireless if any one has any suggestions.
matonanjin is offline
post #2 of 10 Old 07-06-2014, 04:55 AM
GusGus748s's Avatar
Quoted: 414 Post(s)
Liked: 699
Wired is always better. I switch to an ASUS AC66U router and it has good range and faster wireless speed. However, DSL ISP are pretty slow. You might consider lowering your picture quality under the Netflix settings. May be that will help.
matonanjin likes this.
GusGus748s is offline
post #3 of 10 Old 07-06-2014, 02:12 PM
FX4
FX4's Avatar
Quoted: 138 Post(s)
Liked: 45
Wireless is not the best way to go for streaming HD video. It can be done but there are frequently many issues to battle. Have you considered MoCA adapters? They work well.
FX4 is offline
post #4 of 10 Old 07-07-2014, 06:34 AM
bac522's Avatar
Quoted: 177 Post(s)
Liked: 100
Most likely just a configuration issue on the wi-fi router, a lot of times just simple placement of the location of the wi-fi router. Try changing channels on the wi-fi AP to see if it helps, ensure the router is setup using a 20/40MHz channel.
bac522 is offline
post #5 of 10 Old 07-07-2014, 09:30 AM - Thread Starter
Quoted: 104 Post(s)
Liked: 34
Thanks for you response. If I understand correctly, a MoCA adapter converts my signal from the DSL to Coax. What exactly is that going to get me?
post #6 of 10 Old 07-07-2014, 09:35 AM - Thread Starter
Quoted: 104 Post(s)
Liked: 34
Thanks for your response. This is intuitively logical, since I changed routers. But this means I have to try and figure out how to change "channels on the wi-fi AP", whatever that means.
However, listening to all of your responses here, it seems as though wireless is not the way to go, like I originally thought. I may play with this a little more but will probably end up going wired.
Thanks again.
post #7 of 10 Old 07-07-2014, 06:17 PM
Gronnie's Avatar
Quoted: 32 Post(s)
Liked: 30
Less interference and more stable throughput, which is important when streaming video.
Gronnie is offline
post #8 of 10 Old 07-07-2014, 09:40 PM - Thread Starter
Quoted: 104 Post(s)
Liked: 34
more stable than what?
More stable than what? Than wireless I can understand. But why go with coax rather than network cable? And my blu-ray player that I am using for streaming doesn't have a coax input anyway.
post #9 of 10 Old 07-07-2014, 10:22 PM
Gronnie's Avatar
Quoted: 32 Post(s)
Liked: 30
If you can run an ethernet cable great, go for it. That would be by far the most preferable solution.
MOCA is meant for when there is already a coax run and you do not want to or cannot run ethernet. You don't plug coax into your devices, the MOCA adapter has an RJ45 jack.
Gronnie is offline
post #10 of 10 Old 07-08-2014, 08:41 AM - Thread Starter
Quoted: 104 Post(s)
Liked: 34
Ah ha! Ok.
Thanks to you, bac522, FX4, GusGus, and anyone else I may be missing on the help with this. Great forum!
Netflix , streaming , wireless
