Looking for the best Netflix player - AVS Forum | Home Theater Discussions And Reviews
 8Likes
  • 2 Post By kluken
  • 2 Post By gtgray
  • 2 Post By David Susilo
  • 1 Post By tboe77
  • 1 Post By Westly-C
Old 07-07-2014, 02:19 PM - Thread Starter
David Susilo's Avatar
Quoted: 612 Post(s)
Liked: 584
Question Looking for the best Netflix player
Just for Netflix. i'm looking for advice for the best (best PQ, most stable) Netflix player. I'm currently using WDtV Live but it is slow and unreliable. Often times it needs rebooting. I also use a PS3, but for some odd reason, my 30+ Mbps download speed is only showing as (max) 16 Mbps.
My current best is the Oppo 103D but for Netflix only (and virtually all my viewings are documentaries) I'm unwilling to spend $600.
follow my A/V tweets @davidsusilo
ISF, THX, CEDIA, Control4 & HAA certified
Reviewer for TED & WifiHifi Magazines
my (yet to be completed) BD list
my home theatre
David Susilo is offline
Old 07-07-2014, 04:12 PM
Westly-C's Avatar
Quoted: 325 Post(s)
Liked: 202
The PS3 speed test, as I understand it, has never been an accurate indicator of your true internet speed.
The Roku 3 might be a good option for you. Aside from good reviews for Netflix performance, you'll have a bevy of other channels available that aren't on the PS3. The NF app would be identical to the one on the console though, so you'll lose variety in it's appearance and operation.
Dazed and confused over high tech.
Sigh...Concrap. The Internet Overlord Cometh
They're not com-tastic!
Westly-C is online now
Old 07-07-2014, 04:23 PM
Quoted: 303 Post(s)
Liked: 270
IMO Roku 3 rocks for Netflix and just about anything else I want to stream, Amazon, Plex, etc.
reddice and SMHarman like this.
kluken is offline
Old 07-07-2014, 04:47 PM
gtgray's Avatar
Quoted: 206 Post(s)
Liked: 136
The latest ROKU 3 Netflix app is instantaneous and doesn't bobble a bit on my 30mbs Comcast service at 1080P. For the price of the ROKU 3, I paid $85 at the local BestBuy, I don't see how anyone can go wrong.
Samsung 78" JS8600, Mits WD-92840 43" Samsung 43ku7000 - Lumagen Radiance XS, Martin Logan Motion 40s, Ascend Sierra 2s
58" Panny Plasma -DVDO DUO, Usher S520, JBL HLS-610, Definitive SM45, MusicHall Marimba
gtgray is offline
Old 07-07-2014, 06:52 PM - Thread Starter
Quoted: 612 Post(s)
Liked: 584
Roku 3 it is then !
It will allow me to change DNS so me in Igloo Land can get Netflix from 'Murica right?
Edllguy and SMHarman like this.
my home theatre
Old 07-07-2014, 07:24 PM
mecmec's Avatar
Quoted: 407 Post(s)
Liked: 159
i know you said oppo 103d is oit of your budget, but man...is it goooooooood. also with some..ahem...custom firmware, you open a lot of options for local play back of bd iso files, etc...
mecmec is online now
Old 07-07-2014, 07:45 PM
Westly-C's Avatar
Quoted: 325 Post(s)
Liked: 202
Originally Posted by David Susilo View Post
Roku 3 it is then !
The DNS service you subscribe to, will require inputting their DNS addresses in your router in order for the Roku3 to work that way.
Old 07-07-2014, 08:21 PM
mlknez's Avatar
Quoted: 205 Post(s)
Liked: 52
This is like asking, "What is the best MP3 player" The quality is low on any device.
mlknez is offline
Old 07-08-2014, 05:51 AM - Thread Starter
Quoted: 612 Post(s)
Liked: 584
My modem/router combo does not allow me to do that. Therefore the DNS change have to be done on each individual machine. If I can't change the DNS on the Roku itself then the Roku unit will be useless for me.
my home theatre
Old 07-08-2014, 10:09 AM
Westly-C's Avatar
Quoted: 325 Post(s)
Liked: 202
What brand-and how old, is this router?
Old 07-11-2014, 04:27 PM
tboe77's Avatar
Quoted: 62 Post(s)
Liked: 136
I live in Canada. I also use Netflix in conjunction with a DNS service. I use the 3rd gen. Apple TV.
The menu system of the Netflix app is not as good as other devices. It has too many layers to it, requiring more button presses and screen loads than necessary to get to the show you want to watch. It doesn't support 3D either.
It does, however, allow me to change the DNS settings, and the picture and sound quality are as good as I've seen on any other device.
David Susilo likes this.
tboe77 is offline
Old 07-11-2014, 07:42 PM - Thread Starter
Quoted: 612 Post(s)
Liked: 584
It's the modem/router combo provided by my ISP (Rogers). I asked both Rogers and Unblock-us CSR, both told me that it can't be done
my home theatre
Old 07-11-2014, 08:49 PM
Westly-C's Avatar
Quoted: 325 Post(s)
Liked: 202
Then, if you wanted to, get an inexpensive router and connect it to the ISP's modem , which would allow you to change DNS addresses.
Old 07-11-2014, 09:30 PM - Thread Starter
Quoted: 612 Post(s)
Liked: 584
Being blind about internet tech, so all I have to do is plug in one of the outlets of my modem/router combo to a wifi router? What is the best wifi router out there ($400 max budget)?
Thanks beforehand.
my home theatre
Old 07-11-2014, 09:55 PM
Westly-C's Avatar
Quoted: 325 Post(s)
Liked: 202
Yes, the Ethernet cable that is currently going out from the ISP modem into the computer, would be plugged into a WiFi router. Then from the router to the computer, and any other devices that you'd have wired. Wireless devices would be set to receive WiFi from the router. The ISP gateway would need to be set to 'bridge mode' making the WiFi router the lead device with the gateway the 'dumb' box feeding the router. A call to your ISP and they should be able to set the gateway to bridge mode from their end.
As for what router would be best, I'm currently using an old D-link router, and it works fine for me. A more expensive unit would offer more features such as more detailed band with monitoring, but we'll both (I'm thinking of upgrading) need advice as to the options out there.
Old 07-12-2014, 12:33 PM
bodean's Avatar
Quoted: 170 Post(s)
Liked: 43
Netflix runs just fine on my Xbox One
Sony KDL65W850A 65" LED HDTV  || Bose Soundtouch 130 soundbar || Synology DS716+ NAS || XBOX One ||
Xbox Live : BoDEAN
bodean is offline
Old 07-18-2014, 09:21 AM
EVT
EVT's Avatar
Quoted: 46 Post(s)
Liked: 25
No it doesn't. The X1 sends all audio to your AVR in a predetermined number of audio channels. For example, if you set the X1 to decode in 7.1 if you playback a source (whether it's blu-ray, Netflix, etc.) with less than 7.1 channels the X1 will still send it to your AVR in a 7.1 wrapper. For example, if you tried to stream a movie with stereo 2.0 from Netflix your receiver will see it as 7.1, but what it's actually getting is two audio channels with audio information and 5.1 dummy channels. As well, the Netflix interface is worse than either the ATV3 interface and the common interface found on other devices such as the PS3, PS4, XBOX 360, etc.
This is hugely problematic because it prohibits post-processing by the AVR such as DPLIIx which would ordinarily be used to matrix the 2.0 stream into 7.1. For this reason, nobody with surround sound should be using an X1 to stream anything. Hopefully Microsoft will address this dealbreaker issue.
To the OP's question, other than a Roku 3 I have most of the devices mentioned in this thread. The two I use most are the PS3 and ATV3. Personally, of the two, I generally prefer to use the ATV3, simply because access to Netflix and other services is faster than the PS3 and it turns on instantaneously. Accessing U.S. Netflix is also pretty easy but I found it frustrating on both the PS3 and ATV3, such that I no longer bother (both devices tended to run slower).
Still, if you already have a PS3, I would stick with that for the time being.
EVT is offline
Old 07-18-2014, 09:30 AM
bodean's Avatar
Quoted: 170 Post(s)
Liked: 43
Interesting. I have 5.1 uncompressed set on my XB1, and haven't noticed any issues. I will post this issue though in the xbox preview forums and see what they say.
Xbox Live : BoDEAN
bodean is offline
Old 07-20-2014, 03:59 PM - Thread Starter
Quoted: 612 Post(s)
Liked: 584
I ended up buying an ATV3. Now I only have one "problem". Is there a way to automatically play one episode to the next?
my home theatre
Old 07-20-2014, 04:30 PM
Westly-C's Avatar
Quoted: 325 Post(s)
Liked: 202
Go to Netflix online, select the main profile, and under Your Account, look for Playback Settings. There, you'll see Preferences, and check the play next episode automatically option. That may need to be set for each profile.
Old 07-20-2014, 05:10 PM - Thread Starter
Quoted: 612 Post(s)
Liked: 584
I've done that and it works for my WDTV and PS3 but not ATV3.
my home theatre
Old 07-20-2014, 10:26 PM
tboe77's Avatar
Quoted: 62 Post(s)
Liked: 136
Don't think there's a way to make that work.
As I said in my earlier post, the Netflix interface on the ATV3 is pretty clunky compared to other devices, but the performance, in terms of reliability, and sound and picture quality, is rock solid.
The option to automatically start the next episode would be great. However, on the ATV3 it required about 4 button presses. Annoying, but not a huge deal for me.
tboe77 is offline
Old 07-23-2014, 08:29 PM
tboe77's Avatar
Quoted: 62 Post(s)
Liked: 136
Update: I've been watching The Walking Dead on Netflix on my ATV3. Just within the last few days, I've been getting the option to jump right to the next episode, right when the current episode reaches the credits. Don't know if this is for all shows or just this one.
It's a nice bump in user-friendliness for ATV users.
tboe77 is offline
Old 07-23-2014, 09:01 PM - Thread Starter
Quoted: 612 Post(s)
Liked: 584
It works with some shows and not with others. Mythbusters and How They Do That, for example, don't work, Psych and Rules of Engagement work.
Weird.
my home theatre
Old 07-23-2014, 09:21 PM
tboe77's Avatar
Quoted: 62 Post(s)
Liked: 136
Huh. Definitely weird.
tboe77 is offline
Old 07-24-2014, 06:49 AM - Thread Starter
Quoted: 612 Post(s)
Liked: 584
Sooo weird. This morning Mythbusters goes auto-continue to the next episode!
my home theatre
Old 07-24-2014, 08:03 PM
Westly-C's Avatar
Quoted: 325 Post(s)
Liked: 202
Saw this on a Facebook group posting first, then checked my Twitter account. The pic originated from Netflix, twitter page.
https://www.facebook.com/photo.php?f...type=1&theater
ATV owners may want to check any Apple TV forums for comments from other owners.
