Sony FMP-X10 owners thread - Page 27 - AVS Forum | Home Theater Discussions And Reviews
 796Likes
post #781 of 3884 Old 08-15-2014, 08:49 PM
** Man of Leisure **
AustinJerry's Avatar
Quoted: 7562 Post(s)
Liked: 4224
@Tweaker : Thanks for running a test. But I still don't think we are to the bottom of this problem yet. I played the Karmin clip as well (God, I hate that music), and I was getting all five channels. I tried Eldorado as well, but it doesn't have much surround content, as you say. But then I tried another movie, this time Salt, and no sound from the left surround channel. Perhaps it has something to do with the player's decoding of lossless audio into PCM that is the issue. I believe Salt, and most of the other movies, are DTD HD MSTR, although there is no direct way to confirm this.
So, we need someone to play a movie, not a clip, to see if the problem is duplicated. And, if you run the test, also report the make/model of your AVR. Sony is always quick to blame various AVR manufacturers as being incompatible with the player. I have a Denon.
AustinJerry is online now
post #782 of 3884 Old 08-15-2014, 08:49 PM
TweakerInWA's Avatar
Quoted: 443 Post(s)
Liked: 212
Originally Posted by thestewman View Post
I am also testing the video player and have discovered it is a real multipurpose streaming device.
A detailed report on the video player will follow shortly after I test some additional codecs and formats.
Looking forward to it....
I have the X10 downmix set to surround as well. Also have my Onkyo's HDCP 2.2 input (which the X10's audio is being sent to) setup for Pure Audio on incoming PCM and straight decode for DD, DTS, True-HD....
Sent from my SM-N900T using Xparent BlueTapatalk 2
TweakerInWA is offline
post #783 of 3884 Old 08-15-2014, 08:50 PM
rolldog's Avatar
Quoted: 418 Post(s)
Liked: 136
Yes, if you're testing codecs, let me know what format to burn a movie to using either Nero, DIVX, Cyberlink, Amersoft, etc so I can convert a lot of my movies that are in a digital format to 4k and play them from a USB drive plugged into the media player. I'm in the process of building a new water cooled PC with an awesome graphics card, and I'm wondering if I should put wheels on it so I can move it from my home office to my bedroom, which is where I have my 4K setup.
rolldog is offline
post #784 of 3884 Old 08-15-2014, 08:56 PM
Liked: 4224
I tested the surround playback of the FMP-X10 and here is what I found.
I have the HDMI 2 output of the X10 connected to an HDMI input of an Anthem D2v 3D.
The Anthem processor settings are set for 5.1 audio with the ability to also play the audio as 7.1 by using PLIIx.
i have the X10 audio downmix set to Surround not Stereo
I used Sony Sen downloads Total Recall and the Amazing Spiderman and several others. Not Netflix videos.
With every Sony Sen video I played the Anthem indicated receiving a 5.1 48khz PCM signal of LF Rf C LR RR and Sub.
I could hear audio from all 5.1 speakers and from all the 7.1 speakers when using PLIIx.
Something is not right with your configuration. The player should be passing 5.1 audio as PCM and the Anthem should be playing the audio either as Multi-channel or as Dolby Digital. PLII is 5.1 audio synthesized from a two-channel source. To me, this indicates that the Anthem is either not configured properly, or it is only receiving a two-channel signal.
Your thoughts?
post #785 of 3884 Old 08-15-2014, 09:00 PM
rolldog's Avatar
Quoted: 418 Post(s)
Liked: 136
I wish I wouldn't have sold me Mirage speakers when I built my house and had Sonance speakers put in the ceiling around the house. I feel like setting up my old home theater equipment in my bedroom so I can hear all these movies better. I also wish I would have bought Sony's 4K projector a few months ago instead of this 1080P 3D 300" projector. The 4K resolution is incredible, but I'd like to see what the difference looks like at 300".
rolldog is offline
post #786 of 3884 Old 08-15-2014, 09:04 PM
Liked: 4224
Sorry, but this audio problem is driving me nuts. I changed the Downmix setting to "Surround" and played Total Recall, which has a lot of action in the surround channels. I also turned off my Emotiva XPA-3, which powers LCR so that the surrounds are the only channels playing. It is absolutely confirmed that the left surround is deader than a doornail when playing Total Recall, but active when playing the Karmin clip.
Ideas, anyone?
post #787 of 3884 Old 08-15-2014, 09:05 PM
rolldog's Avatar
Quoted: 418 Post(s)
Liked: 136
Your thoughts?
I agree with you. If you're truly getting a digital signal, PLII shouldn't even be an option. Most receivers can be set on auto so you can hear sound no matter if the signal is digital or PCM, but if he were to change his input from auto to digital, if he doesn't hear anything, he's getting a PCM signsl.
rolldog is offline
post #788 of 3884 Old 08-15-2014, 09:18 PM
rolldog's Avatar
Quoted: 418 Post(s)
Liked: 136
Actually, I don't think setting anything to "surround" will make a difference if you have a digital signal because each speaker has its own track. If a digital signal is coming through, somewhere on the front of your receiver it'll say digital, or a light might come on to indicate digital sound. It's like watching something in DTS ES, or Neo DTS, which is an analog signal converted to sound like a digital signal. If it were a digital signal, a 7.1 signal would play in either DTS ES or Dolby Digital EX, not Pro Logic.
rolldog is offline
post #789 of 3884 Old 08-15-2014, 09:18 PM
Quoted: 443 Post(s)
Liked: 212
Sorry, but this audio proble is driving me nuts. I changed the Downmix setting to "Surround" and played Total Recall, which has a lot of action in the surround channels. I also turned off my Emotiva XPA-3, which powers LCR so that the surrounds are the only channels playing. It is absolutely confirmed that the left surround is deader than a doornail when playing Total Recall, but active when playing the Karmin clip.
Ideas, anyone?
I would have to download either Salt or Total Recall for comparison, but we both know how long that's going to take. I will start downloading one of them, I like both, any suggestions as to which has the better 4K pq. ..
post #790 of 3884 Old 08-15-2014, 09:32 PM
Liked: 4224
I have not watched either movie in its 4K format yet. I'll defer to someone who has. From the brief passages of Total Recall that I have watched while conducting tests, the quality looks pretty good.
post #791 of 3884 Old 08-15-2014, 09:36 PM
Quoted: 443 Post(s)
Liked: 212
Also, I am getting audio to the SL channel on the Total Recall preview.... My Onkyo's getting kicked out of Pure Audio the way it's currently configured lol.... When Total Recall was released on Blu-ray, audio format was Dolby TrueHD. I would assume it's the same. Salt was DTS-HD..... so that just doesn't help narrow things down one bit!!....lol
post #792 of 3884 Old 08-15-2014, 09:38 PM
thestewman's Avatar
Quoted: 330 Post(s)
Liked: 109
Your thoughts?
You might be confusing PLII with PLIIx
The Anthem is equipped with PLIIx to enable it to play 7.1 with 5.1 sources.
Either PLIIx Music or PLIIx Movie.
As I indicated the Anthem D2v processor indicates it is receiving a 5.1 48khz PCM signal
consisting of LF, C, RF, RR, LR and Sub. To test I temporarily turned off the 7.1 and listened to the 5.1 audio first.
thestewman is offline
post #793 of 3884 Old 08-15-2014, 09:47 PM
Quoted: 443 Post(s)
Liked: 212
Total Recall comes pre-loaded, so I just purchased it. Any specific scene you want to compare, or you just don't get audio out of the SL channel period?
post #794 of 3884 Old 08-15-2014, 09:55 PM
Quoted: 443 Post(s)
Liked: 212
Sure as sh*t, no audio from the SL channel... As a matter of fact, it will completely drop both SL and SR occasionally. Hmmmmm, Sony should be getting a ton of calls from folks here....Ridiculous
post #795 of 3884 Old 08-15-2014, 09:59 PM
thestewman's Avatar
Quoted: 330 Post(s)
Liked: 109
PCM is a digital signal and we are using HDMI which only carries a digital signal.
Though a few users are using optical but it is still PCM digital but might be at a lower bit rate
The FMP-X10 is NOT capable in its current design of playing the Lossless audio codecs of
Dolby TrueHD or DTS HD Master.
Sony may not have wanted to pay the licensing fees or maybe the lossless formats
would have contained larger files to download.
Sony is confusing the normal setup by misnaming some of the parameters
In the audio setup they give you the option of Downmix. Stereo or Surround .
In reality I have read the video file specs with Media Info and almost all except some real old 4k videos Sony is offering contain a surround signal. So you can Downmix to stereo or leave it as a surround file. Confusing.
The same for selecting PCM or Auto. I have no idea what they are inferring as the audio is already PCM.
So what setting it to Auto achieves I have no idea and neither does Sony CS. when I asked them.
post #796 of 3884 Old 08-15-2014, 10:06 PM
thestewman's Avatar
Quoted: 330 Post(s)
Liked: 109
Describe your audio setup. The processor,connections, etc
Is this a 5.1 setup ?
Some scenes have no surround info so the speakers can by quite quiet
post #797 of 3884 Old 08-15-2014, 10:13 PM
Jyoti's Avatar
Liked: 0
Ideas, anyone?
Yup! Left surround sound speaker is active when playing Karmin but is dead when playing all other titles. I've tested the following movies with no sound from left surround.
Total Recall, Spiderman, Spiderman 2, Patriot, A few good men, smurfs 2...basically every movie I have dl'ed from SEN with HDMI 2 audio out - I get no sound from left surround. Changed downmix from stereo to surround and back to stereo. Confirmed Denon is receiving 5.1 48khz pcm digital from fmp-x10. Anyways, seems like sony prefers jacking up prices on their 4k movies instead of fixing the hdmi 2 audio issues. If ya'll figure out a fix, please let us know. In the meantime, i'll just use my ARC for audio.
Jyoti is offline
post #798 of 3884 Old 08-15-2014, 10:22 PM
Quoted: 443 Post(s)
Liked: 212
No problems with my setup... If I watch the Total Recall preview on 4K Unlimited I get audio from all speakers, after purchase and playing the same scene off the HDD, no audio from the SL channel. The SR is stable, was probably just a sync issue earlier.
post #799 of 3884 Old 08-15-2014, 10:22 PM
thestewman's Avatar
Quoted: 330 Post(s)
Liked: 109
Guys
All these different Dolby and DTS codecs are digital.
You only have two choices Analog or Digital.
DTS ES, DTS Neo Dolby Digital Ex etc are just older digital formats that are highly compressed after encoding
post #800 of 3884 Old 08-16-2014, 12:29 AM
Grubs92's Avatar
Quoted: 49 Post(s)
Liked: 26
I have an issue with the x-10 it won't let me purchase anything, all I get is an empty black bar where I assume the purchase box is. I can't even download preview trailers.
Grubs92 is offline
post #801 of 3884 Old 08-16-2014, 05:42 AM
Quoted: 443 Post(s)
Liked: 212
Did you go online and actually create a SEN account?
Can't believe I got up at 5:00 am on a Saturday for the BPL season kickoff...zzzzzz
post #802 of 3884 Old 08-16-2014, 05:55 AM
Liked: 4224
I am not confused. Both PLII and PLIIx are synthesized multi-channel formats, not discrete digital formats. Not being familiar with Anthem, I don't know why it would display PLII if it is receiving a discrete 5.1 source. My Denon will not even allow PLII when the source is discrete.
I think we have enough feedback to indicate that there is a real issue with the X10 audio, so the next step should be to report it to Sony.
post #803 of 3884 Old 08-16-2014, 08:07 AM
rolldog's Avatar
Quoted: 418 Post(s)
Liked: 136
I know this thread is for the FMP-X10, which I finally got working after returning the first one, but has anyone bought one of Sony's DVD players and played one of their DVD's which are "Mastered in 4K?"
rolldog is offline
post #804 of 3884 Old 08-16-2014, 08:24 AM
LeeSoFl's Avatar
Quoted: 277 Post(s)
Liked: 305
In June '13, I bought the 65/900A, the X1 and a BDP-790. The TV purchase offered "Spiderman" (2002), "Ghostbusters" and "Angels and Demons" on Blu-ray, Remastered in 4K. The Blu-ray player is not set to upconvert, the TV does that.
What is your question?
LeeSoFl is offline
post #805 of 3884 Old 08-16-2014, 08:57 AM
rolldog's Avatar
Quoted: 418 Post(s)
Liked: 136
Well, I actually have 2 questions. First, I'm just wondering if the DVDs, which read "Mastered in 4K" have a better picture or have better sound than just a regular Blu Ray disk played on a 4k TV. Second, since most, if not all, 4K TVs upconvert, why would anyone buy a something like Sony's new BDP-S7200, which is supposed to upscale to 4K, access to Netfix, SEN, etc? If someone owns a 4K TV and already has a Blu Ray player (not this particular one) what's the benefit of owning this new Blu Ray player? 4K TVs already have a lot of these features built-in. Unless someone owns a different brand of TV, it'll give them access to SEN, other than that, I don't see the benefit. And to combine the questions, if someone were to watch Spiderman 2 Mastered in 4K on this new Blu Ray player, will it look better, worse, or the same as watching it on the FMP-X10?
rolldog is offline
post #806 of 3884 Old 08-16-2014, 09:07 AM
Grubs92's Avatar
Quoted: 49 Post(s)
Liked: 26
Yes, I had an account that I logged into.
Edit: fired it up this morning and it allowed me to download and purchase content. Don't know what happened last night.
Grubs92 is offline
post #807 of 3884 Old 08-16-2014, 09:09 AM
Quoted: 443 Post(s)
Liked: 212
Should we even bother calling the "Extended Hours" weekend number, or just hold off until Monday and have a bunch of people call. I say we schedule a time and all call at once !!! lol
post #808 of 3884 Old 08-16-2014, 09:11 AM
Quoted: 443 Post(s)
Liked: 212
Try resetting the box....
post #809 of 3884 Old 08-16-2014, 09:26 AM
rolldog's Avatar
Quoted: 418 Post(s)
Liked: 136
I'm still waiting for my call back from customer service about how to fix my FMP-X10, even though I've already swapped it out for a new one, which seems to be working. I called them last weekend, when my error message changed from Network not available to Error 6002, and they told me to call them back on Monday because the service level I was talking to doesn't work on the weekend.
rolldog is offline
post #810 of 3884 Old 08-16-2014, 09:29 AM
Quoted: 443 Post(s)
Liked: 212
I don't buy into the "Mastered In 4K" Blu-Ray stuff. It might improve (very very very slightly) some aspect of the PQ of the regular Blu-Ray (maybe I just haven't seen it) due to the higher bitrate... But otherwise, it's the same 1080p/24 format using AVC/MVC encoding (MVC only because of the multiview video coding needed for 3D flix). So in my opinion, I don't think you'll see much (if any) difference between the Blu-Ray and the "mastered in 4K" version. Especially on the X900 which does a magnificent job of upscaling content on it's own as is.....Remember those superbit versions of Blackhawk Down and a few other movies?, same principle, just with the Sony stamp on the end product.... and you see how well those went. Not bad, more of a placebo effect IMO..
I have a suggestion, buy the same disk, have someone load the disks and do a blind comparison of specific scenes in the movie.... Going to cost a couple of bucks, but it would put your mind at ease.
Edit: The answer to your last question, just my opinion, but there shouldn't be any question that the 4K version on the X-10 should look better. Hard to say right now as Spiderman won't be out until the 19th ? But either way, if you're seated at the correct distance, the true 4K should indeed look better...If not, then I'll be skipping the rest of this whole 4K revolution thing for good..lol
fmp-x10
