Cannot Upgrade to USB 3...Add Sata Internal drive instead. - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By bigbarney
post #1 of 8 Old 07-16-2014, 08:11 AM - Thread Starter
Quoted: 12 Post(s)
Liked: 0
Hello all,
I am trying to eliminate all of the possible bottlenecks in my system (Old PC) that I am using for streaming local content. I am upgrading my NIC Card and Switch now. I was planning to add USB 3 since I store files on external drives. Unfortunately, I do not have a PCIe port available.
My question is.... Would my next best option be to add a couple of SATA internal drives to store the video files on? There are SATA ports available and space to add them in the case. In theory, that would take USB out of the mix.
MontyTheLab is offline
post #2 of 8 Old 07-16-2014, 08:20 AM
elario's Avatar
Quoted: 43 Post(s)
Liked: 66
USB 2.0 has a real-world max throughput of about 35MB/s. That's 280Mbps. Unless you are serving full BDs to 5 or 6 clients simultaneously, it's not gonna be a bottleneck.
elario is offline
post #3 of 8 Old 07-16-2014, 08:26 AM - Thread Starter
Quoted: 12 Post(s)
Liked: 0
Thanks...I am also using run of the mill 3TB WD External Drives....Should that set up be sufficient to run 1080? (that is my goal) I am successful with 720 streaming via hard-wire (with Old NIC Card and switch - not Gigabit). - I am upgrading those now.
Just wondering if I should go ahead and add a drive now while the case is open.
post #4 of 8 Old 07-16-2014, 09:02 AM
elario's Avatar
Quoted: 43 Post(s)
Liked: 66
Add a new drive if you want. USB 2.0 will not be a bottleneck for playing videos. But there are plenty of other reasons why you might want an internal drive instead of an external.
elario is offline
post #5 of 8 Old 07-16-2014, 09:14 AM
bigbarney's Avatar
Quoted: 165 Post(s)
Liked: 61
Yeah, but you have to write to the drive too, and writing multiple gigs to a usb2 drive takes forever. Better off with sata if you can. Then when the drive is full you can stick it a usb2 box
bigbarney is offline
post #6 of 8 Old 07-16-2014, 09:38 AM - Thread Starter
Quoted: 12 Post(s)
Liked: 0
So I gather that I should go ahead and throw a SATA HD in there, right? (thanks) I think that I can grab a 3TB drive for ~100 bucks. May be money well spent.
post #7 of 8 Old 07-16-2014, 12:19 PM
bigbarney's Avatar
Quoted: 165 Post(s)
Liked: 61
Yeah. If you're dealing with bigger files (blu ray rips, full dvd rips... etc) then you'll have more fun ripping your teeth out with a rusty set of pliers than you will writing to a usb2. Go sata then once you fill it you can always stick it in a usb box and place it somewhere else on your network if you wish.
MontyTheLab likes this.
post #8 of 8 Old 07-18-2014, 03:53 PM
mecmec's Avatar
Quoted: 439 Post(s)
Liked: 177
If you have an extra 5.25" bay free, I highly recommend a "hot swap" bay. It is connected via sata internally and makes swapping out drives super easy!
the first example i can find: there are many different variants...
http://www.amazon.com/StarTech-com-5...a+hot+swap+bay
mecmec is offline
