RAID 5 recovery? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 07-22-2014, 07:20 PM - Thread Starter
extotherule's Avatar
RAID 5 recovery?
So gents,
I came home to that unfortunate experience post vacation of a busted water line that had been running for 3-5 days. It started in the master bath, took out half of the 2nd floor, then entire first floor, and the basement.
While it was taking this all out, it dripped into my media server.
SO... I am in the process of trying to see if anything is recoverable.
First things first.
The power supply seems to work (will be replacing anyways)
but the mother board seems pretty well fried.
I had 1 SSD for my boot drive and 4X4TB WD Red drives for storage.
I had an ASRock Z77 Extreme3 motherboard and was running the RAID off of this.
So the questions.
1. If I buy a new ASRock Z77 Extreme 3 motherboard and plug all the drives in, and if they weren't damaged, can I rebuild the RAID without data loss?
2. Can I do this with a newer motherboard if I wanted to upgrade, but not lose all of my data.
3. Any suggestions.
Thanks as usual,
I just haven't had to deal with this one ever, and I hope you don't either.
extotherule is offline
post #2 of 7 Old 07-22-2014, 08:06 PM
mlknez's Avatar
Quoted: 205 Post(s)
Liked: 52
What operating system were you running? Were you using a special raid program?
mlknez is offline
post #3 of 7 Old 07-22-2014, 10:20 PM
robnix's Avatar
Quoted: 661 Post(s)
Liked: 494
Originally Posted by extotherule View Post
So gents,
First things first.
So the questions.
3. Any suggestions.
Thanks as usual,
Was this hardware RAID or Linux/Windows software RAID? Linux and Windows will both allow you to import existing RAID configurations. Just install the OS on the SSD, then, and only then, connect the RAID drives so you can import the array.
Looky here!
robnix is offline
post #4 of 7 Old 07-23-2014, 08:34 AM
blackssr's Avatar
Quoted: 1158 Post(s)
Liked: 578
So gents,
First things first.
So the questions.
3. Any suggestions.
Thanks as usual,
No need to rebuild raid at all. You should use the same Mainboard, just setup the Intel bios for raid 5 before you plug in the drives. Plug HDDs into same ports is good practice. The raid info will carry over automatically if all the drives are good. I have done quite a few time with servers over the years
blackssr is offline
post #5 of 7 Old 07-23-2014, 11:08 AM
replayrob's Avatar
Quoted: 666 Post(s)
Liked: 626
I'd also stick with the same MB for the new setup- it will pretty much guarantee no loss of data unless you have more than one damaged member.
And as blackssr mentioned above- make sure you match the SATA ports on the new MB to the ports on the old MB for each particular drive.
For simple raid servers, you don't need super duper MB screaming performance, so long as they still make/sell your original MB and it's not painfully obsolete that's the way to go.
“You cannot play God and then wash your hands of the things you created.”
Commander Bill Adama
replayrob is offline
post #6 of 7 Old 07-23-2014, 09:43 PM
bigbarney's Avatar
Quoted: 163 Post(s)
Liked: 60
And turn the water off when you go on holidays!
bigbarney is offline
post #7 of 7 Old 07-26-2014, 06:16 PM - Thread Starter
Hey guys,
Good news, I was able to pop the drives into an updated machine and everything came back online. Thanks a bunch for the feedback!
