How to stream MKVs to an Xbox - AVS Forum | Home Theater Discussions And Reviews
Old 07-28-2014, 02:06 PM - Thread Starter
NeilF's Avatar
OK, I simply want to play MKV files from a NAS.
I've tried setting up Windows Media Center on a Windows 7 machine to feed them to the XBox, and although I can see photos, Windows Media Center doesn't seem to want to find/list my MKV files.
I've followed this, which hasn't helped - http://www.groovypost.com/howto/howt...-media-center/
I'm concerned also that streaming the footage over my homeplugs won't work. ie: It would be better if the XBox natively uncompressed the MKVs?
Anyway, anyone offer any help/advice?
NeilF is offline
Old 07-28-2014, 04:28 PM
Charles R's Avatar
Liked: 536
If you look/search in the Home Theater Computers forum you'll find various references to get your started. Typically installing (just) Shark007 will get you rolling. Personally, I'd skip the Xbox and use a streamer especially if you want to use it for anything but casual playback.
| 120" Screen | 1080p Projector | 7.2.4 Boston Acoustics & Power Sound Audio | Yamaha RX-A3060 & AudioSource AMP110 | Philips BDP7501 | LibreELEC/ODROID-C2 Media Client | Ubuntu/ODROID-XU4 Server via Kodi/Plex Media Server : LG 65EG9600 OLED TV | TiVo | Premiere+ | Blu-ray Movies for Sale | Digital HD Codes for Sale |
Charles R is offline
Old 07-28-2014, 04:30 PM
Otter0911's Avatar
Quoted: 69 Post(s)
Use Plex or PlayOn
Otter0911 is offline
Old 07-29-2014, 01:33 AM - Thread Starter
NeilF's Avatar
Having tried a few options, and seen how clunky DNLA is, with various drops/jitters etc etc I'm coming to the same conclusion! Any suggestions for a simple unit aimed at allowing friendly/fast navigation of material held on a NAS?
NeilF is offline
Old 07-29-2014, 04:36 AM
Alx330's Avatar
Quoted: 17 Post(s)
Liked: 47
Xbox is a terrible player got nothing to do with DLNA.
Because the xbox has such crappy media support your limited to transcoding video and if you do a lot of fast navigation ffw/rwd then transcoding is a bad idea as the back end server is having to convert the media in real time which is a huge strain depending upon your server. Using homeplug/powerline adapters doesnt help either if the connection is poor.
What you could do is run the files through MKVtoMP4 with AAC audio enabled in the options, that should make Xbox play videos natively so server no longer transcodes content but your homeplugs might still be a bottleneck.
If it's not a network issue than replace it with more modern hardware like an Intel NUC running XBMC Openelec, good fast CPU and use the pulse eight adapter to make it work with your TV remote via HDMI-CEC.
Alx330 is offline
Old 07-29-2014, 04:42 AM - Thread Starter
NeilF's Avatar
I might just get an old Boxee Box and put BoxeeBox+ on it then...
NeilF is offline
Old 07-29-2014, 05:24 AM
Alx330's Avatar
Quoted: 17 Post(s)
Liked: 47
Why bother with boxee NUC is faster more capable and more stable, even the cheapest Celeron model. If your going to be doing a lot of ff/rwd then you want a fast CPU, not the old atom based thing that powers the Boxee.
If you really want to stick with the Xbox you need a PC server (with Core i3 or thereabouts CPU) running Mezzmo or Serviio DLNA server, those are two of the best. Does the Xbox WiFi adapter support 5Ghz wireless ? if your router does you might want to go down that path instead of homeplugs if the connection is still an issue.
Most consumer NAS do not have the power to properly transcode video in real time, Synology's Play series is an exception as it has a hardware transcoder built in.
Alx330 is offline
Old 07-29-2014, 05:41 AM - Thread Starter
NeilF's Avatar
^^ Fair enough... But a Boxee is turnkey and can be had for under £80.
NeilF is offline
Old 07-29-2014, 06:06 AM
Alx330's Avatar
Quoted: 17 Post(s)
Liked: 47
Celeron NUC doesn't cost much more with a tiny mSATA drive or USB stick running Openelec, you'll probably pay around £120 -£130 in total.
You can get it even cheaper via the Asus Chromebox which is the same unit but there is a little more work involved in installing Openelec.
You still have to hack a Boxee and it's not really turnkey any more. Plus NUC's arent like putting a PC together, you stick RAM, HDD/SSD or USB drive into it and turn it on, anyone reading this forum can do that.
Alx330 is offline
Old 07-29-2014, 06:39 AM - Thread Starter
NeilF's Avatar
OK interested, but surely Celeron NUC + memory + SSD + remote isn't going to be £130? Surely we're heading closer to £200?
I assume putting XMBC on the unit is just flashing a USB and booting off it?
NeilF is offline
Old 07-29-2014, 06:59 AM
smitbret's Avatar
Quoted: 314 Post(s)
Liked: 96
I echo everything that Alx330 is saying.
The Xbox will work, but I would only use it as the occasional streaming box and only with good Server software like Mezzmo, Serviio, etc. They will transcode incompatible files (which will be many) on the fly but requires the serving PCs CPU be powerful enough to transcode in real time, and while it's happening, you won't have things like FF/Rew.
Boxee works pretty well as does something like a WDTV Live but if you are ready to invest a little more, a Chromebox running XBMC is a great way to go and will stream more smoothly. The NUC is the other way to go but will be slightly more expensive since you have to add RAM and an HDD. The Chromebox has a built-in SSD, that while only 16GB, is pretty quick and if you set it up to direct boot into OpenELEC, you can be up and running in less than 5 seconds. The customization with XBMC is huge, too. You can dual boot the NUC/Chromebox or even run XBMC from the OS. I prefer the OpenELEC version that just installs from a Flash Drive and the just boots from the internal HDD straight into XBMC.
If you have the time and a little extra cash, you will not regret NUC or Chromebox running XBMC.
smitbret is offline
Old 07-29-2014, 07:07 AM - Thread Starter
NeilF's Avatar
So are you able to point me to a good resource?
Surely the Chromebox would be the best/cheapest option for a simple XBMC?
Two questions:-
1) I need optical output, so could I just get a £10-20 USB sound card and use it for optical out?
2) A remote?
And I'd then be good to go?
NeilF is offline
Old 07-29-2014, 07:29 AM
Alx330's Avatar
Quoted: 17 Post(s)
Liked: 47
Optical out complicates things NUC's dont normally have those but you can buy HDMI audio extractors like this for £26. One other option is a USB sound card which have SPDIF optical out like this for £9 but I've no tried it personally, in theory it should work but the Openelec forums may know better.
Celeron NUC £103
RAM £16
You dont need to buy a mSATA drive you can run Openelec from a USB flash drive if you have one lying around. But if you want one here is a mSATA for £22.
Lastly a remote, get a cheap MCE remote for £10-15 or get the Pulse Eight CEC adapter (around £30) if your TV supports CEC and most should these days (edit forgot about audio extractor the PE CEC adapter may not work with that in place so you might be limited to MCE remote or use a tablet/phone to control XBMC).
So with extractor, NUC, RAM, MCE remote you're around the £160 mark, still cheaper than things like the Popcornhour and more capable.
It doesn't look like the Asus Chromebox is sold in the UK, all the prices on Amazon UK are very high import prices.
Another XBMC option with optical out is the Solidrun CuBox-i series a more powerful version of the Raspberry Pi, this has optical, IR and HDMI-CEC out of the box, all you do is buy the unit and a micro SD card, burn Openelec to SD card and then put in the box and turn it on. Get the i2 (dual core CPU) or the i4 (quad core CPU) model, the downsides are support for CuBox-i is still in alpha state and they make them in batches, due to high demand there is waiting time in getting one.
Alx330 is offline
Old 07-29-2014, 08:15 AM - Thread Starter
NeilF's Avatar
Celeron NUC £103
RAM £16
So surely the latter makes the most sense? Buy the Solidrun CoBox-I4 one for $140 (+$20 postage) which means under £100. Buy a microsoft mce remote control, and a super fast SDRam card and voila!?
NeilF is offline
Old 07-29-2014, 10:05 AM
smitbret's Avatar
Quoted: 314 Post(s)
Liked: 96
That's tough. The Chromebox would be better as would an NUC since both have x86 CPUs that can software decode. But if they lack the connections.....
I don't know about the availability of the FireTV in the UK but I would start leaning that way at this point.
This is the first time I've run into the Solid Core but I would be skeptical. Clicking the Product link on SolidRun's own website takes you to a dead link. It looks like just another Android box to me. There's been a few come and go like this through the XBMC forums. They all have their fans and their detractors.
smitbret is offline
Old 07-29-2014, 10:17 AM - Thread Starter
NeilF's Avatar
I didn't think FireTv was very good with local (networked NAS) material (eg: MKV)? Which is my biggest requirement?
NeilF is offline
Old 07-29-2014, 12:23 PM
Charles R's Avatar
Liked: 536
I would try this guy... http://www.amazon.com/WD-TV-Media-Pl...s=wd+tv+stream
I wouldn't bother cracking a FireTV or some such as there are always trade-offs. I have used several NUCs with and without OpenELEC. A low-end unit with memory and a flash drive running OpenELEC would be my second choice. The WD offers wall art and very limited Themes so I don't really see the need for OpenELEC but you would have the ability to use various XBMC Add-ons (of which I don't).
Old 07-29-2014, 01:52 PM - Thread Starter
NeilF's Avatar
Well, if we're getting back into that territory I would have thought a Boxee Box (Plus) would be the better option. Faster and more functional for local content.
NeilF is offline
Old 07-29-2014, 02:32 PM
Charles R's Avatar
Liked: 536
It doesn't support HD Audio (without issue) at least back in the day I tried and wrote it off. Plus the vibrating case via the fan drove me nuts on a few units.
TrueHD and DTS-HD are not working yet (while DD/AC3 and DTS inside TrueHD and DTS-HD respectively works fine).
Some users have some sort of audio-drops when enable HDMI or SP/DIF pass-through.
Above via XBMC... never used Plus so I can't comment.
Boxee+ doesn't fix the audio blip AFAIK. - reportedly...
Old 07-29-2014, 03:30 PM - Thread Starter
NeilF's Avatar
Thanks...
Not bothered with HD Audio as I generally use DTS so that shouldn't be a problem then? I would be outputting the audio over SPDIF to my amp!?
NeilF is offline
Old 07-30-2014, 02:31 AM - Thread Starter
NeilF's Avatar
If you aren't dong HD audio the Xbox with Shark007 might hit the spot. Especially, if it's already in play for WMC or some such.
I've been down the Windows Media Center route with various fun and games for MKVs and then using DNLA via the XBox and it was not an impressive performance. Trying to FF or RWD generally meant the video would reset to the beginning etc.
I tried Universal Media Server too, and not really any better.
So I think the only answer is a dedicated Media Player...Hence the discussion(s) above. Just a question of which to get!
NeilF is offline
Old 07-30-2014, 05:12 AM
fmedrano1977's Avatar
Quoted: 322 Post(s)
Liked: 95
If seeking to play mkv's is all you need, then you can't go wrong with the affordable WDTV Live, Best Buy price matches Amazon sold products.
Sent from my HTC One_M8
fmedrano1977 is offline
Old 07-30-2014, 05:16 AM - Thread Starter
NeilF's Avatar
I heard the interface was kinda laggy?
What attracts me to the BoxeeBox is it's a step towards XBMC with a nice slick/friendly interface to navigate your local (NAS) media.quickly.
I get the impression with the WDTV you'd need to navigate yourself over to the nav, and through folders etc etc. Using a somewhat slow interface?
NeilF is offline
Old 07-30-2014, 06:40 AM
Alx330's Avatar
Quoted: 17 Post(s)
Liked: 47
Yes WDTV Live has slower UI in comparison.
If you can wait for it then you would like the Solidrun CuBox-i it comes close to the experience of running XBMC on a NUC with it running XBMC at 1080p@60fps but as I said software is still in alpha state, when it hits beta that would be when to jump on board and then there are the delays in shipping you could be looking at 1-2 months before you get it.
The hardware the CuBox-i uses (Freescale iMX6) is also in another XBMC project the Ezeecube which might also be available at the end of this year.
The NUC plus the HDMI audio extractor should deliver everything you want, I think thats really the way to go instead.
Alx330 is offline
