WDTV Firmware Update Questions - Page 2 - AVS Forum | Home Theater Discussions And Reviews
 9Likes
post #31 of 67 Old 08-10-2014, 01:41 PM - Thread Starter
JRock3x8's Avatar
Quoted: 647 Post(s)
Liked: 163
Originally Posted by Otter0911 View Post
You can do both. I would try manually first...
so I know how to rename the movies - how do I manually add movie posters? Is that just throwing jpgs in the same foldeR?
oh I see a bunch of XML's out there now...is there a program that can generate these XML's? Is that thumbgen?
Thumbgen thinks that all of my movies that it can't find are "Divergent" which is basically all of them...
JRock3x8 is offline
post #32 of 67 Old 08-10-2014, 01:58 PM
Otter0911's Avatar
Quoted: 69 Post(s)
Hit the Options button then Get Content Info
Otter0911 is offline
post #33 of 67 Old 08-10-2014, 05:18 PM - Thread Starter
JRock3x8's Avatar
Quoted: 647 Post(s)
Liked: 163
my only options are auto or manual - not sure what I would do in "manual" mode
also not sure but I am not seeing any of the plot synopsis, actor or other stuff. the xml for source code has :
"overview>Decorated soldier Captain Colter Stevens wakes up in the body of an unknown man, discovering he's involved in a mission to find the bomber of a Chicago commuter train. He learns he's part of a top-secret experimental program that enables him to experience the final 8 minutes of another person's life. Colter re-lives the train incident over and over again, gathering more clues each time. But can he discover who is responsible for the attack before the next one happens?</overview>
<year>2011-04-01</year>
<runtime>93</runtime>
<title>Source Code</title>
<cast>Jake Gyllenhaal / Michelle Monaghan / Vera Farmiga / Russell Peters / Joe Cobden / Michael Arden / Jeffrey Wright / Cas Anvar / Brent Skagford / Craig Thomas (II) / Gordon Masten</cast>
<director>Duncan Jones</director> "
but I'm not sure how to view that info on the WDTV.
JRock3x8 is offline
post #34 of 67 Old 08-10-2014, 06:12 PM
Otter0911's Avatar
Quoted: 69 Post(s)
Are you using Stock Theme (mochi) or a different theme?
post #35 of 67 Old 08-10-2014, 07:40 PM - Thread Starter
JRock3x8's Avatar
Quoted: 647 Post(s)
Liked: 163
Simple
JRock3x8 is offline
post #36 of 67 Old 08-10-2014, 08:12 PM
Otter0911's Avatar
Quoted: 69 Post(s)
Ok with Simple you won't see any of the movie info until you go to the movie hit Option on remote than hit View Info
JRock3x8 likes this.
post #37 of 67 Old 08-11-2014, 03:00 AM - Thread Starter
JRock3x8's Avatar
Quoted: 647 Post(s)
Liked: 163
are there any xml generators where I can just tell it "this is "x" movie"? I am amazed at how bad thumbgen's guessing skills are.
JRock3x8 is offline
post #38 of 67 Old 08-11-2014, 05:01 AM
Otter0911's Avatar
Quoted: 69 Post(s)
This is what I use..It's a very basic XML generator... http://www.frillen.dk/apps/xml-editor/
If naming is a issue for the WD go to... http://www.themoviedb.org/ That's where the WD gets it's info from. For TV Shows...http://thetvdb.com/
Just match the name to those sites.
post #39 of 67 Old 08-11-2014, 06:52 AM - Thread Starter
JRock3x8's Avatar
Quoted: 647 Post(s)
Liked: 163
ok but can I change it back then afterwards? The reason I have my movies named the way I do is so Batman Begins is not on the complete opposite side from The Dark Knight...
JRock3x8 is offline
post #40 of 67 Old 08-11-2014, 07:31 AM
Otter0911's Avatar
Quoted: 69 Post(s)
I would just use XML Editor and name them how ever you want. It's very easy to use.
post #41 of 67 Old 08-11-2014, 08:05 AM - Thread Starter
JRock3x8's Avatar
Quoted: 647 Post(s)
Liked: 163
thanks will check that out. Really appreciate all your help.
Otter0911 likes this.
JRock3x8 is offline
post #42 of 67 Old 08-12-2014, 03:46 AM - Thread Starter
JRock3x8's Avatar
Quoted: 647 Post(s)
Liked: 163
seems like the easiest way to do this is to rename the movies to something the WDTV understands and then let it find the content.
I'm going to test renaming the files back to the way I want them ordered tonight and pray that works.
I really wish I could force the WDTV to only look at one directory but it seems to pick up the entire damn drive every time.
What if I mark the folders I dont want the WDTV to see as hidden? Will that work?
JRock3x8 is offline
post #43 of 67 Old 08-12-2014, 07:02 PM - Thread Starter
JRock3x8's Avatar
Quoted: 647 Post(s)
Liked: 163
can't seem to get it to recognize the phantom menace or the original Star Wars. hmmm.
edit : renaming the movies, the xml and the metathumb keeps the XML intact but somehow corrupts the metathumb so it no longer associates with the movie file. Sigh.
JRock3x8 is offline
post #44 of 67 Old 08-13-2014, 05:45 AM - Thread Starter
JRock3x8's Avatar
Quoted: 647 Post(s)
Liked: 163
that XML editor might be okay for doing one movie at a time but running 40 that way is a bit tedious.
Also, how do you get multiple backdrops into that editor? or do you just break into the XML manually afterwards and add them?
also see my other questions - I'm mostly there but still struggling with some silly issues.
JRock3x8 is offline
post #45 of 67 Old 08-13-2014, 08:42 AM
Otter0911's Avatar
Quoted: 69 Post(s)
I would just try to add them manually if auto did not find anything. Go to the movie with no info hit on the remote "Options" then hit "Get Content Info" it will then bring a list of movie titles, pick the right one.
On the XML Editor, yes it does multi-backdrops. On the box for backdrops you put the URL of the image from any site you find that you find a pic you want as a backdrop.
post #46 of 67 Old 08-13-2014, 11:24 AM - Thread Starter
JRock3x8's Avatar
Quoted: 647 Post(s)
Liked: 163
I don't think I get that choice when I hit "Options" on a blank movie. I can move, edit, or delete if memory serves.
oh wait do I have to go to settings and choose get content manually first?
JRock3x8 is offline
post #47 of 67 Old 08-13-2014, 12:48 PM
Otter0911's Avatar
Quoted: 69 Post(s)
Turn off auto and go to manual
post #48 of 67 Old 08-13-2014, 07:48 PM - Thread Starter
JRock3x8's Avatar
Quoted: 647 Post(s)
Liked: 163
yah i don't appear to have that option. I have Move Copy Delete Upload to Facebook (?!?) and Select Multiple
JRock3x8 is offline
post #49 of 67 Old 08-14-2014, 07:15 PM - Thread Starter
JRock3x8's Avatar
Quoted: 647 Post(s)
Liked: 163
double checked that manual was flipped - still not getting that option in the movies list.
looks like this guy (see video) can do it on mochi - not sure what I'm doing wrong in Simple. guess I will try switch then switch back... so frustrating!
also is there a program that can generate thumbs? Planet Earth is a real problem for thumbs because I ripped it chapter by chapter which the movie db doesn't recognize. I have all the jpegs I want to use in the same directory but the wdtv isn't picking them up.
JRock3x8 is offline
post #50 of 67 Old 08-14-2014, 07:24 PM
Otter0911's Avatar
Quoted: 69 Post(s)
Goto "Setup" then to "System" then turn Get Content Info to Manual Only.
Goto Videos pick a movie that does not have info/xml hit "options" then "get content info"
Yes it works on the Simple theme.
post #51 of 67 Old 08-14-2014, 07:33 PM
Otter0911's Avatar
Quoted: 69 Post(s)
For example...
post #52 of 67 Old 08-14-2014, 07:52 PM
Otter0911's Avatar
Quoted: 69 Post(s)
I also did Planet Earth...each episode...write them yourself using XML Editor.
This can be a labor of love
post #53 of 67 Old 08-15-2014, 04:39 AM - Thread Starter
JRock3x8's Avatar
Quoted: 647 Post(s)
Liked: 163
For example...
I'll have to take a video later and post it - mine doesn't look like that.
Does your manual XML editor post metathumbs? At this point that is starting to look like the quicker and easier solve.
finally getting results but with mochi, not simple. Except that backdrops are not populating from the manual XML edited files. I also appear to be running on an older firmware (1.something whereas the latest firmware is 2.something)
this entire process is MADDENING. but I'm making progress...breathe...
JRock3x8 is offline
post #54 of 67 Old 08-15-2014, 06:22 AM
Otter0911's Avatar
Quoted: 69 Post(s)
I don't think your running a older firmware...Let me ask you does your WD have Netflix?
post #55 of 67 Old 08-15-2014, 05:16 PM - Thread Starter
JRock3x8's Avatar
Quoted: 647 Post(s)
Liked: 163
Current Version : 1.16.13
New Version: 2.02.32
yes I have netflix and a whole crap ton of other apps.
also backdrops are not working using the manual xml generator
manual content update is working now.
so it looks like it is ordering the movies based on title and not file name - (maybe?) so how would I reorder Transformers 1 2 3? (Don't judge me - I hate Michael Bay too but damn, giant robots...)
I suppose I could manually update the title in the XML? edit - tested - I can make the update - it does show up on the WDTV and it doesn't change the sorting. Sigh.
JRock3x8 is offline
post #56 of 67 Old 08-15-2014, 07:39 PM
Otter0911's Avatar
Quoted: 69 Post(s)
Whose to judge?! Love Transformers and Pacific Rim!!
I posted this in my screenshot thread...
For the "The" in titles, myself, I just leave it on most titles. But you can trick the WD. What I do is write my own XML using this program...http://www.frillen.dk/apps/xml-editor/. I name the movie "Deep" then I use XML Editor and put the title as "The Deep". It will put the movie in the "D" but will show title as "The". I did that for the Star Wars movies, I named the movies (MKVs) as Star Wars 01, Star Wars 02, and Star Wars 03. They Display as Star Wars, The Empire Strikes Back and Return of the Jedi. Simple trick.
To get Backdrops to work in XML Editor you have to put the URL for the image in box for Backdrops. For example,
If you want this as your backdrop...
Go to themoviedb.org go to the backdrop images cut/paste the URL from the site...http://image.tmdb.org/t/p/original/d...NoCpsCngwW.jpg and paste it into the Backdrop Box.
post #57 of 67 Old 08-16-2014, 04:29 AM - Thread Starter
JRock3x8's Avatar
Quoted: 647 Post(s)
Liked: 163
Mine is not working this way for whatever reason - For example, I have my files names Star Trek 07 Generations, 08 First Contact, 09 Insurrection, 10 Nemesis, 11 but they are ordered by Title - Star Trek 11, Generations, Insurrection, First Contact, Nemesis.
JRock3x8 is offline
post #58 of 67 Old 08-16-2014, 05:54 AM
Otter0911's Avatar
Quoted: 69 Post(s)
I know this is a pain but try it like this...Delete them...Write the XML on your computer first...then reload them onto the WD.
post #59 of 67 Old 08-16-2014, 11:56 AM
Brian Hampton's Avatar
Quoted: 572 Post(s)
Liked: 302
I haven't been here but gosh Otter ... thanks for all this info.
For the moment, I'm happy with just having my files have thumbnails but those tricks you mentioned for titles with "the" or naming the star wars movies are fantastic.
So, ... thanks,... I'm taking it slow and for the moment the simple theme and just thumbnails ... I'm easily pleased I guess... Though, I'm sure I will love to dig deeper in time and make many of the tweaks you detailed here.
-Brian
Brian Hampton is offline
post #60 of 67 Old 08-16-2014, 02:24 PM - Thread Starter
JRock3x8's Avatar
Quoted: 647 Post(s)
Liked: 163
I am having no luck with the manual xml editor. Backdrops wont show up.
figured out the manual sort - just needed to rescan the library.
I think I'm pretty good at this point.
JRock3x8 is offline
