Networking Experts Double Router Question - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 08-20-2014, 06:07 PM - Thread Starter
funhouse69's Avatar
Quoted: 484 Post(s)
Liked: 154
I have a friend of mine that has FIOS and is using their Wireless for their wireless devices, he also has a Netgear Firewall behind the FIOS Router and has recently started using Plex. I was able to get plex working outside of his network but can't get it working inside the network with the wireless devices.
I understand that this is a Double Router Setup and have Port Forwarding set up on the FIOS Router to the WAN IP of the Netgear Firewall and the Netgear Firewall forwarding the same port to the Plex Server on the Internal Network.
Any thoughts on what I am missing?
funhouse69 is offline
post #2 of 8 Old 08-20-2014, 06:45 PM
LexInVA's Avatar
Quoted: 661 Post(s)
Liked: 269
Sounds like wireless isolation might be enabled on the gateway though I don't know the specifics of your friend's FIOS hardware as there are different gateways used by FIOS, including many older models that are no longer supported but still in use. Anyway, your friend should only be using one configuration: FIOS gateway in Bridge Mode with the Netgear WiFi router connecting all wireless and wired devices.
LexInVA is offline
post #3 of 8 Old 08-20-2014, 07:00 PM - Thread Starter
funhouse69's Avatar
Quoted: 484 Post(s)
Liked: 154
He has one of the newer Routers that supports Wireless N, the Netgear is a Firewall only / does not have any wireless which is why he is using the Verizon Wireless.
I just looked through my router which I believe is the same and I don't see anything Wireless Isolation Setting. I am NOT using the Wireless on my Actiontec Router just using it as a point of reference.
post #4 of 8 Old 08-20-2014, 09:22 PM
jimbo75's Avatar
So with the wireless client, are you trying to reach Plex by using the WAN IP of the Firewall?
Is it possible to turn off NAT on the firewall and just route?
jimbo75 is offline
post #5 of 8 Old 08-20-2014, 09:28 PM - Thread Starter
funhouse69's Avatar
Quoted: 484 Post(s)
Liked: 154
Yes the wireless clients are getting their IP from the FIOS Router, the firewall is LAN is an internal / non-routeable address 10.x.x.x.
My friend isn't very technical, I set up the firewall / VPN Connections (which is why he has the firewall in the first place) for him and just needs it to work without a whole lot of trouble.
There has to be a way to get it to work
post #6 of 8 Old 08-21-2014, 04:57 AM
tdallen's Avatar
Quoted: 197 Post(s)
Liked: 64
Faced with a similar issue, I had Comcast configure their router in bridge mode - essentially turning their device back into a modem. All wired and wireless routing/switching duties are now back on my router, where they belong. You might want to see if Verizon can do something similar.
tdallen is offline
post #7 of 8 Old 08-21-2014, 07:32 AM
LexInVA's Avatar
Quoted: 661 Post(s)
Liked: 269
You ditch the useless firewall and replace it with a high-end WiFi router while using the FIOS gateway in bridge mode. Takes about five minutes to configure and it works far better than the current arrangement.
LexInVA is offline
post #8 of 8 Old 08-22-2014, 09:10 AM
jimbo75's Avatar
It seems like you are running into the reasons why everyone will always say not to double NAT.
Having said that, if you are still troubleshooting, I'd start with seeing if wireless clients can communicate with the firewall WAN IP. Not sure if your firewall allows pings on the WAN IP, or if you can hit a config webpage from the WAN IP... but I'd start there. If the Verizon modem isn't blocking client to client communication, maybe there is something on the firewall that is blocking traffic?
jimbo75 is offline
