Netflix DD Plus only works on TV with xbox 360 but not Roku 3? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 08-24-2014, 11:25 AM - Thread Starter
Dr.Evazan's Avatar
Quoted: 58 Post(s)
Liked: 71
Here's my setup...
Roku 3 HDMI, Xbox 360 slim HDMI > Insignia TV (NS 39D400NA14WYW) > Optical audio out > Logitec Z5500 (soon to be Yamaha RX-V630)
Both have the option in Netflix to use Dolby digital plus 5.1, however my insignia TV only recognizes Netflix surround sound audio from my xbox (I have xbox set to dolby surround sound) and not from my Roku? When the Roku is set to DDP the tv has no sound and does not recognize the format, so the logitec's dont get any signal either via the optical out. What is the Xbox doing to the audio stream that the Roku isn't?
My hypothesis is this, the Insignia TV doesn't recognize DDP but the Xbox is converting the DDP to another DD format that the TV does recognize, where as the Roku just sends straight DDP.
I would really like to use the Roku 3 for Netflix because i think it has a nicer interface and better PQ.
And yes i've looked around the web and can't find anything.
Any help/suggestions is much appreciated.
Dr.Evazan is offline
post #2 of 9 Old 08-25-2014, 08:18 AM
Mr.G's Avatar
Quoted: 767 Post(s)
Liked: 442
Originally Posted by Dr.Evazan View Post
Here's my setup...
The Roku 3 does not process Netflix DD+ it just passes the audio stream straight to the decoding device via HDMI when set to Surround Sound mode.
Your Insignia TV should be set to RAW so that the original stream is sent to the Logitech to decode DD+...assuming it has that capability.
All I Really Need to Know I Learned in Kindergarten Movies
Mr.G is offline
post #3 of 9 Old 08-25-2014, 08:53 PM - Thread Starter
Dr.Evazan's Avatar
Quoted: 58 Post(s)
Liked: 71
Well that's the thing, i have it in raw and it passes through the xbox's surround sound but not the roku's
post #4 of 9 Old 08-26-2014, 07:37 AM
EVT
EVT's Avatar
Quoted: 46 Post(s)
Liked: 25
I believe the reason for this discrepancy is that the XBOX 360 does not output DD+ rather it outputs garden variety Dolby Digital which your TV can accept. I can't think of any TV's off hand that can pass along or process advanced formats like DD+ or DTS-HD, or DD True HD.
EVT is offline
post #5 of 9 Old 08-26-2014, 09:52 AM
Mr.G's Avatar
Quoted: 767 Post(s)
Liked: 442
As mentioned by EVT the Insignia will not pass through the original DD+ audio stream, I was thinking maybe it would re-encode the audio stream to regular Dolby Digital 5.1 but that's not the case here. The Logitech cannot handle DD+ even if it were passed through untouched. And as you know the Xbox outputs regular Dolby Digital 5.1 which your TV and Logitech have no problem with.
In your particular case the Apple TV 3 would have been the better choice for your system and Netflix since it has an optical output in addition to HDMI. You would have to mute the TV since the sound is output through both optical and HDMI at the same time. The ATV3 outputs DD 5.1 but not DD+.
Other solutions are to purchase a re-encoder device (usually over $100) to take the Netflix DD+ and output regular DD 5.1.
The best solution of course is to purchase a new receiver with HDMI and DD+ capability.
Mr.G is offline
post #6 of 9 Old 08-27-2014, 10:25 AM - Thread Starter
Dr.Evazan's Avatar
Quoted: 58 Post(s)
Liked: 71
Thanks EVT and Mr.G. That's the answer i was looking for, which is the xbox in fact does not output DD+
Thanks for the help
post #7 of 9 Old 03-19-2015, 02:10 PM
4DHD's Avatar
Quoted: 205 Post(s)
Liked: 114
I have an AVR with HDMI & DD Plus capable. And Apple TV.
On some streams the AVR shows DD 3/2.1 EX-off, other times just DD.
According to the AVR manual, DD EX can be manually turned on, even if an EX stream is not there. But nowhere does it tell you how to turn on the EX.
Going into the audio mode menu, it never shows the EX option.
Custom, one of a kind pair, MJC212 mains, mod PT800 center, PT800 surrounds, SUB1500s. Parasound P7, Citation 19, Parasound HCA2205A, HK AVR3600, Marantz TT, Samsung BD player, Denon DVD-A player, MacBook Pro w/ Dirac Stereo Suite.
4DHD is offline
post #8 of 9 Old 03-20-2015, 07:31 AM
Mr.G's Avatar
Quoted: 767 Post(s)
Liked: 442
This would be better addressed in the Receivers, Amps and Processors forum, naming your specific receiver.
http://www.avsforum.com/forum/90-rec...ps-processors/
Mr.G is offline
post #9 of 9 Old 03-20-2015, 09:05 AM
4DHD's Avatar
Quoted: 205 Post(s)
Liked: 114
Actually, I posted there first. In the HK AVR3600 thread.
4DHD is offline
