Roku XS Problems - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 08-30-2014, 02:26 PM - Thread Starter
kpr711's Avatar
Roku XS Problems
I have a rokus XS, connected via Ethernet (switch to router xfinity)
Recently the connection speed a dramatically dropped off. It does not appear to be the ethernet or network, I can disconnect the ethernet from the roku and connect to Xbox one, I get 28-30 mbs. But on the roku is is dreadfully slow.
Tried trouble shooting with Roku, no avail. Everything points to the Roku. About three months ago I had a lighting strike that blew my av receiver. Could that have caused the issue with the Roku.
Just to be clear, the Roku works, just verrrry sloooooowly.
Thank you all in advance.
kpr711 is offline
post #2 of 4 Old 08-30-2014, 02:37 PM
bac522's Avatar
Quoted: 177 Post(s)
Liked: 100
Most likely the problem...only thing I would suggest is doing a factory reset on the box and see if that clears it up.
bac522 is offline
post #3 of 4 Old 08-30-2014, 03:39 PM - Thread Starter
kpr711's Avatar
Nope, that did not work
kpr711 is offline
post #4 of 4 Old 08-31-2014, 06:17 AM
bac522's Avatar
Quoted: 177 Post(s)
Liked: 100
Bummer, my guess (and you probably suspect) is that the unit is slowly "giving up the ghost". Only other thing I can suggest is posting this problem on the Roku forum and see if any of the guru's over there can help.
bac522 is offline
