Sports Streams - Best MadVR settings? - AVS Forum
Old 11-17-2014, 06:22 PM - Thread Starter
Advanced-'s Avatar
Liked: 0
I am paying for HockeyStreams and BallStreams and they work great with KCP (Kawaii Codec Pack) Which has the following:
MPC-HC 1.7.7
madVR v0.87.10
LAVFilters-0.63 x86
XySubFilter 3.1.0.697 Beta 2
ReClock v1.8.8.4
With it running on high: Bicubic, 75 (AR) - Lanczos, 3 taps (AR) - Catmull-Rom (AR)
Bitrate will be either 800 Kbps or 3200 Kbps depending on who else is using the internet with 60 fps. Are the settings above just fine as they are? Or should I use something else to do this? I notice a lot of "clear blocks" over fast moving objects. Not sure if that can be improved or that's just how the streams are run.
Specs: i7-4710HQ, Intel HD 4600, 8 GB DDR3 1600 Ram.
Enjoy life while you can, because there really isn't as much time as you think :)
Advanced- is offline
