NVIDIA Shield (Android TV set-top box) - Page 121 - AVS Forum | Home Theater Discussions And Reviews
 1501Likes
post #3601 of 4285 Old 08-21-2017, 05:51 PM
Quoted: 163 Post(s)
Liked: 57
Originally Posted by gadgtfreek View Post
Just ordered a shield to go with my 940E. Figure if I add a 203 for Dolby vision with the update, I need something reliable for streaming and the 940 Amazon app is not great.
I had a gen one, is it still the recommendation to set it to 59.94hz and 4.2.0 10 bit using Netflix and Amazon 1080p and 2160p + HDR?
Yes those are the correct settings but to be clear the Shield hasn't announced one way or another if they will be supporting DV.
Mike
Sony XBR-65X930E | Nvidia Shield TV Pro 2017 | Logitech Harmony Elite
m_snow is offline
post #3602 of 4285 Old 08-21-2017, 05:55 PM
Quoted: 163 Post(s)
Liked: 57
Originally Posted by maddog510 View Post
There is no 10 bit option. Only 8 bit & 12 bit.
Sent from my LG-LS997 using Tapatalk
That's not correct. Here's a screenshot.
Mike
m_snow is offline
post #3603 of 4285 Old 08-21-2017, 05:55 PM
maddog510's Avatar
Quoted: 336 Post(s)
Liked: 84
Originally Posted by cmdrdredd View Post
Yes there is. At 60hz you can set 10bit 4:2:0 and on my tv it is the only option that does not cause banding on Netflix and Amazon hdr content.
The banding I experience is tv specific.
I don't have all of those options. I just have 4 options when i select 1080P & none of them are 10 bit.
maddog510 is online now
post #3604 of 4285 Old 08-21-2017, 05:55 PM
gadgtfreek's Avatar
Quoted: 634 Post(s)
Liked: 4065
Yeah, not too worried about DV streaming at the moment, but would like to try them on disc one Sony puts out the update.
Does the Shield do Netflix and Amazon 24hz if you set it to 24hz? One thing I like about the Sony X800, it outputs streaming as 2160p/24.
gadgtfreek is offline
post #3605 of 4285 Old 08-21-2017, 05:56 PM
psuKinger's Avatar
Quoted: 1036 Post(s)
Liked: 353
I'm probably the last guy on the forums to notice this, but I don't watch GoTS, so I didn't notice it until tonight... But the HBO Now app on Shield now supports DD 5.1. this is fantastic news, for me at least.
psuKinger is offline
post #3606 of 4285 Old 08-21-2017, 05:58 PM
maddog510's Avatar
Quoted: 336 Post(s)
Liked: 84
Here are my options when I select 1080P
post #3607 of 4285 Old 08-21-2017, 06:05 PM
gadgtfreek's Avatar
Quoted: 634 Post(s)
Liked: 4065
I started subbing to the premiums like Starz and HBO thru Amazon prime, PQ is the best I have found too and I get DD on my other devices.
My Shield should be here tomorrow.
post #3608 of 4285 Old 08-21-2017, 06:10 PM
Quoted: 163 Post(s)
Liked: 57
These are 4K settings for our 4K TV's. Help me understand why you setup your Shield/Sony combo at 1080p?
Mike
m_snow is offline
post #3609 of 4285 Old 08-21-2017, 06:12 PM
maddog510's Avatar
Quoted: 336 Post(s)
Liked: 84
Because I want the tv doing the upscaling of non 4K. Not the shield. When I watch 4K content then that's when I switch the resolution over to 4K.
post #3610 of 4285 Old 08-21-2017, 06:19 PM
Quoted: 163 Post(s)
Liked: 57
Yes, Netflix and Amazon support 4K at 59.940Hz, 60Hz, 50Hz, 23.975Hz and 1080p at 59.940Hz.
Mike
m_snow is offline
post #3611 of 4285 Old 08-21-2017, 06:22 PM
Quoted: 163 Post(s)
Liked: 57
Allright. if you set yours to 4K you'll see the same options I have.
Mike
m_snow is offline
post #3612 of 4285 Old 08-21-2017, 06:24 PM
maddog510's Avatar
Quoted: 336 Post(s)
Liked: 84
I don't have a 60HZ option for 1080P. It says 59. something.
post #3613 of 4285 Old 08-21-2017, 08:04 PM
psuKinger's Avatar
Liked: 353
I don't really care for the Prime app (at least not on Shield, which is basically the only thing I use). It's fine I guess. I do use it for Showtime, as it's $2 less per month than just doing the Showtime app directly thru the Play Store.
But when HBO costs the same regardless, I prefer the HBO Now interface over the Amazon app..
JMO.
post #3614 of 4285 Old 08-21-2017, 08:10 PM
cmdrdredd's Avatar
Quoted: 2892 Post(s)
Liked: 2850
You can't tell me you see any difference if you just leave the shield at 4k. Having to remember to go into the menu all the time and change it is super annoying.
shoman94 likes this.
Samsung 55JS9000, Denon AVR-X2200w 5.1.2, PS4 Pro, Gaming PC(SLI 970s), Philips BDP7501 UHD Player, Nvidia Shield TV
2x Elac F5/Elac C5/2x AR PS2052/2x Pioneer SP-T22A-LR/Power Sound Audio 15v w/ Anti-Mode 8033S-II
cmdrdredd is offline
post #3615 of 4285 Old 08-21-2017, 08:12 PM
maddog510's Avatar
Quoted: 336 Post(s)
Liked: 84
Then stop using 1080p
No I'm not going to do that. My Sony 930E has far superior upscaling capabilities than the Shield. 1080P looks crystal clear when the Sony handles the upscaling.
post #3616 of 4285 Old 08-21-2017, 08:13 PM
cmdrdredd's Avatar
Liked: 2850
Placebo effect. Samsung is supposed to have great scaling too but guess what? There's no perceptible difference.
Ken Ross and Snoogleheimer like this.
post #3617 of 4285 Old 08-21-2017, 08:14 PM
maddog510's Avatar
Quoted: 336 Post(s)
Liked: 84
No placebo effect going on over here. I've compared both. The Sony does a better job.
MCaugusto likes this.
post #3618 of 4285 Old 08-22-2017, 06:47 AM
lovingdvd's Avatar
Quoted: 2862 Post(s)
Liked: 608
Is the shield the best player for streaming 4K in *HDR*. I primarily only care about streaming Netflix, Amazon Prime Video in HDR which it looks like it will do. But it does not appear to do HDR for VUDU according to the company's web page. Its also $200 compared to the Google Chromecast Ultra which is only $70. Are there any benefits for the Shield that make it worth the extra $$ compare to the Ultra (assuming the Ultra can do HDR for Netflix and Amazon)? For instance can the Shield (or Ultra) do 4k24 for these services (instead of 4k60)? I have a Roku Ultra but want to replace it due to problems with it and the Roku service. Thanks!
lovingdvd is offline
post #3619 of 4285 Old 08-22-2017, 06:51 AM
gadgtfreek's Avatar
Quoted: 634 Post(s)
Liked: 4065
It was said above it will do 24hz for Amazon and Netflix. I really only use those services, so I was thinking about just setting it to 2160/24 output and leaving it be.
post #3620 of 4285 Old 08-22-2017, 08:18 AM
cuibap's Avatar
Quoted: 27 Post(s)
I just bought the Shield on the weekend and tried to move the Plex server from my desktop computer to Shield. One thing I can't make it work is enable remote access. I was able to do that with my old set up on the pc. No double NAT and both have static IP address. This is Shield TV 16GB 2017 version. Can you help?
Sent from my SM-G935T using Tapatalk
cuibap is offline
post #3621 of 4285 Old 08-22-2017, 08:24 AM
atc98092's Avatar
Location: Washington (the state) temporarily in Chantilly VA
Quoted: 821 Post(s)
Liked: 321
Perhaps Plex on the Shield uses a different port? Or maybe go into Plex and set a port manually and use that port number when enabling port forwarding on your router.
Dan
Samsung JU7100 4K TV, Yamaha RX-V679, Windows 10 home media server with Serviio and Plex, 18TB of movies/TV shows. Other players and TVs as well.
atc98092 is offline
post #3622 of 4285 Old 08-22-2017, 08:49 AM
cuibap's Avatar
Quoted: 27 Post(s)
Thanks. Forgot about the port number. Will check it tonight
cuibap is offline
post #3623 of 4285 Old 08-22-2017, 09:31 AM
bryansj's Avatar
Quoted: 1424 Post(s)
Liked: 646
Change the port forwarding to point from the old server IP address to the Shield's IP address.
bryansj is offline
post #3624 of 4285 Old 08-22-2017, 10:03 AM
lovingdvd's Avatar
Liked: 608
I understand from a friend that Netflix on the Shield will NOT do HDR at 4K/24, and that you must use 4K/60 for Netflix HDR. Is that the case for everyone or might that be specific to his setup (cabling issue etc)? Can it do Amazon HDR at 4K/24? Can the Shield do Vudu in HDR and if so at what frame rate?
With the right display and HDMI cables, does the Shield *reliably* play back Netflix and Amazon in 4K HDR?
post #3625 of 4285 Old 08-22-2017, 10:10 AM
groove93's Avatar
Quoted: 364 Post(s)
Liked: 176
Not sure how similar your display is to the 900e that I have, but be sure your HDMI settings are set to "Enhanced Mode", and use Ports 2 or 3 for these settings. Ensure that your Display is outputting 4K, and the same for the Shield.
This will allow for HDR rather than just Ultra 4K to appear in some titles via Netflix as well.
Sony XBR55X900E
Marantz SR7010/Marantz MM7025
Oppo UDP-203 - Nvidia Shield
Klipsch RP-260f - RP-440C - RP140sa- RP-160m - RB10 - Sony SA-WM500
groove93 is offline
post #3626 of 4285 Old 08-22-2017, 10:15 AM
groove93's Avatar
Quoted: 364 Post(s)
Liked: 176
Does Plex not direct play anymore? They changed the setting & only allows maximum for streaming audio & video. I have both of these options selected but then it shows it's transcoding & it's showing direct stream for both audio & video.
There was an update that for some reason defaulted the streaming settings to an "Automatic" setting. I downgraded to an earlier version of Plex, and this fixed my streaming issues. The current version, brought back the ability to "Direct Play" your files.
Check over at the Plex forums for information regarding this issue.
Sony XBR55X900E
groove93 is offline
post #3627 of 4285 Old 08-22-2017, 02:16 PM
gadgtfreek's Avatar
Quoted: 634 Post(s)
Liked: 4065
Got the little guy installed in the home theater, and dang this FW download for 5.2 is terrible, slow as molasses. ATT gigabit connection too.
post #3628 of 4285 Old 08-22-2017, 02:28 PM
gadgtfreek's Avatar
Quoted: 634 Post(s)
Liked: 4065
15 mins in and 250 mb's out of 1.13 gigs. Gonna take an hour!
post #3629 of 4285 Old 08-22-2017, 04:11 PM
bryansj's Avatar
Liked: 646
None of my updates have been that slow. Maybe restart the Shield and try again. Are you connected to you LAN with gigabit Ethernet?
bryansj is offline
post #3630 of 4285 Old 08-22-2017, 04:22 PM
gadgtfreek's Avatar
Quoted: 634 Post(s)
Liked: 4065
It took an hour and a half LOL, 5ghz radio on gigabit modem.
Anyways, it finally finished and speeds on Amazon and Netflix are smoking. Netflix app speed test reported back at 233mbps, and the ultra HD test video hit 16,000 about as expected time wise. Amazon got UltraHD HDR quick, and it moves thru the apps quickly as well.
I left it on recommended settings of 4K 59.94 and ycbcr 420 10 bit 2020, and PQ is great on my Sony X940E. Works about as fluid on those apps as my X800, and I get HDR Amazon! HDR Netflix checked out OK too.
