NVIDIA Shield (Android TV set-top box) - Page 122 - AVS Forum | Home Theater Discussions And Reviews
 1502Likes
post #3631 of 4288 Old 08-22-2017, 05:34 PM
K_Thompson's Avatar
Quoted: 123 Post(s)
Liked: 43
Originally Posted by cuibap View Post
I just bought the Shield on the weekend and tried to move the Plex server from my desktop computer to Shield. One thing I can't make it work is enable remote access. I was able to do that with my old set up on the pc. No double NAT and both have static IP address. This is Shield TV 16GB 2017 version. Can you help?
Sent from my SM-G935T using Tapatalk
I was under the impression from previous conversations that it isn't a good idea to use the 16GB version of the Shield as a Plex server due to the server software only being able to use internal memory to store the metadata. That 16GB would be used up pretty quickly if you have a large media collection.
K_Thompson is offline
post #3632 of 4288 Old 08-22-2017, 05:37 PM
Quoted: 163 Post(s)
Liked: 57
Originally Posted by gadgtfreek View Post
It took an hour and a half LOL, 5ghz radio on gigabit modem.
Anyways, it finally finished and speeds on Amazon and Netflix are smoking. Netflix app speed test reported back at 233mbps, and the ultra HD test video hit 16,000 about as expected time wise. Amazon got UltraHD HDR quick, and it moves thru the apps quickly as well.
I left it on recommended settings of 4K 59.94 and ycbcr 420 10 bit 2020, and PQ is great on my Sony X940E. Works about as fluid on those apps as my X800, and I get HDR Amazon! HDR Netflix checked out OK too.
Just so I understand, this is the same 5.2 that we all got a few months ago right? Just want to make sure I'm not missing out
Mike
Sony XBR-65X930E | Nvidia Shield TV Pro 2017 | Logitech Harmony Elite
m_snow is offline
post #3633 of 4288 Old 08-22-2017, 05:41 PM
Quoted: 163 Post(s)
Liked: 57
Works for me although I prefer Kodi to Plex as a media server. I've tried it both on the internal HD and a USB, no problem with either.
Mike
m_snow is offline
post #3634 of 4288 Old 08-22-2017, 05:52 PM
gadgtfreek's Avatar
Quoted: 634 Post(s)
Liked: 4068
Yeah, it was 5.2.
m_snow likes this.
gadgtfreek is offline
post #3635 of 4288 Old 08-22-2017, 07:26 PM
bryansj's Avatar
Quoted: 1425 Post(s)
Liked: 647
Kodi isn't a media server. It is a player.
bryansj is offline
post #3636 of 4288 Old 08-22-2017, 08:13 PM
mariob33's Avatar
Quoted: 95 Post(s)
Liked: 76
Send a message via Skype™ to mariob33
it does have the ability to share content/library from a config and if you use the mysql also trak watch states cross device. I would call it a hybrid..
m_snow likes this.
In search of video bliss...
mariob33 is offline
post #3637 of 4288 Old 08-23-2017, 04:05 AM
Quoted: 163 Post(s)
Liked: 57
They both have Player components and Kodi can play HDR and other high bitrate high frame rate formats that Plex can't.
Additionally, Kodi has the ability to run off shared storage and can be configured as SMB. If you are somewhat technical it's better all in all to serve content that Plex can't. That said, I agree Plex is, out of the box, easier to get up and running.
Also, I misread the point about the 16G version. Mine is 500G with extra storage so my experience is different.
bigapp likes this.
Mike
m_snow is offline
post #3638 of 4288 Old 08-23-2017, 04:50 AM
bryansj's Avatar
Liked: 647
Yes, but it isn't a media server. Plex Server is set up and you point the Plex clients (or Kodi) to it. All metadata is as it exists on the server. With Kodi you have to set up each instance to point to your libraries. Plex client and Kodi are players unless you hack together what was mentioned above. There is no Kodi Server.
bryansj is offline
post #3639 of 4288 Old 08-23-2017, 10:45 AM
Liked: 4
Originally Posted by lovingdvd View Post
I understand from a friend that Netflix on the Shield will NOT do HDR at 4K/24, and that you must use 4K/60 for Netflix HDR. Is that the case for everyone or might that be specific to his setup (cabling issue etc)? Can it do Amazon HDR at 4K/24? Can the Shield do Vudu in HDR and if so at what frame rate?
With the right display and HDMI cables, does the Shield *reliably* play back Netflix and Amazon in 4K HDR?
Your friend told you the right thing. Netflix on the Shield don't support 4K resolution at 24Hz for either HDR Ultra HD or SDR Ultra HD.
If you set your Shield to 4K/24Hz it shrinks from Ultra HD to 1080p and doesn't go further. This is a known bug since the first nougat update.
Amazon HDR and SDR Ultra HD works at 4K/24Hz. About Vudu I can't tell you any.
B1tK1t is offline
post #3640 of 4288 Old 08-23-2017, 02:15 PM
Poolshark69's Avatar
Quoted: 57 Post(s)
Liked: 58
Anyone in Canada that can tell me if Crave TV and TMNGo work on the Shield? I am on the fence about ordering one to replace my Roku for a PlexClient and Netflix.
Gamertag: Quicksilver1663
Poolshark69 is offline
post #3641 of 4288 Old 08-23-2017, 05:42 PM
archer75's Avatar
Quoted: 364 Post(s)
Liked: 109
4k and 24hz works on mine for netflix. A while back someone said it wasn't working so I switched the shield to 24hz, loaded up netflix and started a movie playing, brought up the info screen and there it was 4k. If I come back to it another time then 4k won't work and I have to reboot to get it back again.
Though I tend to not leave it at 24hz as I don't see any difference.
Streaming Devices: Nvidia Shield TV, 2x Roku 3's, 1st and 2nd gen chromecast, Amazon Fire TV stick 2nd gen, Apple TV 4, xbox 360, xbox one
Displays: Vizio M602i-B3, LG OLED65B6, panasonic ax100u on a 145" S-I-L-V-E-R painted screen, 40" Samsung(don't recall model #)
Receivers: Denon X3300, Yamaha RX-V663. Bluray/UHD player: Oppo UDP-203
Retired - HTPC: Intel e6300 2.8ghz, Intel DG45ID, 2gb DDR2, Radeon 5570, MCE IR receiver
archer75 is offline
post #3642 of 4288 Old 08-23-2017, 10:56 PM
Liked: 4
Reboot the Shield, change it to 4K/23.976Hz 12-bit YCbCr 4:2:2 Rec.2020 before launching Netflix for the first time, then all Ultra HD logos are gone and the streaming resolution will be limited to 1080p. It's another problem that the Netflix app somehow remembers the refresh rate when it's first launched, therefor a reboot is needed to properly test this. A force close of Netflix might help aswell.
B1tK1t is offline
post #3643 of 4288 Old 08-24-2017, 04:55 AM
gadgtfreek's Avatar
Quoted: 634 Post(s)
Liked: 4068
After a couple of days use on different content, I'm happy with the Shield set on the "recommended" settings for video with my 940E, just going to leave it alone. When I fire it up at night after work to watch content, I just want to click a couple of buttons and relax.
I can see a slight difference in motion vs the X800 Sony, but its fine, and the PQ is good on the 75".
psuKinger likes this.
post #3644 of 4288 Old 08-24-2017, 05:00 AM
cmdrdredd's Avatar
Quoted: 2894 Post(s)
Liked: 2860
Some tvs can't do a judder free 60hz and that's where the benefit is. Your tv may be fine or you just don't notice.
Samsung 55JS9000, Denon AVR-X2200w 5.1.2, PS4 Pro, Gaming PC(SLI 970s), Philips BDP7501 UHD Player, Nvidia Shield TV
2x Elac F5/Elac C5/2x AR PS2052/2x Pioneer SP-T22A-LR/Power Sound Audio 15v w/ Anti-Mode 8033S-II
cmdrdredd is offline
post #3645 of 4288 Old 08-24-2017, 09:14 AM
psuKinger's Avatar
Quoted: 1036 Post(s)
Liked: 353
Does anybody use the Showtime app on Shield (rather than the Showtime channel thru the Amazon Instant Video app)? If so, does it stream with DD 5.1?
themystical likes this.
psuKinger is offline
post #3646 of 4288 Old 08-24-2017, 11:36 AM
chanc's Avatar
Quoted: 28 Post(s)
I so got my new shield and installed Kodi Krypton 17.4 from the Play Store. Tried for 2 days now,set it up with my Freenas movies and Kodi Shield cannot connect to The Movie Database server. I am really frustrated. Anybody else has a solution? With Kodi 17.3 with the Sony 940 E Kodi had no problem.
bigapp likes this.
Sony XBR75X940E, Onkyo TX-RZ800, Klipsch speakers, SVS subwoofer, Tivo Roamio
chanc is offline
post #3647 of 4288 Old 08-24-2017, 02:09 PM
maddog510's Avatar
Quoted: 336 Post(s)
Liked: 84
Looks like the latest version of Plex is back to direct playing movie files.
Sent from my LG-LS997 using Tapatalk
maddog510 is offline
post #3648 of 4288 Old 08-24-2017, 04:03 PM
Quoted: 163 Post(s)
Liked: 57
Wow, and for the first time for me it's playing some HDR videos. Cool!!
Mike
m_snow is offline
post #3649 of 4288 Old 08-24-2017, 04:08 PM
K-Wood's Avatar
Quoted: 16 Post(s)
How do we ensure we have the latest version of Plex on our Shield?
K-Wood is offline
post #3650 of 4288 Old 08-24-2017, 04:15 PM
Quoted: 163 Post(s)
Liked: 57
Google Playstore.
Mike
m_snow is offline
post #3651 of 4288 Old 08-24-2017, 05:14 PM
gadgtfreek's Avatar
Quoted: 634 Post(s)
Liked: 4068
Yeah, I don't use Plex but I generally go into play, see if there are updates, and then reboot before using. I downloaded the Plex update.
post #3652 of 4288 Old 08-24-2017, 05:24 PM
jbn008's Avatar
Quoted: 122 Post(s)
Liked: 57
I'm sure someone has mentioned this before, but the official Plex add-on in Kodi (specifically SPMC for me) has been the answer to my Plex wishes. For starters the GUI is much better than the official Plex app on the shield (my preference of course).
It uses Kodi's player, which is superior in my opinion.
-direct play
-hvec x265 4k playback
-23.976fps
-2160p GUI (specific to SPMC)
-better 4k scaling using Lanczos3 - optimised (SPMC specific)
-audio delay
-HD audio including Atmos
Just thought I'd share my experience since it hits all the marks I was looking for in a Plex client.
Headless Petie
jbn008 is offline
post #3653 of 4288 Old 08-24-2017, 05:29 PM
Quoted: 163 Post(s)
Liked: 57
-direct play
-23.976fps
-audio delay
I have both SPMC and Kodi. Dumb question - why do you prefer the 23.976 fps for example instead of higher frame rates and Hz? I don't have a Plexpass so I had to use the PlexConnect addon and I didn't really like it. I assume you're using the regular Plex addon for Kodi/SPMC with a Plexpass right?
Mike
m_snow is offline
post #3654 of 4288 Old 08-24-2017, 05:51 PM
gadgtfreek's Avatar
Quoted: 634 Post(s)
Liked: 4068
Is there any benefit to running Kodi or any of these other apps for someone who just uses Netflix and Amazon?
post #3655 of 4288 Old 08-24-2017, 05:53 PM
jbn008's Avatar
Quoted: 122 Post(s)
Liked: 57
I do have a plex pass, but I believe it?s now available for free as well (minus a few features). I tried plexkodiconnect as well and didnt like it either. As for 24fps, it?s just a preference I prefer, but at least it?s an option (unlike on the Roku, Xbox, Appletv, etc..
m_snow likes this.
jbn008 is offline
post #3656 of 4288 Old 08-24-2017, 06:04 PM
bryansj's Avatar
Liked: 647
Nope.
bryansj is offline
post #3657 of 4288 Old 08-24-2017, 06:08 PM
gadgtfreek's Avatar
Quoted: 634 Post(s)
Liked: 4068
Nope.
OK, I assumed they were for other types of file playback and services, but was wondering.
post #3658 of 4288 Old 08-24-2017, 08:10 PM
psuKinger's Avatar
Liked: 353
They're for "local media".
I rip my Blu Ray collection (losslessly). On Shield, Plex and Kodi (and SPMC) play those files back, and they look (and sound; shield can bitstream the lossless audio track that is included in Blu Rays and nowhere to be found on Netflix/Amazon/Vudu etc) like I have to the disc inserted into my Player. Point-n-click. No getting up off the couch. No menus.
I DVR favorite shows/series/sporting events, edit them for commercials, and play them back this way as well.
I also rip my CD collection losslessly (.flac). Plex supports Google Cast, so it works great with Shield, and integrates well with my whole home audio setup of CCAs.
If you don't do any of those things, you probably have no use for Plex/Kodi...
post #3659 of 4288 Old 08-24-2017, 08:12 PM
Quoted: 178 Post(s)
Liked: 51
How do you rip a Blu-ray collection and how big are the files on average?
ROMIL is online now
post #3660 of 4288 Old 08-24-2017, 08:21 PM
psuKinger's Avatar
Liked: 353
I use MakeMKV. Uncompressed, the files tend to range from 20 - 30 Gigs each.
