NVIDIA Shield (Android TV set-top box) - Page 124 - AVS Forum | Home Theater Discussions And Reviews
 1496Likes
post #3691 of 4255 Old 08-28-2017, 08:22 AM
maddog510's Avatar
Quoted: 335 Post(s)
Liked: 84
Originally Posted by archer75 View Post
You could get better results. Once you figure out your settings you just save it as a profile and you never have to touch them again.
I'll stick with DVDFAB. Like I said the end result comes out pretty good.
Sent from my LG-LS997 using Tapatalk
maddog510 is offline
post #3692 of 4255 Old 08-28-2017, 11:33 AM
blenky's Avatar
Quoted: 428 Post(s)
Liked: 500
Originally Posted by Brian View Post
Ultraflix just added support, so now we've got even more content available. You'll need a mouse connected to complete the login process the first time.
I have registered. How can you find HDR content?
Samsung UE55KS8000 | Yamaha RX-V581 | Dune HD SOLO 4K | Nvidia Shield TV (2017) | Samsung UBD-K8500 UHD Player
blenky is offline
post #3693 of 4255 Old 08-29-2017, 06:23 PM
Robert Simandl's Avatar
Quoted: 232 Post(s)
Liked: 112
I have a 2-3 second audio dropout issue on Amazon and other apps with 5.1 channel surround. I've replaced all cables (HDMI, ethernet, etc) to no effect.
I have the 2015 Shield on ethernet connection (briefly tried wi-fi, didn't help) and HDMI to Yamaha TSR-5810 reciever, then HDMI to TV.
This issue does NOT rear its ugly head with my 2nd-gen Fire TV hooked up the same way to the same receiver and TV. But dammit, I like the Shield better than the FTV otherwise.
Trying to figure out if the problem is in the Shield or the Yamaha.
Bob Simandl ... somewhere near St. Louis
Robert Simandl is offline
post #3694 of 4255 Old 08-29-2017, 07:13 PM
psuKinger's Avatar
Quoted: 1036 Post(s)
Liked: 353
I have five Shields. Four are 2015 models and one is a 2017 model. Two of them are connected to AVRs and three are not. On one of those two AVRs I have a similar problem. I never get any audio dropouts on any of the other four.
It is my opinion that the faulty "set" is the result of a faulty AVR, and NOT the Shield, but I haven't conclusively proven that yet. I intend to upgrade my AVR sometime within the next 6 months (waiting for the Denon x3400h to drop $200-$300 first), at which point I will know for sure....
psuKinger is offline
post #3695 of 4255 Old 08-30-2017, 04:46 AM
psuKinger's Avatar
Liked: 353
Any 4K HDR users on here run their NVidia Shield into and out of an Oppo UDP-203?
Apparently the oppo has one HDMI input (for exactly this purpose) and two HDMI outputs (one HDMI 2.0 port for passing 4K HDR directly to my new 4K HDR TV, and a second HDMI 1.4 port for passing Dolby TrueHD/DTS-HD-MA (and probably Atmos, although I don't do that) to my "old" AVR in parallel)... they basically forsaw this problem and at least *tried* to solve it for me. Which is very cool.
Anyone do this? Does it work well? This seems like a desireable solution to the problem of having an "old" non-HDMI 2.0 non-HDCP-2.2 compliant AVR, relative to the other solutions I had been considering up until I learned about this:
1) Upgrade my AVR *today*, which is costly as I am still hoping for a Dolby Vision firmware update for Shield, I purchased a TV that Sony has publicly promised would be getting a DV firmware update, and as such am only looking to buy a DV compliant AVR "in series" with my Shield-->TV chain, of which their are not many to choose from, and the ones that are tend to be $$$ at the Watts-per-channel I'd want.
2) Connect my Shield directly to the TV, and then come out of the TV via ARC to my AVR, which would give me 4K HDR access for video on Netflix and Amazon, at the expense of losing Dolby TrueHD/DTS-HD-MA support for my 1080p blu ray collection, of which I have invested considerable time and money to cultivate.
3) Run two HDMI cables to the Shield. One from the TV (for ARC) and one from the AVR (for lossless blu ray audio). Then get my lazy arse up off the couch to flip the cable manually whenever I want to switch from Netflix HDR to Plex Blu Ray (thus defeating half the purpose of ripping my blu ray collection by nullifying the point-and-click convenience of locally stored digital media).
4) Try to get an HDMI splitter from somewhere like HDFury (not at all an elegant solution, in my mind, as I'm not sure it will work the way I want (flawlessly) and not as cheap as I'd like it to be to just get a splitter)
5) Try this Oppo 203, which seems to give me all of "benefits" that any of the other 4 options accomplish, *and* a physical media player (which I probably want/need anyway, at least until 4K UHD ripping software becomes available), at a price that isn't *that much more* than an HDFury ripper, and considerably less than a new AVR...
post #3696 of 4255 Old 08-30-2017, 05:03 AM
Quoted: 229 Post(s)
Liked: 479
Originally Posted by psuKinger View Post
Any 4K HDR users on here run their NVidia Shield into and out of an Oppo UDP-203?...
I see you've posted over in the UDP-203 thread, which is what I was going to recommend. Check that thread for discussion on the "HDMI In" capability that you'd be using. While my OPPO has been flawless for me (my Shield runs directly to my AVR, as does my OPPO), others continue to report problems with specific usage of that function, including IIRC intermittent audio drop outs. It's an acknowledged bug OPPO is working on. With dual cables, you may not have a problem, but you want to be very sure you get a straight answer -- not the generic ones of "this is how it's supposed to work". I'm sure others will jump in with more specifics.
psuKinger likes this.
Bert (09-10-2017: I am no longer actively monitoring this thread)
Denon AVR-X4300H | Sony XBR-55A1E OLED | Def Tech 7.2: Mythos 2 *2, Mythos 3, DI 6.5R *4, SC4000 *2 | OPPO UDP-203 | Apple TV 4th Gen | Nvidia Shield TV (16GB 2017) | DirecTV (1080) HR44 & C51 | Panamax M5300-PM | AC Infinity T8 | Logitech Harmony Elite | BJC & Monoprice Cables | CalMAN Home Enthusiast, i1Pro2, C6-HDR2000, Murideo Six-G
BertL is offline
post #3697 of 4255 Old 08-30-2017, 05:14 AM
groove93's Avatar
Quoted: 360 Post(s)
Liked: 175
I did at one time have my Shield installed in the 203's HDMI Input after I installed the beta firmware which allows for HDR through this input. I've been having handshaking issues between the Shield and the 203 and just did not have time to troubleshoot the issue, but HDR does work. Others found within the 203 Thread have had success with this set up.
Sony XBR55X900E
Marantz SR7010/Marantz MM7025
Oppo UDP-203 - Nvidia Shield
Klipsch RP-260f - RP-440C - RP140sa- RP-160m - RB10 - Sony SA-WM500
groove93 is offline
post #3698 of 4255 Old 08-30-2017, 05:14 AM
psuKinger's Avatar
Liked: 353
Thanks. That's EXACTLY the kind of input I'm looking for.
*IF* it works, I could upgrade my AVR (to one that DOESN'T support Dolby Vision) for better Audessey cal, WPC, etc, AND get this OPPO for physical media playback for not much more than it would cost to just get an AVR with the audessey + WPC I want plus Dolby Vision support... it really would be a great avenue to pursue, IMO.
But like you said, if and only if this feature works well....
post #3699 of 4255 Old 08-30-2017, 05:24 AM
Quoted: 229 Post(s)
Liked: 479
Do realize many OPPO owners don't believe DV will ever work with HDMI In... it certainly does not today, and is not stated in the documentation as a supported feature if that is what you're thinking. Lots of opinions, but mine is that most of us on the forum don't know the true licensing and implementation facts related to DV (but that does not stop lots of supposition), and given DV is all about Dolby ensuring consistent content from creation-to-end display, I don't see OPPO or any other mfgr ever opening up some ability that could subvert that one way or another. Time will tell. Just realize, HDMI In may be a good solution for basic 4K (and maybe even HDR), but it likely won't support 100% of what the OPPO can do with other sources it can play.
BertL is offline
post #3700 of 4255 Old 08-30-2017, 05:56 AM
sikclown's Avatar
Quoted: 1505 Post(s)
Liked: 750
I use my Nintendo Switch through my Oppo 203. Different situation because it isn't a 4k device but I am out of ports on my AVR and the Switch only outputs 5.1 PCM so my LG only passes through 2.0 PCM. I have my Oppo connected directly to my LG for Dolby Vision and then a second Audio HDMI running to my AVR. I have not had any audio dropouts or any issues at all using the Switch through the Oppo but again it isn't a 4K device. If I have time later I will try my Shield in place of the Switch and report back.
LG OLED 65C7P, Denon AVR-X7200WA, Apple TV, Oppo UDP-203, PS4, Xbox One
Nvidia Sheild Pro, HTPC, (2) Klipsch RF-82IIs, (4)RS-52IIs,, (1)RP-450CA,
(4) RP-140SA, SVS PB12-Plus, Emotiva XPA-100, XPA-200, Emotiva A-700
UN55KS9000, Denon x4200w, Apple TV, Panny BDT460, HTPC,
Nvidia Shield, Klipsch G-42,(2) R-3650-W-II,(4) RSL-C34E, SVS SB-1000, UPA-200
sikclown is offline
post #3701 of 4255 Old 08-30-2017, 07:02 AM
archer75's Avatar
Quoted: 364 Post(s)
Liked: 107
Dolby Vision support is coming to the Denon 2016/2017 receivers. Confirmed straight from the horses mouth. I picked up the Denon x3300 for less than half price at a deal at frys. Those deals seem to come up from time to time.
Streaming Devices: Nvidia Shield TV, 2x Roku 3's, 1st and 2nd gen chromecast, Amazon Fire TV stick 2nd gen, Apple TV 4, xbox 360, xbox one
Displays: Vizio M602i-B3, LG OLED65B6, panasonic ax100u on a 145" S-I-L-V-E-R painted screen, 40" Samsung(don't recall model #)
Receivers: Denon X3300, Yamaha RX-V663. Bluray/UHD player: Oppo UDP-203
Retired - HTPC: Intel e6300 2.8ghz, Intel DG45ID, 2gb DDR2, Radeon 5570, MCE IR receiver
archer75 is offline
post #3702 of 4255 Old 08-30-2017, 08:05 AM
sikclown's Avatar
Liked: 750
Yup and The X4300 can be had for under 800.00 currently.
sikclown is offline
post #3703 of 4255 Old 08-30-2017, 08:07 AM
psuKinger's Avatar
Liked: 353
Yea that's something else I've considered. The TV I bought doesn't have DV, Sony simply (officially, fwiw) promised that it's coming.
My preferred streamer of choice, Shield, doesn't have DV... I don't think NVidia has ever promised it, officially, although there's lots of speculation (particularly on this forum) that it could/would...
I could just pull the trigger on the a discounted x3300 or x4300 today, and have an HDR10 AVR today (to go along with my HDR10 Shield and HDR10 Sony 940E)... with DV hopefully/perspectively coming to all 3 links in the chain later.
post #3704 of 4255 Old 08-30-2017, 08:17 AM
psuKinger's Avatar
Liked: 353
Wow. Great tip!
I just scored $430 in BB Rewards by opening a rewards card and getting 10% when I bought my 940E... The $1050 list price had me himming and hawing a little bit, but I'll try to have them price-match $800 and upgrade for $370... would be sweet.
post #3705 of 4255 Old 08-30-2017, 08:23 AM
sikclown's Avatar
Liked: 750
Wow. Great tip!
I know for a fact they price match with Crutchfield so check there.
sikclown is offline
post #3706 of 4255 Old 08-30-2017, 08:27 AM
Quoted: 229 Post(s)
Liked: 479
Guys, I'm not a Mod, but just as a reminder since I see this all the time in other threads, don't discuss pricing here or posts may be deleted.
BertL is offline
post #3707 of 4255 Old 08-30-2017, 08:27 AM
sikclown's Avatar
Liked: 750
Good point. I forget that rule sometimes but does it apply to advertised prices?
sikclown is offline
post #3708 of 4255 Old 08-30-2017, 08:58 AM
lujan's Avatar
Quoted: 2764 Post(s)
Liked: 1279
Me too, the last time I checked the Shield while connected to the Oppo 203, I just got a screen with garbled video so I went to another device to watch. I haven't tried since and I'm thinking of switching over to the Roku Ultra to connect to the Oppo to see what I find there?
lujan
234 Ultra HD
780 HD
18 HD DVD
4 SD
lujan is online now
post #3709 of 4255 Old 08-30-2017, 09:01 AM
groove93's Avatar
Quoted: 360 Post(s)
Liked: 175
Remember that you're dealing with Beta Firmware, not an official Release.
Sony XBR55X900E
groove93 is offline
post #3710 of 4255 Old 08-30-2017, 03:03 PM
psuKinger's Avatar
Liked: 353
Hey just wanted to circle back and share a youtube video I just came across:
If you skip ahead to the 4:30 mark, that guy puts his NVidia Shield through the Oppo for the last couple minutes of that video. Shows it boot up. Navigates the menu. Gets into the 4K UHD section of the netflix app and fires one of those up. Looks like it works really well.
..... I am *very* intrigued by this right now.
sikclown and opideegs like this.
post #3711 of 4255 Old 08-30-2017, 06:27 PM
archer75's Avatar
Quoted: 364 Post(s)
Liked: 107
Wow. Great tip!
My x3300 was $470 at frys.
archer75 is offline
post #3712 of 4255 Old 08-30-2017, 08:37 PM
Hughski68's Avatar
Hooking up to older equipment
I asked over in the Oppo 103 section, but thought maybe I should have here.
What is the best way to hook up a Shield to my system (see sig)? The 2095 has no HDMI. Currently the 103 and 2095 are hooked up by optical.
Panasonic TC-P55GT50, Yamaha 2095, Oppo BDP-103, Yamaha CDC765, Paradigm speakers: 9SEs, CC350, & Titan V2s.
Hughski68 is offline
post #3713 of 4255 Old 08-31-2017, 10:24 AM
crackthewhip's Avatar
Quoted: 108 Post(s)
Liked: 76
The HDMI inputs on the Oppo and TV are both limited to 1080p resolution and your receiver has no HDMI inputs/outputs. I don't see any advantage to connecting the Shield through the Oppo. This is my recommendation:
1. Connect the Shield directly to the TV via HDMI.
2. The Shield will auto-detect recommended settings for resolution and color space from your TV.
3. Connect the TV to the receiver via optical.
4. Change the digital audio output setting on the TV to whatever sounds the best (bitstream?).
5. The TV will pass-through the audio from the Shield and Oppo to your receiver.
6. Select the optical input for the receiver and select the source HDMI input (Oppo or Shield) for the TV.
4K/HDR Display: Vizio M65-D0
Receiver: Pioneer VSX-530K
Media Player: Nvidia Shield TV 2017
OTA HD Tuner: HDHomeRun Connect and Live Channels app
Remote: Logitech Harmony 700
HDMI Cables: Monoprice Premium Certified 18Gbs
crackthewhip is offline
post #3714 of 4255 Old 08-31-2017, 11:56 AM
RichLB's Avatar
Quoted: 13 Post(s)
Hey just wanted to circle back and share a youtube video I just came across: https://www.youtube.com/watch?v=u9-sdZQQTXg
That video is before the oppo beta firmware which allowed hdr through the hdmi input.Hooked my shield to the oppo looked washed out since its a beta it still needs some work.
Vizio P65-C1,P50-C1,Yamaha RX-A2060BL,Oppo UDP-203,Nvidia Shield,Roku Ultra,WD PR4100 NAS,Qnap, TS-453A NAS, Apple TV 4K
RichLB is offline
post #3715 of 4255 Old 08-31-2017, 01:05 PM
psuKinger's Avatar
Liked: 353
Thanks. Really appreciate the input, from you, groove, everyone. I guess their really is no substitute for a new Denon...
groove93 likes this.
post #3716 of 4255 Old 08-31-2017, 03:40 PM
blenky's Avatar
Quoted: 428 Post(s)
Liked: 500
Just bought a FLIRC USB so I can use my Harmony 650 with my Shield. Can anyone tell me how to set up. When I add device to Harmony I can select Flirc as a Manufacturer but don't know what at put as the Device Model No.
Edit: Ok I managed to work it out!
blenky is offline
post #3717 of 4255 Old 09-01-2017, 11:18 AM
Poolshark69's Avatar
Quoted: 57 Post(s)
Liked: 58
I just bought a Shield and Flirc as well. I have the Harmony Ultimate One Can you tell me how you set it up?
Gamertag: Quicksilver1663
Poolshark69 is offline
post #3718 of 4255 Old 09-01-2017, 11:25 AM
cuibap's Avatar
Quoted: 27 Post(s)
Deleted
Sent from my SM-G935T using Tapatalk
cuibap is offline
post #3719 of 4255 Old 09-01-2017, 11:33 AM
Quoted: 108 Post(s)
Liked: 76
I use a Harmony 700 with my Flirc and Shield. See the attachment for programming instructions.
post #3720 of 4255 Old 09-01-2017, 11:35 AM
Quoted: 57 Post(s)
Liked: 58
Thats awesome. Thanks a lot! Excited to start using the Shield when it arrives next week.
