Dune HD SOLO 4K Media Player - Page 133 - AVS Forum | Home Theater Discussions And Reviews
 1292Likes
post #3961 of 5089 Old 12-08-2016, 10:25 AM
blackssr's Avatar
Quoted: 1176 Post(s)
Liked: 588
Originally Posted by kadqs View Post
Yes, it is. Same as Solo4k and Duo4k.
BTW, a big Christmas promotion for SOLO LITE is planned at 16th Dec on IBOOD.com.
Only if BD Menu subscription is in place. If not, then only the lite engine which does not support forced flags in ISOs.
I've paid for my sins. We're even!
blackssr is offline
post #3962 of 5089 Old 12-08-2016, 01:25 PM
thrang's Avatar
Quoted: 2000 Post(s)
Liked: 1662
I own two Solo 4k's and love them. I honestly don't even know what the implication is of not getting Android...
My use is to play movies I own and have ripped, via the Binnerup MyMovies iOS app, and that work's great for ISO and BDMV alike.
blackssr and blenky like this.
thrang is offline
post #3963 of 5089 Old 12-10-2016, 08:51 AM
Untaru's Avatar
Quoted: 144 Post(s)
Liked: 34
It does not have any implication in the way you are currently using your players.
You simply are not going to get the specifications you paid for, when you bought the player.
Please think that you may want to sell the players (on eBay) in few years and upgrade to the latest model.
You will not be entitled to say in the specifications "Dual Boot Linux + Android" as it is stated now in the (printed) user manual at page 4.
Thank you
Untaru is offline
post #3964 of 5089 Old 12-10-2016, 09:07 AM
Untaru's Avatar
Quoted: 144 Post(s)
Liked: 34
I think that Dune should (also) prepare a (big) permanent price decrease because of the failure to implement android.
Thank you
Untaru is offline
post #3965 of 5089 Old 12-10-2016, 12:51 PM
Quoted: 92 Post(s)
Liked: 25
Thank you
But that doesn't benefit existing owners of the Dune Solo 4K.
Whirlpool0548 is offline
post #3966 of 5089 Old 12-10-2016, 01:20 PM
Untaru's Avatar
Quoted: 144 Post(s)
Liked: 34
Unfortunately, you are right.
Untaru is offline
post #3967 of 5089 Old 12-10-2016, 01:37 PM
Quoted: 92 Post(s)
Liked: 25
So, is that what you are suggesting ?
Seems a bit harsh on the existing Dune Solo 4k users.
post #3968 of 5089 Old 12-11-2016, 12:36 PM
Untaru's Avatar
Quoted: 144 Post(s)
Liked: 34
I do not suggest anything.
I am just trying to guess what will happen.
Untaru is offline
post #3969 of 5089 Old 12-11-2016, 12:48 PM
thrang's Avatar
Liked: 1662
Thank you
I still don't know what I'm missing - meaning, what joy am I not experiencing??
thrang is offline
post #3970 of 5089 Old 12-11-2016, 01:02 PM
jconjason's Avatar
Quoted: 754 Post(s)
Liked: 1359
None. Enjoy the Solo 4K like most of us are. Don't let the negative bias deter from enjoying what this player can do.
Samsung 65" KS8000
Denon AVR 6300H
Klipsch F-30 Fronts
Klipsch C-20 Center
Klipsch S-20 Sides
Klipsch B-20 Rears,PA 120 12" Sub,klipsch R-10SW
jconjason is offline
post #3971 of 5089 Old 12-11-2016, 01:39 PM
Untaru's Avatar
Quoted: 144 Post(s)
Liked: 34
Basically most of the apps (that are applicable) that are on Google Play could be installed on your Dune.
If you have iPhone then think that Google Play has similar apps as App Store.
Some people said on this forum that they would like to have Netflix, Plex, Kodi, these are just few examples.
And as I mentioned the re-sale price of your Dune dropped since Dune silently withdraw Android from the specs.
Thank you
Untaru is offline
post #3972 of 5089 Old 12-11-2016, 01:51 PM
thrang's Avatar
Liked: 1662
Thank you
Thanks, of no interest for this device for me.
jconjason likes this.
thrang is offline
post #3973 of 5089 Old 12-11-2016, 02:03 PM
Untaru's Avatar
Quoted: 144 Post(s)
Liked: 34
How about having your favorite application (Binnerup MyMovies iOS app) on Dune?
There is similar application for Android :-).
You could install on your Dune, if you have Android on Dune.
Untaru is offline
post #3974 of 5089 Old 12-11-2016, 02:10 PM
thrang's Avatar
Liked: 1662
I have MyMovies on my iPad, browse the titles there, and selected Play. It plays on the Dune. Couldn't be simpler.
thrang is offline
post #3975 of 5089 Old 12-11-2016, 02:22 PM
Untaru's Avatar
Quoted: 144 Post(s)
Liked: 34
If you consider simpler to use 2 devices (Dune & iPad) to do the same thing as you could do by using only 1 device (Dune), then you are right, it is simpler :-)
Untaru is offline
post #3976 of 5089 Old 12-11-2016, 02:26 PM
jconjason's Avatar
Quoted: 754 Post(s)
Liked: 1359
Hes happy with his Dune and he's stated that more than once he doesn't need the Android ability. Why are you continuing to go on and try to convince him otherwise? Clearly you have a negative agenda here. We all see it very clearly. Thank you.
Samsung 65" KS8000
Denon AVR 6300H
Klipsch F-30 Fronts
Klipsch C-20 Center
Klipsch S-20 Sides
post #3977 of 5089 Old 12-11-2016, 02:33 PM
thrang's Avatar
Liked: 1662
10 foot GUI's are really cumbersome. The ability to quickly scan through, search, and filter several hundred movies using the iPad app is clearly better, especially since I can Play To any Dune on the network easily from it, or any iOS device.
So yes, two devices are objectively superior than one as considered in this instance.
thrang is offline
post #3978 of 5089 Old 12-11-2016, 02:46 PM
Scott Horton, techht.com
GetGray's Avatar
Quoted: 194 Post(s)
Liked: 155
I just saw this post so hopefully my reply isn't out of context. I'm a long time user of MyMovies and Dunes. And I'm generally not a fan of iPad remote control. I am the author of an apparently popular MyMovies Dune customization template that shows covers in a 5x11 format for large screens. BUT... I got an iPad mini as a gift a year or so ago. So of course I loaded MyMovies onto it. Now I'm a convert. I find using it to search for and select movies superior to using the on-screen interface. It's like using a HTPC MyMovies application without the pain and hassle of using an HTPC. I find it much more enjoyable to use to select a movie. I can quickly sort and filter in a variety of ways. If there was anyone who would lean toward the on-screen interface it would probably be me. I now use the iPad app for MyMovies control. It bridges the flawless hassle free playback of the dune with a quick, robust browsing application.
HTH,
Scott
thrang and Mr Eric like this.
GetGray is offline
post #3979 of 5089 Old 12-12-2016, 08:41 AM
Super Moderator
markrubin's Avatar
Quoted: 1296 Post(s)
Liked: 2785
thread cleanup
if your post was deleted, please think twice about re posting it: otherwise you may be asked to leave
thanks
please take the high road in every post:do not respond to or quote a problematic post: report it
HDMI.org:what a mess this is a red flag issue
HDCP = Hollywood's Draconian Copy Protection system
Test Reports HDMI Cables that support 18GBPS&HDMI 2.0b
markrubin is offline
post #3980 of 5089 Old 12-14-2016, 08:24 PM
LD-838D's Avatar
Quoted: 148 Post(s)
Liked: 36
Hi all, Been awhile!
I finally got a AVR that will pass through 4K (Onkyo TXNR646)
It's been awhile and I can't find in the thread or remember what settings I need to play 4K content.
Video Mode? / Additional Video Settings?
Display is a Sony Bravia XBR 55X850C
ID:	1830569   Click image for larger version
LD-838D is offline
post #3981 of 5089 Old 12-15-2016, 12:25 AM
kadqs's Avatar
Quoted: 252 Post(s)
Liked: 164
It is fine as you did it.
You can also use INFO buton on your Onkyo remote, o display video input parameters on the TV screen - just to be sure what signal comes from Dune.
Please also remember to set enchanced mode for HDMI input used to connect AVR, at your Sony TVset.
LD-838D likes this.
DuneHD Duo4K, Solo4K, SoloLite, Base3D, TV-102w, Popcorn A500pro, A500, VTen, A410, C300, Mede8er x3d, QNAP/Synology, Fibaro
kadqs is offline
post #3982 of 5089 Old 12-15-2016, 04:49 AM
the_abbot's Avatar
Quoted: 228 Post(s)
Liked: 38
I am finally getting a 4k avr as well. I will be experiencing 4k on the new Dune for the first time and tinkering with the same settings. Thanks for the screenshots.
Current setup: JVC RS55 - Marantz 7008 - Dune Solo 4K - Kodi/Chromebox - Cinema 10's LCR - Volt 10 Surrounds - Polk in wall rear & ceiling - eD A7-450
the_abbot is offline
post #3983 of 5089 Old 12-15-2016, 09:39 AM
LD-838D's Avatar
Quoted: 148 Post(s)
Liked: 36
Sure thing, Not much content but we have to justify these purchases with 4K trailers ^_^
LD-838D is offline
post #3984 of 5089 Old 12-15-2016, 10:25 AM
Sledgehamma's Avatar
Quoted: 297 Post(s)
Liked: 155
Do you know whether it's for all countries or limited to some?
Sledgehamma is offline
post #3985 of 5089 Old 12-15-2016, 06:49 PM
LD-838D's Avatar
Quoted: 148 Post(s)
Liked: 36
Could someone recommend a 4K trailer/demo that I could check compatibility?
Most of the stuff I'm getting from Demo UHD are having compatibility issues.
I'm playing locally of the Dune HD.
Does AVS forum have a reference clip?
LD-838D is offline
post #3986 of 5089 Old 12-16-2016, 02:39 AM
Quoted: 92 Post(s)
Liked: 25
I have only played test files but the spec says "For Ultra HD (4K) Videos, it looks like the new BD spec calls for 10-Bit H.265 encoding and allows for a maximum bitrate of 128 Mbps. I'm not entirely sure whether this is just for video, audio and video combined"
But the jellyfish-140-mbps-4k-uhd-hevc-10bit.mkv test file plays via NFS over a gigabit network without either audio or video stuttering and no buffer underruns, also this file hits 174Mbps at times. There is an embedded link to many more test files if anyone wants to do further testing.
LD-838D likes this.
post #3987 of 5089 Old 12-16-2016, 03:05 AM
kadqs's Avatar
Quoted: 252 Post(s)
Liked: 164
I see Germany, Netherlands (maybe whole Benelux), Poland. But I am not familiar with their politics, if they allow cross-country sale, and if Austria is handled by DE, etc
kadqs is offline
post #3988 of 5089 Old 12-16-2016, 03:09 AM
kadqs's Avatar
Quoted: 252 Post(s)
Liked: 164
You can check this site: http://demo-uhd3d.com/
Lot of 4k samples, all h265 samples up to 30fps shall work fine.
Some files have special compatibility notes, that can be played only at some TV sets (via USB), but there is only a few such files. Skip them.
LD-838D likes this.
kadqs is offline
post #3989 of 5089 Old 12-18-2016, 10:55 AM
a5ian300zx's Avatar
Quoted: 209 Post(s)
Liked: 67
Hi kadqs,
Any news on what the next firmware update will include?
Sent from my SM-G935F using Tapatalk
TV: Panasonic 55" VT65 Plasma Surround: Yamaha RXA3050 + Orbs Audio Mod2 7.1.2 + SVS SB12-NSD Stereo: Yamaha AS500 + Kef Q300 Processor: DVDO Duo + Darbee 5000S + Iscan Mini Players: HDI Dune Solo4K / VU+ Duo2 NAS: Qnap TVS-871 Pro i7 16GB
a5ian300zx is offline
post #3990 of 5089 Old 12-18-2016, 01:23 PM
kadqs's Avatar
Quoted: 252 Post(s)
Liked: 164
Originally Posted by a5ian300zx View Post
Hi kadqs,
No so much details.
Dune plans to develop music part of MyCollection, but it is lot to do. Maybe we will see a piece of that in next version.
But Dune is releasing Duo4k now, and polishes initial version of its firmware.
For Solo4k we will get something at the end of the year, or beginning of January. To early for details now.
a5ian300zx likes this.
kadqs is offline
