Media Player advise needed - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By godfatherip
post #1 of 15 Old 07-17-2017, 12:51 AM - Thread Starter
sanderdvd's Avatar
Quoted: 170 Post(s)
Liked: 31
Hi guys,
I have a question. I m looking for a media player:
- No netflix, tv etc needed
- Only need .m2ts, .mkv and .iso playback (don t care about blu ray menu)
- Need option to connect my external USB 3.0 device on it
- Prefer XBMC support but if not, another decent movie/series library browser with the iMDB movie scraper
- HDMI 1.4 is enough for me
- Want TrueHD and DTS-HD passtrough via HDMI
- decent 23,976fps support
- a HTPC is ruled out
Not other requirements needed
Please advise.
sanderdvd is offline
post #2 of 15 Old 07-17-2017, 06:45 AM
ronhender's Avatar
Looked at a lot of options and finally decided on Amazon Fire TV (box, not the stick) with Kodi sideloaded. It's 4K capable and has been able to play everything I have thrown at it (BluRay ISOs included). I have several of them. As far as portable storage, when traveling I use a router with a USB port and an external USB drive and use Kodi to access the content. At home everything is played off of a QNAP TS-431+ NAS.
ronhender is offline
post #3 of 15 Old 07-17-2017, 06:52 AM
movd's Avatar
Quoted: 88 Post(s)
Liked: 57
I don't think the FireTV can passthrough lossless audio.
Based on the OPs requirements, its sounds like an Odroid C2 or some other S905 device running LibreELEC would give everything needed at the lowest cost.
Vizio P55-C1 | Denon AVR-X1200W
[5] DefTech ProMonitor 1000s | ProCenter 2000 | SR-8040BPs
[.1] SVS PB1000 [.2] Micca R-8C
movd is online now
post #4 of 15 Old 07-17-2017, 07:01 AM
godfatherip's Avatar
Quoted: 196 Post(s)
Liked: 132
I think the Nvidia Shield will do everything you want, but it isn't cheap. I have one and I know that it works with usb 3.0 HDs, plays mkvs, supports Kodi, and supports lossless audio passthrough over HDMI. I haven't tried iso files myself so I'm not sure about those.
Ricker62 likes this.
godfatherip is online now
post #5 of 15 Old 07-17-2017, 03:05 PM
AVSero's Avatar
Quoted: 23 Post(s)
I would go with the Odroid C2 previously mentioned.
AVSero is offline
post #6 of 15 Old 07-17-2017, 09:24 PM
rbanfield's Avatar
Liked: 6
This is the one most recommend here in Australia, available through Banggood.com
Xiaomi Mi Box Amlogic S905X 2GB RAM 8GB ROM TV Box - International Version AU$90.60
rbanfield is offline
post #7 of 15 Old 07-19-2017, 02:08 PM
Paul37's Avatar
I have similar requirements for a media player as the OP and I'm considering the Nvidia Shield. My only reasons for hesitating are that I don't need the additional expense of a game controller and from what I've heard there's no way to set the Shield to pass-through the video at the original resolution. I would prefer to have my TV (4k Sony) do the upconverting.
Paul37 is offline
post #8 of 15 Old 07-26-2017, 11:56 AM - Thread Starter
sanderdvd's Avatar
Quoted: 170 Post(s)
Liked: 31
Thanks for all input guys. I think you misread my starting post. I do not need netflix support etc. All I am looking for is a device that meets my requirements. Please read my starting post again and advise me. I was thinking you guys would come up with maybe a dune or popcorn hour or mede8er or something.
post #9 of 15 Old 07-27-2017, 01:40 PM
Paul37's Avatar
Like you, I'm just looking for a box that will take files from an attached USB drive and pass through video to my 4k tv without up-converting it, and to pass-through HD audio to my A/V receiver. If you're considering anything running Android make sure you research the difference between an "Android" box and an "Android TV" box. If you plan to use XBMC (now called Kodi) I don't think you get HD audio support unless it's an Android TV box. (anyone here correct me if I'm wrong.) The cheap Chinese boxes are almost all just Android, while the Nvidia Shield and a couple of others are Android TV.
Paul37 is offline
post #10 of 15 Old 07-27-2017, 09:56 PM
Ph8te's Avatar
Quoted: 4810 Post(s)
Liked: 4359
You don't need Android TV to get HD Audio. Kodi has supported HD Audio on Android for a little while now.
Ph8te is offline
post #11 of 15 Old 07-28-2017, 01:29 AM
Paul37's Avatar
From the Kodi website:
Kodi 17.0 is now standards-compliant with Android’s official Audio API and requires Android 5.0 or higher as the minimum version. DTS-HD, DTS-X, Dolby TrueHD, and Dolby ATMOS passthrough are now supported on devices that implement AudioTrack v23 or higher. Devices with firmware that does not follow this standard will not support passthrough.
My understanding is that the cheap Chinese boxes don't have AudioTrack v23 implemented in their firmware, but the boxes running Android TV do. If you have it working I'd be interested in what hardware you're using and which version of Kodi. Also, are you sure you're talking about HD audio, and not just DD and DTS?
Paul37 is offline
post #12 of 15 Old 07-28-2017, 05:38 AM
Ph8te's Avatar
Liked: 4359
@Paul37 I'm sure there are many available now. It also depends on how you define "cheap Chinese boxes". HD Audio since Kodi 16.x has been available depending on the chipset the device uses. I personally use a Wetek Hub (temporary device) and it does output HD Audio (TrueHD/DTSMasterHD) via the ISOs I have in my collection.
I would suggest tasking a look at the Kodi forums as they are a great source of information (you'll even see some members from AVS there).
https://forum.kodi.tv/showthread.php?tid=252916
Ph8te is offline
post #13 of 15 Old 07-28-2017, 01:27 PM
Paul37's Avatar
@Ph8te Thanks for the suggestion to look at the Kodi forums. The information at the link you provided would probably be of help to the OP as well.
If your Wetek Hub is a temporary device, have you decided what your next option will be?
Paul37 is offline
post #14 of 15 Old 07-28-2017, 01:49 PM
Ph8te's Avatar
Liked: 4359
Not yet, waiting for Kodi 18 which will be "the beginning" of BDJava support (it's in testing now). I'm in no real rush as the Hub serves most of my needs. The next player I get id like to be DV/HDR10+ capable and be able to do BDJava menus (currently I can see non Java almost every time). I'm not huge in need of app support, but Kodi has been great for local media management (moved from an A400).
The one caveat with the Hub is that sometimes the firmware can cause issues (I check their forums before installing anything). This can mean it needs a clean install to upgrade (not a fan). With so many options I am hoping to see something next year sometimes that meets my minimum goals.
Ph8te is offline
post #15 of 15 Old 08-01-2017, 12:54 AM - Thread Starter
sanderdvd's Avatar
Quoted: 170 Post(s)
Liked: 31
