Mvix Wireless Hi-Definition Media Player (MX-760HD) - Page 4 - AVS Forum | Home Theater Discussions And Reviews
Old 01-11-2007, 08:34 PM
sixtyhurts's Avatar
Originally Posted by cpete View Post
I downloaded firmware 1.0.9 and was was able to flash it no problem.
Chris
Ya for some reason when I drug the file from my laptop to the internal mvix drive it didn't like it. I called support and they suggested I use a thumbdrive to update from and that finally worked.
sixtyhurts is offline
Old 01-12-2007, 08:54 AM
sixtyhurts's Avatar
Originally Posted by antivirus View Post
i have 1.03 firmware in my mx760
run good.but no read files from my dreamboxes ( .ts / mpeg transportfiles) :-(
regards
Hmm.. so you can't get it to play your .ts files at all?
Old 01-12-2007, 08:57 AM
sixtyhurts's Avatar
Latest reply from MVIX on continued problems with .ts files:
"If it is possible, please upload a sample TS file to an FTP or fileshare server
so we can download and test. Please rest assured this will get the attention of
our development team ASAP.
Thank you,
John Rearden
~ Mvix Support Specialist ~
Mvix (USA), Inc. - Revolutionizing Portable Entertainment.
www.mvixusa.com
Toll Free: (866) 310 4923"
Now to find a place to serve the .ts file.... Can anybody suggest a place to serve large files from for free?
Old 01-12-2007, 10:57 AM
Squished Squirre's Avatar
http://www.mediafire.com/
Squished Squirre is offline
Old 01-12-2007, 04:11 PM
sixtyhurts's Avatar
Thanks for the help Squire, that is a great place to host files.
I managed to upload a couple .ts files that show the frame drop stutter, but it seems that I can't reproduce the audio glitches or the video reset in midstream with these smaller samples. (I joined the two sample .ts files in the exact place of the reset on the full movie)
It appears that around 4gb into the .ts is when it resets to the start of the video. So I'll have to upload a 5gb sample file for the devs. Mediafire seems to ignore the 5gb file I attempt to upload. Maybe I'll send them a dvd if all else fails.
Old 01-12-2007, 04:18 PM
sixtyhurts's Avatar
here is a test .TS file
i have link mail to company now...
http://amd.co.at/anti//ts_files/
regards
Thanks anti. i'll try that one on my mvix now..
Old 01-12-2007, 06:54 PM
sixtyhurts's Avatar
but: this .ts file DONT run in mx 760 with firmware 1.09 :-(
i wait for firmware update ...??
best regards
Ya, i got an invalid or unsupported format error as well. Yet it plays fine with VLC media player. I sent that file to them with a link to this thread as well. Let's hope they take a peek in here.
BTW, that sample is funny as hell... even if I don't understand it.
Old 01-12-2007, 07:24 PM
sixtyhurts's Avatar
I bought this unit and immediately tested some .ts files I captured straight from my hdtv cable box. To my amazement it played them flawlessly.
With 1.0.9 installed, the flawless playback is now replaced by the infamous dropped frame stutter problem. And the Null Packet Stripper joined .ts files have a much worse stutter than with the default 1.0.0 firmware.
I'm depressed.
Old 01-13-2007, 04:16 PM
Yagodewinter's Avatar
Hi Guys,
just two questions. I don´t have the device but would like to get it.
Is it possible to rotate pictures while watching and does the device play m3u-playlists? I would like to use the device mainly as mp3 and photo storage and playback.
When watchin movies they will be .iso,.avi files and some divx, I believe they should work.
So if m3u and rotating of pictures is okay. I will go for it.
greets
Yagode
Yagodewinter is offline
Old 01-13-2007, 06:41 PM
sixtyhurts's Avatar
Originally Posted by Yagodewinter View Post
Hi Guys,
I just tested an m3u playlist and it works great. I'm not sure about rotating pictures. Right now the image viewer feature doesn't seem that great.
Isos and avi files should be no problem tho.
Old 01-14-2007, 02:07 AM
Thanks for the info. Sounds great. I read through the manual and it didn´t say anything about rotating pictures.
Can anyone comment on that feature?
Would be great.
thanky
Yagode
Old 01-14-2007, 10:45 AM
patja's Avatar
Anyone using this unit to stream DVD .ifo or .iso from an Infrant ReadyNAS?
I've got a Zensonic Z500 and Helios X3000 and they either suck at this (Z500 doesn't play half my films) or simply don't support it (X3000).
I am looking for rock solid reliability of .ifo and .iso ...getting ready to revert back to HTPC to get this experience, but I am still holding out hope for the Z500 1.6 firmware that is to be released end of the month.
patja is offline
Old 01-14-2007, 04:45 PM
sixtyhurts's Avatar
hi yagodewinter :-.) i build now a new firmware for mx760 :-)
with all bugs fixed..
if you want i sent you next days a test image... and its run 100%
regards :-)
You built a new firmware? With all bugs fixed? Please give us details
Old 01-16-2007, 07:14 AM
jeepfanz's Avatar
antivirus - great job!
This sounds too good to be true! I looked at your site, but my german is sorely lacking and even with translation I was lost. Can you point directly to the firmware package?
Can you post a link to the source ? What did you use to build it up? I'd love to take a crack at the UI, there has to be a way to add thumbnails to files.
Any one had luck trying this yet?
jeepfanz is offline
Old 01-16-2007, 05:11 PM
sixtyhurts's Avatar
what you want in a new firmware ? tell me what you want ...
first i make telnetd, then samba, gftp, nfs , http, and some other nice things
and a lot of bug fixed.... better mp3 player, id tags, rotate pictures, and some more..
Wow, i'm impressed... A good feature to add would be maybe seamless playback of segmented movie files. Would H-264 file support be asking too much? :P What kinda features could you add?
Old 01-16-2007, 10:09 PM
dlorenzo's Avatar
h.264 support I want that
dlorenzo is offline
Old 01-16-2007, 10:46 PM
mpabart's Avatar
Just wondering who may have had luck with 1080i .ts files ? At what bitrate ?
Bart
Bart Harrison
MPA - The HD Suite
Editing Systems, Storage Area Networks
HD Consulting, Production & Post, Exhibition & Distribution
www.hdsuite.com
mpabart is offline
Old 01-17-2007, 06:57 AM
jeepfanz's Avatar
Unfortunately, the Mvix designers used a the EM8621L and not the EM8623L, the 21L doesn't support H.264 decoding.
Check the sigma designs site for the EM8620L Series and look at the back of the product brochure (I can't post a link here yet until I post a few more times).
It looks like these are pin compatible though ... I wonder if they could be swapped if they were available (reasonably)? or maybe they'll offer an upgrade later if enough folks scream for it.
jeepfanz is offline
Old 01-17-2007, 04:00 PM
sixtyhurts's Avatar
Bart
The raw .ts files i have captured from my cable box via firewire seem to playback smoother than .ts files I download. With the current firmware they all have dropped frames and reset after 4gb for some reason.
Old 01-18-2007, 10:40 AM
gregsmith's Avatar
Nice one man! You may have just been the one to make me buy a 760-hd
I'd love to see a web browser and a torrent client!
don't know if this is possible, but it's based on Linux right??
gregsmith is offline
Old 01-18-2007, 01:33 PM
cpete's Avatar
antivirus,
I was able to download everything but "mixv_romfs_telnet.gz". I'm not sure why. IE7 says the site is unavailable when I try to "save target as". What does this file do? Is it necessary?
I didn't have any problems with "mvix_romfs.gz", "readme_first.txt" and "tftp_desktop_free.exe".
Thanks, Chris
cpete is offline
Old 01-18-2007, 01:53 PM
cpete's Avatar
Very nice. Thanks for the improved directions, with screen shots.
Many thanks, Chris
cpete is offline
Old 01-18-2007, 03:01 PM
maltice's Avatar
Hmm... well i just bought the thing, waiting to get home to set the damn thing up... the .ts file playback problem worries me... but this new firmware antivirus has been wiritng sounds promising as hell...
anyone actually upgrade with his firmware with success?
Also Anticirus, i am slightly confused as to what exactly you have done so far.. what things have you actually fixed or changed or added?
-maltice
///wish i knew more about hacking firmwares....
maltice is offline
Old 01-18-2007, 03:18 PM
maltice's Avatar
this is gonna be one big ass learning experience isn't it?
heh....
maltice is offline
Old 01-18-2007, 06:43 PM
sixtyhurts's Avatar
Great ideas greg!
Antivirus, you are making people buy this unit. Thanks so much for your efforts and knowledge.
Old 01-19-2007, 02:03 PM
gregsmith's Avatar
Great ideas greg!
Yeah, hats off to you AntiVirus! Thanks for gracing us with your time and abilities.
I'm so tempted to buy this device, but they seem to be coming thick and fast at the moment - I don't want to be kicking myself if a better one is round the corner. Does anyone know anywhere that might have the lowdown on future devices of this kind?
Old 01-19-2007, 02:10 PM
Sy-
Sy-'s Avatar
Anyone try the New Firmware from MVIX 1.1.15? Just got the email about it!
Sy- is offline
Old 01-19-2007, 02:28 PM
maltice's Avatar
Nope... can you download already?
maltice is offline
Old 01-19-2007, 02:31 PM
maltice's Avatar
yeah new download:
Languages supported: Korean/Japanese/English/French/Spanish/German
Moved volume to upper right side.
Modified fast backward function. (2/4/8/16/32)
Improved FB speed stability
Improved "My List". If files in "My List" are not detected, they do not show on the list.
Added display hourglass for access to the "My List" folder
Bug Corrected: Unit Slows down if a recently played Playlist has a digital image file.
Improved audio/video format information display on the info OSD.
Improved "Stop" issue with certain file formats
Improved remote control functionality
Improved problem with movies not being able to play to the end
Fixed hang up associated with 8x FF
Improved FF/FB information display
Improved mp3/wma playback
***My favorite part is the "Improved Problem with movies" !! HAHAH Why would you improve a problem? Anyway i thought that was funny.
http://www.mvixusa.com/support/index...nloaditemid=17
maltice is offline
Old 01-19-2007, 03:05 PM
I'd be happy if it truely fixes the problems with fast forward hanging the box. I've had that happen more times than I care to recall.
Cool.. fixed problem with mylist. That annoyed me that after disconnecting from the network, it still showed all the files from the server. Hate having all the porn show up when disconnected ;-)
