Disaster! ReadyNas upgrade TviX cannot connect! - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 12-30-2007, 02:00 PM - Thread Starter
AJSG's Avatar
My TVix ReadyNAS combo has been working perfectly for over 6 monts, suddenly the NV+ uprgades its firmware and after the lengthy file check it no longer functions properly with the TViX.
I have checked that they are both on a 10/100 router, ie Jumbo frames disbled. It will see the 5 main folders under the "MEDIA" share (password "tvixhd1") but then when I enter the folder it cannot see any of the files!!!
Then it crashes.
Any ideas? Does anybody know how I can put back the old firmware on the NV+?
Also I have full access to all of the folders on the NV+ from my PC. I have even tried a different network cable (just in case, as I had to roll the piano over the old one today!).
Gentlemen prefer Bonds...
AJSG is offline
post #2 of 3 Old 12-30-2007, 02:33 PM - Thread Starter
AJSG's Avatar
Sorry all...resolved...MTU setting must be 1500...no higher...
AJSG is offline
post #3 of 3 Old 01-09-2008, 08:54 PM
base428's Avatar
Over at the Infrant forum, several people found that disabling jumbo frames was all that was needed to fix it. It's a bug in the latest firmware since jumbo frames should still work with non-jumbo devices like the Tvix. My Tvix could connect to the ReadyNAS, but folders were inaccurately shown as being empty. Disabling jumbo frames solved my problems as well. There is a way to go back to the old firmware, but you will lose all data on your drives unless you back it up first.
base428 is offline
