LCD of Plasma for Standard Definition??? - AVS Forum
post #1 of 5 Old 05-28-2008, 11:29 AM - Thread Starter
Bucky_Balls's Avatar
Looking for a new HDTV, however, I'll be watching TV through over-the-air broadcasts for now. I do a decent amount of gaming as well, and will eventually be getting a blue ray player. For the moment though, it's just Standard Definition over-the-air signals, and standard definition DVD's, plus Xbox 360 and Wii. Which would be better? LCD or Plasma???
Bucky_Balls is offline
post #2 of 5 Old 05-28-2008, 11:53 AM
tank171's Avatar
SD has nothing to do with the different techs, but the tv's video processor.
tank171 is offline
post #3 of 5 Old 05-28-2008, 12:28 PM
BWDinc's Avatar
Well, actually most top tier plasmas will make sd look better than any non top of the line lcd. for example to get sd to look good on a sony lcd you have to get the xbr. ANY panny or sammy plasma sd will look good.
BWDinc is offline
post #4 of 5 Old 05-29-2008, 06:29 AM
TNG
TNG's Avatar
A year ago I would have said that Plasma would look better with SD, mainly because it was more like the CRT that we all grew up with. Now after watching allot of HD content and comparing it to SD, I will say that it doesn't matter. After you get used to HD, all SD on PDP or LCD looks blurry. Scalers will make a difference, but it is still SD.
BWDinc is correct that a Sony will make SD look better, but they do cost more for the privilege of having a XBR5,6,7,8 or what ever number they are up to now.
Games are a whole different story. What kinds of games? As an avid gamer, I have found that for allot of games (mainly RPG) Halo, Gears, Resident Evil, etc... that have dark backgrounds and dark scenes, you have to get a set that has good black detail. PDP would normally be better for this, but there are a few LCD sets out there that can do it. Remember that if you can't see the alien or zombie lurking in the dark you can't kill it before it kills you. As you can see this is my favorite type of game.
If you are playing allot of sports type games like EA Football, basketball, hockey, racing of any kind, etc... games with lots of light bright backgrounds, I would recommend LCD.
My 2 cents
TNG is offline
post #5 of 5 Old 05-30-2008, 04:36 PM
Jack White's Avatar
SD only looks good on high quality 13" to 40" Direct View CRTs, END of story.
SD can look ok if a flat panel has great image processing, scaling, etc, but an SD source will never reach its full potential on a flat panel at least till some of the newer technologies become more than vaporware.
Jack White is offline
Reply Flat Panels General and OLED Technology
User Tag List
