Are DVDs really 480p? 480p vs. 720p question. - AVS Forum | Home Theater Discussions And Reviews
 20Likes
post #1 of 145 Old 01-28-2009, 06:11 AM - Thread Starter
SpeksETC's Avatar
I always thought DVDs were 480p, which is considered SD and thats why 720p material looked so much better.
Yesterday I went to www.apple.com/trailers and saw that not only do they categorize their 480p trailers as HD, but when I watched a 480p trailer on my Panny 50PV80, it looked pretty damn good, and definitely better than a standard DVD.
What is going on here?
Try it for yourself:
http://movies.apple.com/movies/unive...tlr2_h480p.mov
http://movies.apple.com/movies/unive...tlr2_h720p.mov
SpeksETC is offline
post #2 of 145 Old 01-28-2009, 06:15 AM
dyates69's Avatar
Did you watch it in full screen mode or a window? It's a newer compression codec than DVD but likely a lower bitrate. I had a look and don't believe it looks better than a well mastered DVD. The mastering quality does vary substantially however between DVD's.
dyates69 is offline
post #3 of 145 Old 01-28-2009, 07:10 AM - Thread Starter
SpeksETC's Avatar
I watched it full screen on my 50" plasma.
720p version looked better, but I was really impressed by the 480p version - so much so that I thought I was watching the 720p one first....
SpeksETC is offline
post #4 of 145 Old 01-28-2009, 11:04 AM
dovercat's Avatar
Quoted: 68 Post(s)
I think DVDs are Interlaced not Progressive, hence the need for deinterlacers, a good deinterlacer with a film sourced DVD should give more picture detail equal to Progressive most of the time. While a video sourced DVD deinterlaced relys on bobbing and weaving all the time. A dvd player with a poor de-interlacer may bob and weave film sources reducing the visible fine detail.
A 480p source may have color encoded at the same resolution as the black and white image. Color resolution on DVDs is normally half the vertical and half the horizontal resolution of the black and white image. The dvd player interpolats this up to the black and white images resolution. Not all dvd players are good at doing this interpolation.
Film and video is sampled then filtered at half the frequency of the sampling to prevent aliasing effects. So detail resolution maybe less than detail resolution of computer graphics, or film/video from sources that have been downscaled to the same resolution.
On DVDs pre-smoothing - reducing the fine detail, is often done before encoding to reduce the mpeg bit rate. Too low a bit rate for too much information leads to mosquito noise and blocking noise. Noise reduction in the dvd player may automatically reduce mosquito and blocking noise, but on discs that are properly encoded this is not needed and when done reduces image detail.
In the UK PAL dvds are often claimed to be 576p, if NTSC dvd claims are like PALs then NTSC is probably not equivelent to 480p.
PAL DVD claim equivelent to 576 progressive x 720 and calibration - reference dvds are that good but in reality most dvds were designed for CRT displays on which they typically give 500+ (very rarely 540) interlaced x 711 resolution so are usually not mastered better than this.
Dvd is mastered up to 6.75MHz the higher the MHz the finer the details - more lines of resolution. To retain this detail they must have a flat response all the way up to 6.75MHz. However I believe to save bit rate, frequency response is usually tailed off before 6.75MHz. All dvds are filtered vertically to reduce flickering. Superbit dvds are not filtered horizontally.
DVD was developed when CRT was the main type of display and was over spec for it.
On a 4:3 tv a dvd has at most 540 lines of resolution because in this case each MHz = 80 lines of resolution. So I believe most dvds are mastered with less than this, very few with more.
The 720 lines of resolution comes from the sampling rate. But CRT has at best 711 pixels of resolution, it does not have time for more. it takes 52.65 µs (microseconds) to draw a scan line and aprox 0.07407 µs per pixel.
PAL Dvd players typically claim 500+ lines of resolution which is more accurate to DVDs in reality than the maximum DVD spec 576. It is unfortunate that the DVD specs do not include a minimum quality - resolution of discs.
You then get to reduce the resolution of the display by the Kell factor.
dovercat is offline
post #5 of 145 Old 01-28-2009, 12:10 PM
Carled's Avatar
The video is meerly stored on the disc in interlaced format. The content itself can be either.
Carled is offline
post #6 of 145 Old 01-28-2009, 02:38 PM
Gary McCoy's Avatar
Quoted: 93 Post(s)
Liked: 97
The standard DVD resolution is 480i. What that means is there are two "fields" of 240 lines by 720 pixels stored on the disk in digital format. A standard DVD player will output these frames unchanged in a 480i format, via "composite video", S-Video, or "component video". A 480p DVD player will first "de-interlace" or recombine the two "odd" and "even" fields into a single 480p frame, and output this as a "480p frame" (resolution 480 lines X 720 pixels), via "component video". This output requires a high definition display - either an HDTV or a computer type display, or there will be no video quality difference from the standard 480i TV. The 480p display requires THREE seperate video cables, a "component video" display.
The ultimate way to display a standard DVD on an HD display is via an "upscaling DVD player", which reads the 480i signal, converts to 480p, then "scales" the 480p output to 720p, 1080i, or 1080p. However, due to the copy protection rules, the upscaling DVD player must use an HDMI interface.
Gary McCoy
The United States Constitution ©1791. All Rights Reserved.
Gary McCoy is online now
post #7 of 145 Old 01-29-2009, 12:29 AM
gus738's Avatar
Quoted: 59 Post(s)
Liked: 32
gary has a great post, but in short i woud like to say, dvds are SD l and so therefore as the screen size gets bigger the worse dvds are to look, with HD being 720p you have more lines more resolution to work with therefore doesnt look as bad as 480 i/p
so say a 480i/p video on a small screen then watch it on a bigger screen it will look diffrent.
Keep in mind of the resolution/spec numbers are like 720x480 i think, so therefore put a screen of that size and thats the best it will look, think for a moment how small is the amount of pixels of a screen of 720x480.
darn i made this complicated,
HD is better then SD so higher resolution better
Pioneer Elite PRO-111
Samsung 60PnF5300 af
panasonic px75u(r.i.p)Samsung 51f4500
XBL x117x831
PS4 gusx831
gus738 is offline
post #8 of 145 Old 01-29-2009, 09:56 AM
dovercat's Avatar
Quoted: 68 Post(s)
"The video is meerly stored on the disc in interlaced format. The content itself can be either"
Thats why I said film sources can be de-interlaced to be as good as progressive. Players with progressive output also benefit from having faster DACs with more oversampling. But the player needs to correctly detect the film source and switch between methods of de-interlacing. Often dvds have incorrect flags as to how they should be de-ineterlaced and films often have poor edits which need to be de-interlaced with bob and weaving. The player may also have the color upsampling bug where it is assigning color incorrectly.
dovercat is offline
post #9 of 145 Old 01-30-2009, 05:56 AM
Daviii's Avatar
DVDs are recorded in MPEG2 at 5mbps while Apple encodes all the trailers carefully at H.264 which is a MUCH more advanced codec and retains MUCH more detail at lower bitrates. The loss of quality over the master is much higher on the DVD. That's the reason.
It's like comparing a 1080p BD picture with a 1080i TV broadcast. It simply has better encoding.
Daviii is offline
post #10 of 145 Old 01-03-2014, 01:43 AM
markfilipak's Avatar
Quoted: 61 Post(s)
-withdrawn-
markfilipak is offline
post #11 of 145 Old 01-03-2014, 02:15 AM
pokekevin's Avatar
Liked: 102
Originally Posted by markfilipak View Post
Wow! What an incredible amount of disinformation is here. ...Far too much to comment on. Sad. I guess some people feel to be respected they must take their half-baked notions and present them as truths.
Calling out people and not telling them why they are wrong is another thing too lol
rickumali likes this.
pokekevin is offline
post #12 of 145 Old 01-03-2014, 04:07 AM
Quoted: 61 Post(s)
-withdrawn-
post #13 of 145 Old 01-03-2014, 05:58 AM
coolscan's Avatar
Quoted: 18 Post(s)
Liked: 88
When you resurrect a thread that was last active in 2009, you must expect it is full of all kind of info that is no more applicable.
There is a reason the activity in this thread stopped in January 2009. rolleyes.gif
coolscan is offline
post #14 of 145 Old 01-03-2014, 02:10 PM
tgm1024's Avatar
Location: Sorry, chances are excellent that you're an idiot.
Quoted: 2455 Post(s)
Liked: 2230
Because he likely wanted to sound off as if he was one of the experienced crowd.  Or some other such thing.  There is  no other reason to go out of your way to dig up something that old just to bash folks for technical mistakes which stand a good chance of merely being more dated than incorrect.
Thought #EAA: I wonder how many people know that no one ever says "What we've got here is a failure to communicate." in the movie "Cool Hand Luke" (1967).
tgm1024 is offline
post #15 of 145 Old 01-03-2014, 02:27 PM
Otto Pylot's Avatar
Quoted: 1356 Post(s)
Liked: 852
With only 3 or 4 posts he apparently hasn't learned the cardinal rule for newbies. However, he's new so a little slack may be in order wink.gif
Otto Pylot is offline
post #16 of 145 Old 01-03-2014, 02:30 PM
Quoted: 61 Post(s)
-withdrawn-
post #17 of 145 Old 01-03-2014, 03:04 PM
8mile13's Avatar
Quoted: 1479 Post(s)
Liked: 825
Actually,
1, Someone in an Internet Movie Database (imdb.com) forum implied that 720p DVDs existed
8mile13 is offline
post #18 of 145 Old 01-03-2014, 03:14 PM
tgm1024's Avatar
Liked: 2230
3, I didn't mean to "bash" anyone. Settle down, eh?
BS!  Yes you did.  Or was this little tidbit of yours supposed to be supportive?
tgm1024 is offline
post #19 of 145 Old 01-03-2014, 03:17 PM
tgm1024's Avatar
Liked: 2230
Actually,
LOL.....since we're in 2009, BD has only recently won the format war.  You suppose it has any staying power?
tgm1024 is offline
post #20 of 145 Old 01-03-2014, 03:42 PM
Otto Pylot's Avatar
Liked: 852
post #21 of 145 Old 06-28-2014, 01:08 AM
Quoted: 61 Post(s)
I don't understand, Carled. Help me out, would you?
If DVD content is interlaced, how can it be progressive?
Suppose the odd field (240 odd lines) begins at t=0. The even field (240 even lines) will begin at t=1/60 seconds.
Scenario #1 : If the odd field was captured 1/60 second ahead, then the interlace is temporal and rather than a frame, the video consists of 2 fields that are separated in time by 1/60 second. I would think that, because they are separated in time, the 2 fields cannot be deinterlaced.
Scenario #2 : If on the other hand the odd & even fields were captured at the same time (for example, from a film telecine), then the capture was progressive, but the 2 fields are still separated in time by 1/60 second. I would think that by delaying the 1st field by 1/60 second, the 2 fields could be combined into a single deinterlaced frame (at 1/30 second frame rate).
Which is interlaced, Scenerio #1 or Scenerio #2 ?
Which is progressive, Scenerio #1 or Scenerio #2 ?
If Scenerio #1 is interlaced, then I would think the proper designation should actually be "60 fields/sec", not "interlaced".
If Scenerio #2 is progressive, then I would think the proper designation should actually be "30 frames/sec", not "progressive".
What say you?
post #22 of 145 Old 06-28-2014, 02:31 AM
Carled's Avatar
What say you?
You actually necroed a thread from half a decade ago to start an internet argument? Seriously? Sometimes members of my species scare me.
As for that antique storage medium known as the DVD, it stores things as sixty interlaced fields per second (fifty in PAL format), and someone storing a film on it could choose between taking 24/25/30 frames and breaking it up into fields (telecine), or storing something that's shot in interlaced format if for some reason they wanted temporal resolution more than spatial resolution. It sure sounds like a whacky way of doing things now, but DVD was designed back in the dark ages of the early 90s when most of the world was using CRTs (kids: ask your parents) and the engineers clearly didn't forsee the signal processing revolution of the late 90s and 00s.
But all of this is moot now, we now live in a brave new future where things are actually stored progressively on the disc in the first place. I'm still waiting for my flying car, though.
Carled is offline
post #23 of 145 Old 06-28-2014, 06:42 AM
Joe Bloggs's Avatar
Quoted: 432 Post(s)
Liked: 118
De-interlaced means converting interlaced to progressive/a progressive signal. De-interlacing interlaced (as in scenario 1) video is complex (see de-interlacing in Wiki), one simple (but low resolution) method for scenario 1 is line doubling (you'd end up with 60 different progressive pictures per second) but these days they'd normally do something better (such as using only doing that for the moving parts of the picture - see wiki).
Joe Bloggs is offline
post #24 of 145 Old 06-28-2014, 10:14 AM
tgm1024's Avatar
Liked: 2230
Wikipedia? (groan)
tgm1024 is offline
post #25 of 145 Old 06-28-2014, 11:03 AM
Quoted: 61 Post(s)
Dear Carled & Joe Bloggs,
I'm not trying to start an argument at all, Carled -- honest! I'm trying to understand DVD. I'm also trying to understand how DVD relates to the HDMI specification (which details several dozen formats ranging from 288x480i/60 (DAR=4:3, VIC=10, PR=9) to 2880x480p/60 (DAR=16:9, VIC=36) to 1920x1080p/120 (DAR=16:9, VIC=63)).
On a more mundane note, I have a DVD that appears to be deinterlacing incorrectly and I'm attempting to determine whether I should finger Panasonic (home theater) or Sony Pictures (DVD). I'm a little suspicious of Sony Pictures because, though at least one other person sent their DVD to Sony and Sony claims there was nothing wrong with it, Sony released a completely new Region 1 DVD (new telecine?) only one year later -- the film: "Enigma", wasn't exactly a big seller and so, a new telecine seems suspicious. Unfortunately, I don't have any tools to read low-level stuff on DVDs, and that hinders me. What I do have gives conflicting results (like whether a DVD is 24fps or 30fps). So you see, I have good reason to bring this back up. Or would you prefer a new thread starter?
Hahaha, I think Elon Musk recently said he's going to build that.
So, Carled, let me directly ask you 2 questions, please.
1, Considering a truely NTSC-compatible, 480i telecine that's temporally interlaced, is it actually possible to deinterlace that stream into temporally & spacially progressive keyframes without performing interframe interpolation (which isn't going to happen in a real DVD player)?
And 2, Do you know of a free & accurate source of information on the DVD specification -- I'm an electronics engineer & digital architect, but I'm retired and can't afford to buy the DVD spec.
Believe me: I'm not trying to argue. I'm trying to learn. I need answers, not clues or vague hints. There's so much bogus information out on the net...
I'm glad you bring up line doubling. So I take it that you claim that temporally interlaced 480i cannot be deinterlaced to 480p, but can only be deinterlaced to 240p-doubled -- is there a name or designation for that... maybe 240(x2)p or some such thing?
Thanks guys!
post #26 of 145 Old 06-28-2014, 11:09 AM
Joe Bloggs's Avatar
Quoted: 432 Post(s)
Liked: 118
Originally Posted by tgm1024 View Post
Wikipedia? (groan)
edit: De-interlaced means converting interlaced to progressive/a progressive signal. De-interlacing interlaced (as in scenario 1) video is complex (see de-interlacing in Wiki please see chapter 35 of Charles Poynton's book entitled "Digital Video and HD (algorithms and interfaces), second edition", one simple (but low resolution) method for scenario 1 is line doubling...
tgm1024 likes this.
post #27 of 145 Old 06-28-2014, 11:31 AM
Joe Bloggs's Avatar
Quoted: 432 Post(s)
Liked: 118
No, it was still be de-interlaced to what they call 480p. But with scenario 1 (where it was shot interlaced, where each 1/60th of a second of the source is a different point in time), if they used just line doubling the effective resolution would be no more than half what 480p is capable of. But using line doubling alone was just an example of how it (scenario 1) could be de-interlaced, and is not/not normally the best way. The other ways (including only using line doubling for the moving parts of the picture, so the stationary parts get full resoloution - or close to it), can give better resolution.
It's a bit like how 1080p video is still normally referred to as 1080p even if the effective resolution is less (such as if the 1080p video had been created from upscaled 720p video).
But I still think interlacing isn't a good format and we should have higher progressive frame rates .
post #28 of 145 Old 06-28-2014, 12:05 PM
Quoted: 61 Post(s)
Thank you, Joe,
No, it was still be de-interlaced to what they call 480p. But with scenario 1 (where it was shot interlaced...
"Shot interlaced"? OH! The video was interlaced (i.e., NTSC).
...where each 1/60th of a second of the source is a different point in time), if they used just line doubling the effective resolution would be no more than half what 480p is capable of. But using line doubling alone was just an example of how it (scenario 1) could be de-interlaced, and is not/not normally the best way...
Come on, now. Do DVD players actually have the time to (bother to) do interframe interpolation?
Well, you see, Joe, that kind of 'sloppy' nomenclature is part of what confuses me and others. I would think that such a stream should be termed "720(x1.5)p" or "720(x3:2)p" or some such notation.
Can you give me the names (links to) some tools that will help me to determine what is actually wrong with my Sony Pictures DVD of "Enigma", if anything is wrong with it? Assume I have no tools now -- well, I have a Tektronix 2465 oscilloscope, but no DVD software tools. Thanks!
post #29 of 145 Old 06-28-2014, 12:22 PM
Stereodude's Avatar
Quoted: 3084 Post(s)
Liked: 2236
Most recent DVDs of movies that were shot on "film" are actually encoded at 720x480p @23.976FPS and have a soft pulldown applied to them. Basically the MPEG-2 stream tells the MPEG-2 decoder to apply a telecine to the footage during playback. A progressive DVD player can decided to not honor the flag and pass the 480p23.976 stream out the HDMI port (or to the internal video processor), or it can apply the telecine as flagged and then apply an inverse telecine in the player's video processor to remove the telecine getting back the same 480p23.976 video stream. If your DVD player doesn't support progressive playback you're going to get the telecined 480i59.97 output.
Stereodude is offline
post #30 of 145 Old 06-28-2014, 01:05 PM
Joe Bloggs's Avatar
Quoted: 432 Post(s)
Liked: 118
They probably don't do it (motion compensation frame interpolation) - though mpeg itself sort of uses it - kind of. But TVs do have MCFI, so there's no reason, a DVD/Blu-ray player shouldn't be able to.
Yes but the video stream itself is actually in the full progressive format. eg. a 1920x1080p24 video is made up of 1920x1080 pixels, even if someone had encoded that 1920x1080 video from a 720x576 or 1280x720p source (even though the effective/resolvable resolution is less). But I do think that when there is a Blu-ray like this it should be made very clear that the original source was 576i or 720p or whatever.
I don't really know. I've seen something like that for one of the extras on a discs. I suppose you could look at it field by field in pause mode on a player (eg. Panasonic BD80) to see what it's doing (if things are stepping backwards then going forward again - but that might depend on the mode (eg. film/video/auto?)). Or it could be the player is detecting it incorrectly (it might ignore any flags in the video). My player has options for Film/video/auto (auto=automatically detects format).
edit: This is dated but might be worth a read:
http://www.hometheaterhifi.com/volum...e-10-2000.html
Reply OLED Technology and Flat Panels General
