What are the downsides to Laservue besides size, price, and viewing angle? - AVS Forum
post #1 of 6 Old 04-10-2009, 03:26 PM - Thread Starter
Jack White's Avatar
I mean does laservue suffer from any other problems like motion blur, low motion resolution, rainbows, green phosphor trails(it probably doesn't even use phosphors), bad geometry, etc? Also, do you think the price will come down a lot and will they have a smaller size in 2009?
Jack White is offline
post #2 of 6 Old 04-10-2009, 03:37 PM
tbird8450's Avatar
Liked: 33
Silk screen effect.
tbird8450 is offline
post #3 of 6 Old 04-11-2009, 07:08 AM
Rick46's Avatar
Stopped making them. Supposed to be fixing a problem.
Rick46 is offline
post #4 of 6 Old 04-11-2009, 09:02 AM
HarrisonS's Avatar
Despite all the hype, I feel that RPTV's are about the worst technology out there today, and, to my knowledge, only Mitsubishi and Samsung still make them. They made some sense back when a 50" 720p plasma went for $20k, and are sort of the "low cost big screen". They are very directional (far more so than any LCD today), are dim and have an uneven screen brightness, being dim around the edges with a bright spot in the center. The only way to avoid this uneven illumination would be to sit very far back, and that would defeat the purpose of having a big screen in the first place! If you buy one of these, I think you will have a real dinosaur on your hands in a couple of years!
HarrisonS is offline
post #5 of 6 Old 04-11-2009, 11:31 AM
"Don't PM Me Bro"
RandyWalters's Avatar
Quoted: 76 Post(s)
Liked: 467
Why is this even in the Flat Panel forum? There is still a Rear Projection forum - it belongs there.
Randy
TC-P55ST60, TC-P50GT50, TC-P46G10, TH-42PZ700U, TH-42PX50U, HP LC2600N, TiVo Series3, TWC Cisco 8742HDC DVR, Onkyo TX-SR333, URC R40 Remote.
Pic of My A/V setup - http://cdn.avsforum.com/f/f1/900x900..._Img_4867.jpeg
Gallery - http://www.avsforum.com/g/a/2082686/randywalter...
RandyWalters is offline
post #6 of 6 Old 04-13-2009, 07:14 AM
HarrisonS's Avatar
Originally Posted by randywalters View Post
why is this even in the flat panel forum? There is still a rear projection forum - it belongs there.
+1.
Reply Flat Panels General and OLED Technology
User Tag List
