Edge lit vs back lit LED driven LCDs': What's the big deal other than being thinner? - AVS Forum
post #1 of 48 Old 01-02-2010, 07:02 AM - Thread Starter
videobruce's Avatar
Quoted: 92 Post(s)
Liked: 121
Other than these edge lit LED driven LCD sets are thinner, is there any other advantages?
Do they both have the same power consumption?
Are they more or less prone to hot spotting/flashlight/uneven background levels?
I did look at that now closed thread regarding Samsung Edge lit LCD sets, but other than the thinner part, I didn't read any other differences.
I do know that 'local dimming' is not possible (debatable if that is any issue) and there is cost difference.
Abundant OTA television is what makes this country different from all others. Lets keep it this way.
The Internet is no place for streaming video.
videobruce is offline
post #2 of 48 Old 01-02-2010, 09:35 AM
BillP's Avatar
Liked: 38
Not sure what yo are asking. The edge lit LEDs produce better blacks than regular LCDs. But the back-lit, local-dimming LEDs are even better (and more expensive). All LCDs/LEDs still suffer with off-angle viewing.
BillP is offline
post #3 of 48 Old 01-02-2010, 02:05 PM
drfreeman60's Avatar
Liked: 47
+1
David Freeman
drfreeman60 is offline
post #4 of 48 Old 01-02-2010, 04:59 PM
TVOD's Avatar
Quoted: 74 Post(s)
Liked: 68
One difference is that the light from the LEDs are near monochromatic, meaning the red, green and blue colors are very pure. Florescent lighting is broadband meaning the RGB filtering was accomplished purely with the filters on each LCD element. With LEDs there is only the light at the primary wavelengths which decreases the amount of crosstalk. What this leads to is a wider color gamut - deeper saturated colors. That's not really taken to full advantage if one limits the gamut to rec709 (which is recommended).
A second advantage is that LEDs are more power efficient.
TVOD is offline
post #5 of 48 Old 01-03-2010, 07:15 AM - Thread Starter
videobruce's Avatar
Quoted: 92 Post(s)
Liked: 121
What's the big deal other than they are thinner?
I don't know how much clearer I can ask this? Is that the only difference, the thickness of the panel?
The edge lit LEDs produce better blacks than regular LCDs'.
Better than back lit (w/o local dimming)??
Understood, but back and edge lit sets use white LEDs' don't they? How could they use a tri-colored arrangement other than those monster stadium sized displays that use LEDs' for the actual pixel elements?
Then the actual panel of a LED driven set is different than a panel for a CCFL diver display?
But, are edge lit sets more efficient than back lit?
post #6 of 48 Old 01-03-2010, 11:03 AM
walford's Avatar
All LCD panels are backlit and there are three principal ways to do this that I am aware of.
1. Use close coupled floursant lighting(CCFL) directly behind the LCD panel
2. Use LEDs mounted on the edges of the screen to uniformly provide backlighting to all of the LCD panel.
3. Use local dimmng LED lighting direcly behind the LCD panel and control the amount of backlighting in each local zone so as to maximize the zones contrast.
The best method for both maximizing contrast and reducing power consumption is with local dimming and the CCFL method uses the most power and provides the poorest contrast.
walford is offline
post #7 of 48 Old 01-04-2010, 05:10 AM - Thread Starter
videobruce's Avatar
Quoted: 92 Post(s)
Liked: 121
If you don't mind halos around high contrast objects, namely text; as in credits, titles, CC, etc. Helps one problem (looks good on paper), but creates another.
After reading a few reviews of LCD sets, the drawback with edge lit sets is poorer viewing angle. Blacks become grayish, whites become grayish. Apparently, it's even worse than CCFL LCD sets over DLP RPTVs' and Plasmas'.
post #8 of 48 Old 01-04-2010, 10:49 AM
8mile13's Avatar
Quoted: 212 Post(s)
Liked: 214
My xbr5 is three years old,i don't see a revolutionary better lcd on the market
right now.
8mile13 is offline
post #9 of 48 Old 01-04-2010, 11:01 AM
Nielo TM's Avatar
CCFL is inferior to the current direct-LED approach, but it's superior to the current Edge-LED approach.
And direct-LED doesn't improve the CR over-CCFL unless something is applied between backlight and the LCD layer.
Nielo TM is offline
post #10 of 48 Old 01-04-2010, 11:18 AM
Nielo TM's Avatar
They have several advantages:
1. Slimmer profile means manufactures can cut cost in production, transportation and storage.
2. CCFLs suffer from power-up and shutdown latency, which is negligible on LEDs. So backlight strobing can be implemented accurately to reduce hold-time thus improving motion resolution.
3. LED helps to eliminate CCFL trailing.
4. Direct-LED approach can be used to achieve below 0.01cmd2
5. Certain type of filtration can be applied to the LGP to improve the black level of direct-LED systems
6. LED emits less heat, which may improve the life of the unit
and so on...
Yes
I would say about the same.
ATM, edge-LED systems suffer from uneven luminance. The new Philips LCD supposedly matches the KURO in terms of black level performance (when viewed directly). However, I doubt it has the same level of uniformity as the KURO.
http://www.flatpanelshd.com/review.p...&id=1236858201
Nielo TM is offline
post #11 of 48 Old 01-05-2010, 05:58 AM - Thread Starter
videobruce's Avatar
Quoted: 92 Post(s)
Liked: 121
For cutting cost; maybe For transportation; probably since they are lighter. And for storage; maybe. When I saw the box a friends plasma came in, I thought it was a RPTV. The size of the box was only a few inches less in depth. I could almost get my RPTV in his box.
None of that addressed the question of back vs edge lit LED, only CCFL vs LED which the thread is not about.
LGP???
ATM??? Doing some on line banking?
post #12 of 48 Old 01-05-2010, 06:07 AM - Thread Starter
videobruce's Avatar
Quoted: 92 Post(s)
Liked: 121
How's this for a list;
Edge lit LED driven LCD displays;
Pros;
1. Thinner panel (AFAIC it's the only selling point. Just another 'con', they still stick out from a wall),
2. Less weight.
Cons;
1. More expensive,
2. Local dimming can't be used,
3. Uneven brightness (brighter towards the corners),
4. Even narrower viewing angle (if LCDs' already have enough of a issue here).
post #13 of 48 Old 01-05-2010, 06:15 AM
rambonea4d's Avatar
There is a thread in the LCD forum where LG has announced an edge-lit led with local dimming for 2010. Might be better to wait if you're still undecided.
rambonea4d is offline
post #14 of 48 Old 01-05-2010, 08:08 AM
xrox's Avatar
Liked: 50
Cons;
Local dimming systems for edge-lit LED-LCD are under development.
Over thinking, over analyzing separates the body from the mind
xrox is offline
post #15 of 48 Old 01-05-2010, 08:59 AM
Nielo TM's Avatar
I've included all there and I don't see the problem of mentioning CCFL. After all, the LG L8000 series is powered by CCFL and has similar profile compared to its older brother.
http://www.avforums.com/forums/lcd-l...000-l9000.html
LGP???
Short for Light Guide Plate
Nielo TM is offline
post #16 of 48 Old 01-05-2010, 09:01 AM
Nielo TM's Avatar
Samsung should be unveiling their version in few weeks (CES 2010)
Nielo TM is offline
post #17 of 48 Old 01-05-2010, 09:04 AM
Nielo TM's Avatar
Cons;
1. More expensive,
For now yes. But in time, it will become cheap
Not true
That's due to the current LGP tech. Future LGP technology may help to eliminate the issue.
We do not know if that is due to the higher operating frequency of the panel or because of the current LGP.
But what I can tell you is that the 46B750 also has narrow viewing angles.
Nielo TM is offline
post #18 of 48 Old 01-05-2010, 09:33 AM - Thread Starter
videobruce's Avatar
Quoted: 92 Post(s)
Liked: 121
And so are OLED's. I was discussing what is here now, not 6 months from now (first on the block' technology; i.e.; unproven).
Because the thread is about LED lighting, not CCFL.
I'm going by the reviews of some of these Edge Lit LCD sets where the reviewer talks about a narrower viewing angle over the back lit models.
post #19 of 48 Old 01-05-2010, 09:48 AM
Nielo TM's Avatar
Why no love for the CCFL? It is our friend and we must never forget it.
When you are alone in a dark room (depressed and wondering when the world is coming to an end), who is there to light the LCD and provide hours of empty joy?
Nielo TM is offline
post #20 of 48 Old 01-05-2010, 09:59 AM - Thread Starter
videobruce's Avatar
Quoted: 92 Post(s)
Liked: 121
Power hog. LED driven sets pretty much remove LCD sets from the power hog list (i.e.: Plasma).
post #21 of 48 Old 01-05-2010, 10:00 AM
Nielo TM's Avatar
Yes, it take a little more juice, but it has served as well for the past 30-40 years
PS: Plasma make its up providing superior image. By plasma, I means the Neo-PDP and KURO.
Nielo TM is offline
post #22 of 48 Old 01-05-2010, 07:17 PM
Justin89t's Avatar
Is it a safe statement to say that a mid range EDGE LIT LED LCD will provide a better picture than a high end CCFL set, or is it to general of a statement?
Also, based on the comments here I'm guessing Plasma TV's use a lot of energy?
Justin89t is offline
post #23 of 48 Old 01-06-2010, 05:41 AM
Nielo TM's Avatar
No
CCFL still has the upper hand. But that may change this year.
If you compare using static white, yes.
But on average, it's not that high
Nielo TM is offline
post #24 of 48 Old 01-06-2010, 05:48 AM
greenjp's Avatar
Liked: 25
They typically use more than an LCD. However it's not a lot, and any talk you hear using terms like "power hogs" and "space heaters" is overblown nonsense. The difference between an LCD and a plasma is about as much as a couple light bulbs. I do not believe there's much of a return on investment in electricity savings given the increased cost/area of an LCD.
jeff
greenjp is offline
post #25 of 48 Old 01-06-2010, 06:25 AM - Thread Starter
videobruce's Avatar
Quoted: 92 Post(s)
Liked: 121
Read the previous negatives.
Those terms are NOT overblown and they sure aren't nonsense!
Apparently you haven't compared LED driven LCDs' with Plasmas'.
post #26 of 48 Old 01-06-2010, 06:51 AM
whitetrash66's Avatar
direct backlit local dimming LED is far superior to CCFL in contrast ratio, as the separate areas of the screen can be dimmed or turned completely off while another area can be extremely bright at the same time. CCFL is better than edgelit LED IMO, but far inferior to local dimming LED. With a GOOD local dimming set, the only blooming that will be noticed will be during credits or names on a black screen, and you can always turn down the backlight a bit if it bugs you. But you won't see much blooming (if any) during regular content.
whitetrash66 is offline
post #27 of 48 Old 01-06-2010, 07:41 AM
greenjp's Avatar
Liked: 25
Oh God, this has been gone over ad nauseum but I must. I don't know how I can refute powerful assertions made in bold ALL CAPS italics, but I will try, with some data and logic.
The smallest electric space heater you can buy uses 1,500 watts. A typical 50" plasma uses 250-325 watts per CNet and Crutchfield. So, despite the fact that these sets use 5 to 6 times less energy (and thus produce 5 to 6 times less heat) than an actual space heater, it's not nonsense to equate them? I'm all for good metaphors but they should at least make sense.
As for the difference with LCD, a typical CCFL 52" set uses in the 130-180 watt range. LEDs look to use 100-130 watts.
As I said, the plasmas generally use more power. No shock or argument there. The question is, how much more and what's the consequence? Looks to me like it's about 100-150 watts more than CCFL and 150-200 watts more than LED. 100 watts is a common, medium brightness light bulb size. ergo, my comment that the difference amounts to a couple of light bulb's worth.
But you're going to save a lot of money on electricity with that LED set right? Let's say you use it 8 hours a day and pay 10 cents per kW-hr. At 200 watts less than the plasma, you'll save $58 a year - less than $5 a month.
But, you have to pay a lot more upfront for those savings. Using the G10 and UN6000 for comparison's sake, it looks like the LED will run you an extra $750 for a 46" and $900 for a 55". Your ROI window is 13+ years!
jeff
greenjp is offline
post #28 of 48 Old 01-06-2010, 09:13 AM - Thread Starter
videobruce's Avatar
Quoted: 92 Post(s)
Liked: 121
Depending on how critical you are. Your statement is flawed without the word "may". No different than saying if one will see rainbows when viewing a DLP set. I use to when I was looking for them, but it's rare that I see them now.
With a handle with the word "green" in it, I would expect something different than the "bottom line". There is far more than the dollar saving to the customer. You are missing the big picture.
post #29 of 48 Old 01-06-2010, 09:22 AM
jeff
I agree that the power difference is non-important when a person is paying over $1000 (or much much more) for a TV. If it's only going to be $100 or less a year, that's less than $10 a month. pretty small in comparison to the price of the TV/programming fees/movie rentals/purchases. If i liked TV-A over TV-B but it would cost me another $75 a year, i would still get TV-A.
post #30 of 48 Old 01-06-2010, 09:38 AM
greenjp's Avatar
Liked: 25
Alas, the green in my username has nothing to do with environmentalism.
Anyway, I agree with you, and if a particular consumer values the extra "greenness" of the lower power consuming LED, then by all means factor that into the decision.
However, I'd suggest that self-congratulations and waving the green banner because you chose LED over plasma when buying a new television set (that let's face it you don't really need) that was manufactured overseas (by lower-paid workers) and transported across the ocean to your house (on ships that burn heavy fuel oil) is meaningless window dressing.
I'm not trying to poo-poo energy saving or environment-concious actions or anything. I've got CFLs in my house, my wife and I just bought a 4 cylinder stick shift Accord instead of a V6 auto (I figure we'll use 1,000 gallons less gas over it's life), blah blah blah. Just pointing out that in the "big picture" what TV you choose has a miniscule impact on your enviro footprint.
jeff
greenjp is offline
Reply Flat Panels General and OLED Technology
User Tag List
