Dynex 24" Mount Question - AVS Forum
post #1 of 4 Old 09-26-2010, 12:51 PM - Thread Starter
dudeman135's Avatar
I just purchased a Dynex 24" DX-24L150A11. The specs page for the screen lists the following:
Mount Bracket/VESA Pattern 400mm x 400mm
However, I measured the distance between the holes and it is 125mm x 125mm (just under 5 inches). Where does the 400mm x 400mm come from? Having never wall mounted a TV before, I'm trying to figure out if the specs are wrong or if I'm not understanding how to measure properly?!
I wanted to get one of the MonoPrice single stud swivel/tilt mounts, but when I did a chat with a MonoPrice rep he looked up the TV and also came up with 400x400 and showed me mounts compatible with that size and they were for huge TVs 100lbs+, this TV is only 10lbs.
If the distance between the screw holes is 125mm, isn't that the size mount I should be looking for? Thanks ahead of time for any info.
dudeman135 is offline
post #2 of 4 Old 09-27-2010, 08:45 PM
RBethel's Avatar
I had a 26" Dynex mounted on the wall and I'm pretty sure it was 125 X 125mm. I gave the set to my mom and mounted a 40" Sony (37 lbs.) on the same mount. I had to buy as adaptor plate to accomodate a 400 X 400 mm Vesa. The wall mount was good to 50 lbs. I think maybe the information you're getting is a "typo".
RBethel is offline
post #3 of 4 Old 09-28-2010, 06:09 AM - Thread Starter
dudeman135's Avatar
Thanks, I think so too, but just to be sure I also emailed Dynex support last night to see what they say. Any chance you know what mount you bought that would accommodate 125mm x 125mm?
post #4 of 4 Old 09-30-2010, 03:40 PM - Thread Starter
dudeman135's Avatar
Well, the problem was 2 fold. The online metric ruler I printed out apparently got compressed a bit, making my calculation off. It was actually 100mm x 100mm. So my calculation was off and the specs on both the Best Buy and Dynex website are wrong. I purchased a 100mm x 100mm mount and connected right up and works great. I will try to get Best Buy/Dynex to fix that. What a pain.
Reply Flat Panels General and OLED Technology
User Tag List
