Buying my first TV so a little help is needed. - AVS Forum
post #1 of 11 Old 05-27-2012, 08:40 AM - Thread Starter
Zasekamoz's Avatar
1. Budget
I'm willing to spend around 900€ = 1 130$
2. Seating distance
From 9' to 11'.
3. Size/placement limitations
I have no placment limitations. Looking at 46" to 48".
4. Uses and sources
The only device that will be connected to TV is my PC (trough HDMI). I will be using my TV only for watching movies and series. I will not watch sports, won't play games or to be more exact i will not connect my TV with cable TV or inernet TV.
I will mainly be watching HD material (Full Blu-Rays, 1080p encodes). I watch SD material (DVD9 sources) only when series/movies don't exist in HD.
HD - 70%
SD - 30%
5. Room lighting
I would say "almost dark". There is no bias lighting.
6. Important factors:
- Very important to me is 1080p/24 or 24p compatibility!
- Best PQ possiable.
- Preferably i would like to have LCD Full LED (if possible).
- I don't care about 3D so this is an important factor.
- Since i'm from Europe i can't use and don't need "Internet streaming services" like Netflix and Hulu.
- I also don't need services like Pandora, Rhapsody, Picasa, Flickr, access to Facebook, Twitter, and even Skype.
Zasekamoz is offline
post #2 of 11 Old 05-27-2012, 09:15 AM
8mile13's Avatar
Quoted: 219 Post(s)
Liked: 215
Best PQ possible you won't get for that kind of money.
Best LCd's PQ wise are the Full Array Local Dimming LED LCd's, they cost lots of money. Plasma has simular kind of PQ for half the price. Consencus is that Plasma give's the best movie'ish experience. This year's Panasonic Plasma's are well received. I own a LED and enjoy my movies never the less
I would go for a 50inch, you have to keep in mind that black bar movies will shrink your screen. The bigger your screen the better the experience. Buy the biggest screen you can handle
Recent VE Shootout winner was 65VT50 Plasma, second was the Elite Pro 60X5FD full array Local Dimming LCd (not for sale in Europe) which is twice as expensive...
http://reviews.cnet.com/8301-33199_7...lity-shootout/
not all LED are equal
http://reviews.cnet.com/2795-6482_7-399.html
You should check out LCd/Plasma input Lag, could ruin your gaming experience
LCd input lag
http://www.avsforum.com/avs-vb/showthread.php?t=1131464
Plasma input lag
http://www.avsforum.com/avs-vb/showthread.php?t=1166196
8mile13 is online now
post #3 of 11 Old 05-27-2012, 09:31 AM - Thread Starter
Zasekamoz's Avatar
@8mile13: Thank you for your quick reply.
I meant best PQ for 900€. I think that i can't buy 50inch LCD LED TV for 900€ (they are more expensive). I don't want to buy plasma because our familys plasma did have "burn-in probleme". I my previous post i made a mistake. I will not play games on my TV so i don't need gaming TV.
So 8mile13 wich LCD LED TV would you recommend?
post #4 of 11 Old 05-27-2012, 10:07 AM
kmetek's Avatar
kmetek is offline
post #5 of 11 Old 05-27-2012, 10:43 AM
8mile13's Avatar
Quoted: 219 Post(s)
Liked: 215
+ Sony 46HX720 <^^ are Edge Lit.
When you buy a Edge Lit you will see imperfections most in a dark environment so if i was you i would check the TV out in a dark environment (dark scenes!) soon after you bought it and see if you can live with it, if not return it and consider more expensive Sharp (full array without Local Dimming) or Plasma - modern Plasma's have temporary burn-in, not something to worry much about, should prevent torch mode and static screen. good luck!
post #6 of 11 Old 05-27-2012, 06:31 PM - Thread Starter
Zasekamoz's Avatar
Originally Posted by kmetek View Post
46es6100 samsung
46pfl5007 philips
Samsung 46ES6100 costs 1.140,49 but my budget is only 900.
post #7 of 11 Old 05-27-2012, 06:33 PM - Thread Starter
Zasekamoz's Avatar
SONY LED TV KDL-46HX720 3D costs 1.149,00€ but my budget is only 900€ (that is 1130$)
post #8 of 11 Old 05-28-2012, 08:30 AM
topr's Avatar
Full array is not going to happen at your price point even if you could find something in your size...your best bet is to look for an NX720. Good display and they have been out long enough to find one discounted. Keep an eye on slickdeals.
topr is offline
post #9 of 11 Old 06-01-2012, 04:26 PM - Thread Starter
Zasekamoz's Avatar
Which models have better PQ D6xxx or ES6xxx or EH6xxx? I would like to buy 55inch TV and there is a big money difference.
- Samsung UN55ES6100 is $1,579.99
- Samsung UN55D6000 is $1,259.00
- Samsung UN55EH6000 is $909.93
Any recommendations or suggestions will be welcome.
post #10 of 11 Old 06-02-2012, 12:20 AM
Joxer's Avatar
The EH6000 series doesn't use edge lighting, so it reportedly has none of the flashlighting effects, and the sets are thicker than the ultra-thin ES models that use LED edge lighting.
Reports are that the new ES models are superior to last year's D series with regards to effects like flashlighting too.
Joxer is offline
post #11 of 11 Old 06-02-2012, 06:17 AM
8mile13's Avatar
Quoted: 219 Post(s)
Liked: 215
Aim a bit higher than you are willing to spend then wait till prices drops
Reply Flat Panels General and OLED Technology
User Tag List
