Samsung UE46ES5505 audio problem - AVS Forum
post #1 of 3 Old 06-27-2012, 08:10 AM - Thread Starter
christiansenn's Avatar
Hi,
I Have the 46 UE46ES5505 Samsung Smart tv with 1021 firmware.
Problem is that I have external loud speaker and it all worked fine for few weeks
Now suddenly if waiting 10-20 mins it just loose signal to the loud speaker.
When if i go in the menu and click up and down it works again..
I tried the loud speaker on a PC and no problems what soever.
So it is like the samsung tv loose the signal?
christiansenn is offline
post #2 of 3 Old 06-27-2012, 11:43 AM
Mik James's Avatar
Liked: 36
Don't wire your sound through your tv?
Mik James is online now
post #3 of 3 Old 06-27-2012, 11:46 AM - Thread Starter
It happens after new 10.21 firmware and exactly after 30 mins..
I even called the samsung support, poor service..
they just keep saying use a samsung external speaker and trying to say my device is not compatible even it worked for few weeks before upgrade.
Then I ask if I can downgrade and they say no.
Reply Flat Panels General and OLED Technology
Samsung , Displays , Samsung 46 Inch Led Smart Tv Ue46es5505
