NEED LCD HELP ASAP - AVS Forum
post #1 of 6 Old 06-30-2012, 04:33 PM - Thread Starter
Robert Greenhoe's Avatar
I have a 53" SONY bravia LCD and I need to repair it, I attached a photo of the issue, if anyone has any info on how to fix it please let me know
450
Robert Greenhoe is offline
post #2 of 6 Old 07-02-2012, 06:35 PM
steve1022's Avatar
Liked: 31
I'm not a repairman so the only suggestion I have it to try to factory default reset it and see if it helps at all.
Vizio M601D-A3R w/ Vizio VSB207BT soundbar and Yamaha YST-SW215 Sub | Vizio M501D-A2R | PS3 Slim | PS4 | Harmony 650 Remote | DirecTV Genie WHDVR
steve1022 is offline
post #3 of 6 Old 07-02-2012, 11:33 PM
Chronoptimist's Avatar
Liked: 203
Your TV has clearly been impacted by something in the lower-left corner. Cost of replacing the panel (parts + labour) will be more expensive than replacing the set.
Chronoptimist is offline
post #4 of 6 Old 07-03-2012, 07:44 AM
Gary McCoy's Avatar
Liked: 39
Your HDTV is a total loss caused by abuse, a physical impact to the screen which has broken the glass substrate used for the LCD cells. It is not economicly repairable because of the cost of the panel which is about 70% of the HDTV and most often unavailable.
You may be able to make a homeowner's insurance claim. Decide if that is wise before doing so.
Gary McCoy
The United States Constitution ©1791. All Rights Reserved.
Gary McCoy is offline
post #5 of 6 Old 07-12-2012, 10:36 PM
leftcoastjayhawk's Avatar
leftcoastjayhawk is offline
post #6 of 6 Old 07-30-2012, 11:26 AM
maladjusted's Avatar
you could buy 2 new 55" sony tvs for what it would cost to get a replacement lcd panel for a W/V 4000. Seriously:eek:
"Do your best & don't worry"
maladjusted is offline
Reply Flat Panels General and OLED Technology
Lcd Hdtv , Displays , Sony , Sony 32 Bravia Lcd Hdtv Kdl 32ll150
User Tag List
