Buying decision is starting to wear me down - AVS Forum
post #1 of 9 Old 08-17-2012, 07:12 PM - Thread Starter
bemgolf4's Avatar
This will be a quick question. I was going to get either of the Samsungs
Samsung - 60" Class / LED / 1080p / 240Hz / Smart / 3D / HDTV
Model: UN60ES7500FXZA
or
Samsung - 65" Class - LED - 1080p - 240Hz - Smart - 3D - HDTV
Model: UN65D8000X
both have good ratings which one should I get?
Usage:
TV and sports 60%
Playstation 3 35%
Movies 5%
I am intrigued with projection TV. My first question since I just started looking into them would be are the pictures as good as a LED with a 240hz refresh rate. I like the fact that the screen would be hugh and I would guess they would be in the same ball park as the LED as far as price for the projector itself. I would imagine that cost of the screen would push the price over $3000.00. I was wanting advise either on the top two Samsungs or your thoughts on the projector option.
Really all I want is big screen and great picture quality.
How far is the projector placed from screen?
How ofter are the lamps replace?
How much to replace them?
Thanks for all the help.
bemgolf4 is offline
post #2 of 9 Old 08-18-2012, 12:22 AM
rogo's Avatar
Quoted: 20 Post(s)
Liked: 375
Don't get the 65", it was last year's model and not especially good. Get either the 60" Samsung ES or a Panasonic VT 65" plasma from 2012.
There is no difference in HDMI cables. If you can see the picture without visible dropouts or sparklies, the cable is working at 100%. No other cable will display a better version of that picture. You're simply wrong if you think there is a better digital cable than one that is already working.
rogo is offline
post #3 of 9 Old 08-20-2012, 08:35 AM
JMUdukes07's Avatar
If I was spending ~$3,000+ on a new display there is absolutely no way that I'm not going for the Panasonic 65VT50.
That set would absolutely destroy either of the two LED's that you mentioned.
JMUdukes07 is offline
post #4 of 9 Old 08-20-2012, 10:22 AM
[Irishman]'s Avatar
Liked: 47
+1,000
[Irishman] is offline
post #5 of 9 Old 08-22-2012, 08:01 AM - Thread Starter
bemgolf4's Avatar
This Panasonic you mention on amazon and BB have the same ratings? I also am not interested in a plasma. The screen is too dark for the room and although they have come a long way with the burn in effect. If you don't buy it you will not have to worry about it . Also if you are an HD fanatic you may notice a difference but for the average Joe how much better can it really be. I mean I have gone to the stores and the ones I have been looking at at outstanding with different things that I have seen on the screens. I will not be looking at it with a magnify glass like some of these tech freaks.
bemgolf4 is offline
post #6 of 9 Old 08-22-2012, 11:30 AM
vinnie97's Avatar
Quoted: 213 Post(s)
Liked: 1000
It's your prerogative if you want to spend more for less. wink.gif The new Panasonics get plenty bright. Torch mode is no way to watch any TV. BTW, my 2008 Kuro has never exhibited burn-in (and IR that only lasts for mere seconds), so I would say Plasma tech has been pretty stagnant in that regard.
vinnie97 is offline
post #7 of 9 Old 10-29-2012, 12:56 PM
agogley's Avatar
A projector would only be recommended, IMHO, if you are looking at HUGE screen sizes of 90"+. For example, if you were going to have a HT with a 120" screen, then FP would be the way to go. Having experienced FP at others' homes, I would not recommend it for normal TV viewing unless you'll be able to keep the lighting very dim. A FP looks terrible in normally lit environments even with the best of projectors. BTW, a screen for a FP is going to be costly for a decent one. And a screen has a huge impact on image quality.
I think you'll be more than satisfied with the 60" Sammy or the 65" Panny, unless you really want something bigger.
As for lamps on a FP, I don't think you should expect to replace them often. You'll probably want to replace the projector before the lamp (due to some future technology upgrade). But if you did have to replace one, you're probably looking at a couple hundred dollars, at least.
agogley is offline
post #8 of 9 Old 10-29-2012, 01:06 PM
agogley's Avatar
These are just myths. PDPs aren't "dark." You'd probably not even be able to tell which is a PDP and which an LCD if you weren't told. And "burn-in" is just a scary bedtime story that LCD fanboys like to spread around the forum. Burn-in isn't possible, except in theory, on any modern plasma and this has been true since before Pioneer stopped selling PDPs.
Having said my peace, if you want LCD then the common consensus is to choose the 60" Sammy over the 65" if those are the two from which you want us to choose.
agogley is offline
post #9 of 9 Old 10-29-2012, 04:06 PM
Artwood's Avatar
Quoted: 18 Post(s)
Liked: 196
Hurry! Quick! Buy a 65-inch Panasonic VT-50 before Panasonic gets out of the plasma business and we enter the video sewer of OLED that costs trillions and LCD that SUCKS!!!
Artwood is offline
Reply Flat Panels General and OLED Technology
User Tag List
