Which is better..? Back or edge lit? - AVS Forum
post #1 of 12 Old 11-29-2012, 05:13 AM - Thread Starter
TroyHR's Avatar
My friend has a 240 hz Visio back lit and I have a 240 hz edge lite Visio......Is his better?
TroyHR is offline
post #2 of 12 Old 11-29-2012, 06:21 AM
qwknuf6's Avatar
Liked: 89
back lit is better than edge lit
qwknuf6 is offline
post #3 of 12 Old 11-29-2012, 10:49 AM
Dierkdr's Avatar
Liked: 52
Define "Better."
A well-designed back-lit set should be capable of out-performing a well-designed edge lit set - probably at least in terms of Uniformity and View Angle, and particularly if the back-lit panel implements a decent Local (Zone) Dimming scheme.
Still, would not be surprised at all if a Well Designed Edge Lit panel outperformed a Cheap (Poorly Designed) Back lit set....
Dierkdr is online now
post #4 of 12 Old 11-29-2012, 12:50 PM
mr. wally's Avatar
Liked: 47
does it make a difference whether the back light is ccfl or led?
i have never used a lcd/led display
neflixis our nemesis
mr. wally is offline
post #5 of 12 Old 11-29-2012, 05:08 PM
8mile13's Avatar
Quoted: 67 Post(s)
Liked: 187
LED has a slightly different look/worse off-axis performance. CCFL needs a warmup period (15-30 min)/is less bright. Improvement - better blacks - you will only get with the full array local/zone dimming stuff.
Why LED does not mean a better picture
http://reviews.cnet.com/8301-33199_7-57337192-221/why-led-does-not-mean-a-better-picture/
8mile13 is offline
post #6 of 12 Old 11-30-2012, 02:16 AM
Joe Bloggs's Avatar
Quoted: 47 Post(s)
Liked: 42
Do local-dimming LED back-light TVs with local dimming enabled remove details that should have been shown, in order to increase contrast (such as dimming some zones too far to increase the contrast between dark & bright areas)? Do all local dimming TVs do this or just some? Is there a link that shows which have the best local dimming algorithms - ie,. ones that don't remove details that should be shown (if that's what some are doing)? Also, some will have more zones too. Is there a link which goes into all this eg. how many LEDs/zones each TV has, type of LED back-lighting, how good the algorithm is/whether removes details etc.?
Joe Bloggs is offline
post #7 of 12 Old 11-30-2012, 06:22 AM
8mile13's Avatar
Quoted: 67 Post(s)
Liked: 187
There was an internet article in which the sony xbr8 Local Dimming and the pioneer kuro krp 500 were compared. They included photo's of the stars at night comparison and remarked that several stars disappeared on the xbr8. I do not believe that there has been a drastic improvement in this regard, seems to be a Local Dimming problem.
Joe Bloggs likes this.
8mile13 is offline
post #8 of 12 Old 11-30-2012, 06:32 AM
andy sullivan's Avatar
Quoted: 34 Post(s)
Liked: 131
Not all full array back lit or edge lit panels are created equal. Everything being equal the full array version should provide better screen uniformity. A good full array panel is more expensive to build which is why the vast majority of panels are edge lit. I don't think you'll find any local dimming panels that are not full array.
andy sullivan is online now
post #9 of 12 Old 11-30-2012, 07:41 AM
8mile13's Avatar
Quoted: 67 Post(s)
Liked: 187
Edge Lit
Edge Lit with Local Dimming
Full Array
Full Array with Local Dimming
LED TVs compared: local dimming, edge lit, and full array
http://reviews.cnet.com/2795-6482_7-399.html
videobruce likes this.
8mile13 is offline
post #10 of 12 Old 12-01-2012, 11:16 PM
hoozthatat's Avatar
Liked: 38
In all seriousness I'd prefer the backlit. Case and point look at Samsungs EH6000 compared to ES6100. Nearly identical panels, I wouldn't put either of those in the cheap boat, and IMO the EH6000 outperforms with brightness uniformity, off axis, and black levels. Every pro review I've read on the two gives the EH series the nod as well, unless you absolutely want smart functionally, which is easily obtained through WDTV or etc.
60F8000; RX-V367; TSi300 x2; YST-SW102; Harmony 650; Apple TV; Microsoft Xbox One Console; RF-HTS120;
xRite i1 Display Pro (OEM); CalMAN 5 Basic; ColorHCFR
hoozthatat is offline
post #11 of 12 Old 12-04-2012, 04:32 PM
hoozthatat's Avatar
Liked: 38
Actually from LG the LM6700 series and up are all edge lit local dimming, except for the LM9800 which is a full array with local dimming
From Samsung the ES6900 series and up are also edge lit local dimming, though from what I've gathered they don't truly dim the LED's but rather use video processing to mimic dimming of the LED's.
& From Toshiba the L7200 series is also an edge lit local dimmer
post #12 of 12 Old 12-06-2012, 07:58 AM
videobruce's Avatar
Quoted: 31 Post(s)
Liked: 99
Edge lit = cheaper, less power consumption & thinner bezel, but poorer brightness uniformity,
Back lit = more expensive, even uniformity, but more power consumption and the resulting wasted heat generated.
Local dimming only really works on full array, but you pay for it.
Abundant OTA television is what makes this country different from all others. Lets keep it this way.
The Internet is no place for streaming video.
videobruce is offline
Reply Flat Panels General and OLED Technology
User Tag List
