Haier LE39F2280 mounting - AVS Forum
post #1 of 2 Old 12-24-2012, 04:52 PM - Thread Starter
monssef's Avatar
I bought this tv from amazon when it was on sale. Today I tried to mount it in the wall. First I couldnt find the screws. Second the the top 2 holes where the screws should drive in are missing the metal pieace (as shown in the picture) my question is does anybody knows the size of the screws that need to be used in this model. Also what the workaround the missing pieces.
monssef is offline
post #2 of 2 Old 12-28-2012, 08:25 PM
smsutah's Avatar
There actually aren't any missing pieces on this model. For some reason Haier decided to use brass inserts on the bottom, and threaded plastic holes at the top. You will find that correctly sized mounting screws for the bottom brass inserts will also fit the top plastic holes. The screw size is just a standard M6-1.0 (I used a 12mm length).
smsutah is offline
Reply Flat Panels General and OLED Technology
Awm Haier 39 Inch Direct Led Hdtv Le39f2280
User Tag List
