are 80+" oled tvs going to be normal? - AVS Forum
post #1 of 4 Old 04-10-2013, 11:25 PM - Thread Starter
ComputerTech0903's Avatar
Is it easier to make huge oled tvs over lcd tvs? While oled tvs havent even been released there are already alot of huge oled tvs being shown off. I thought i read large screen oled tvs are easy to make will 80+" oled tvs be normal?
ComputerTech0903 is offline
post #2 of 4 Old 04-11-2013, 01:34 AM
rogo's Avatar
Quoted: 95 Post(s)
Liked: 469
No, it's not easier. Anywhere you read that is based on a lot of bogus speculation using technology that doesn't exist.
The backplanes are the same as LCDs, the color filter layers (on LG's OLED at least) are nearly the same as LCDs, the middle layer is proving hard to build at any size. Future OLED techniques don't even exist yet and they won't be 80" and up for quite some time.
On the other hand, Sharp is showing it's really, really easy to make 80" LCDs.
There is no difference in HDMI cables. If you can see the picture without visible dropouts or sparklies, the cable is working at 100%. No other cable will display a better version of that picture. You're simply wrong if you think there is a better digital cable than one that is already working.
rogo is offline
post #3 of 4 Old 04-30-2013, 10:02 PM
Artwood's Avatar
Quoted: 27 Post(s)
Liked: 203
rogo: If you had to predict--when will be the worst year--the year when there is no 65-inch plasma--OLED costs zillions--and Substandard LCD rules the world?
Artwood is offline
post #4 of 4 Old 05-01-2013, 06:57 PM
rogo's Avatar
Quoted: 95 Post(s)
Liked: 469
So it seems likely that Panasonic won't produce new plasmas for 2015. Samsung might still. OLED will still be outrageous that year. That could be your nadir.
But if luck plays out, there will be a "last great" Samsung in 2015 and by 2016 an affordable 65-inch OLED. Or at least a $4000 one.
rogo is offline
Reply Flat Panels General and OLED Technology
User Tag List
