Do I need a digital converter box? - AVS Forum
post #1 of 6 Old 05-05-2013, 05:17 PM - Thread Starter
BChafes's Avatar
Hi,
I'm hoping you can help me. I have a Samsung SP-R4232 42" flat screen TV. I've had it since 2004 or 2005. I've always had Comcast cable, so used a cable box. But I want to try going cold turkey from Comcast and save some money with my Roku. Here's my question -- how do I get regular (network) channels? Does this TV require a digital converter box? Do I need to buy an antenna?? Do I still need something connected through the cable cord? I'm clueless on this and want to get whatever I need before I cancel my Comcast.
Thank you!
BChafes is offline
post #2 of 6 Old 05-05-2013, 06:18 PM
olyteddy's Avatar
Quoted: 42 Post(s)
Liked: 197
This says it has an ATSC tuner: http://downloadcenter.samsung.com/content/EM/200610/20061013174543343/EN/main.htm If so, get an antenna, hook it up and you'll get whatever is available OTA.
olyteddy is online now
post #3 of 6 Old 05-06-2013, 05:28 AM - Thread Starter
BChafes's Avatar
Thanks olyteddy! And now, bear with me on my lack of tech knowledge, but the only antennae I know of are the rabbit ears we had growing up. Is this they type of antennae I need? Or is there something different I should be looking for?
BChafes is offline
post #4 of 6 Old 05-06-2013, 06:38 AM
"Don't PM Me Bro"
RandyWalters's Avatar
Quoted: 56 Post(s)
Liked: 445
There are different types of antenna - good old 1960's Rabbit Ears work fine if you're not too far from your local broadcast towers (mine work fairly well for most stations in some of my rooms at 27 miles away) but i use my 1950's era roof antenna and i get a perfect signal. There are other more modern antennas available (some amplified). Some cities digital channels are all on UHF, but here in So Cal for instance some are UHF and some are VHF so a so-called new "HD Antenna" i tried wouldn't pick up any of our VHF channels, while my 50-60 year old analog antennas work perfectly for all channels. I'd play it safe and get one that does both.
To see how far you are from your towers and guidance on what type of antenna you need go to this link and enter your zip code and street address: http://antennaweb.org/
Tons of antenna info in this forum:
http://www.avsforum.com/f/25/hdtv-technical
Local broadcast Info:
http://www.avsforum.com/f/45/local-hdtv-info-and-reception
Randy
TC-P55ST60, TC-P50GT50, TC-P46G10, TH-42PZ700U, TH-42PX50U, HP LC2600N, TiVo Series3, TWC Cisco 8742HDC DVR, Onkyo TX-SR605, URC R40 Remote.
Pic of My A/V setup - http://cdn.avsforum.com/f/f1/900x900..._Img_4867.jpeg
Gallery - http://www.avsforum.com/g/a/2082686/randywalter...
RandyWalters is offline
post #5 of 6 Old 05-06-2013, 08:48 AM - Thread Starter
BChafes's Avatar
THANK YOU! This has been so helpful! I'm going to look into antennas today! Appreciate the help.
BChafes is offline
post #6 of 6 Old 05-06-2013, 09:49 AM
Otto Pylot's Avatar
Quoted: 91 Post(s)
Liked: 227
If you go to TVFool you can put in your address and it will show you all of the stations that are available to you for your location. Then I'd post that info in the Local HDTV Info and Reception forum that is specific to your area. The regulars there will then recommend the best type of antenna for you to use.
Otto Pylot is online now
Reply Flat Panels General and OLED Technology
Samsung Sp R4232 42 Ed Plasma Tv
