Best TV Under $900 - AVS Forum
post #1 of 2 Old 07-29-2013, 08:48 PM - Thread Starter
Fredrick00's Avatar
Howdy Everyone,
I've been having trouble deciding on a TV under $900. I find myself with 30 tabs open researching different models, then more confused than when I started. The model I seem to be drawn to is Samsung's UN55FH6030, seems to be readily available around $850. Yet, then I read poor reviews for it and become even more undecided.
I will not use 3D, and do not care if a TV has it. The set will mainly be used for watching TV and Netflix, no Blu-ray. As such, I am wondering if there isn't a TV out there that is superior to the UN55FH6030, for my needs, while under $900?
This forum seemed like the place to go for the best answer. Thank you all in advance.
-Fredrick
Fredrick00 is offline
post #2 of 2 Old 07-31-2013, 04:47 AM
"Don't PM Me Bro"
RandyWalters's Avatar
Quoted: 74 Post(s)
Liked: 464
Panasonic S60 series will blow any LCD TV away. The 55 incher should be around your budget.
Randy
TC-P55ST60, TC-P50GT50, TC-P46G10, TH-42PZ700U, TH-42PX50U, HP LC2600N, TiVo Series3, TWC Cisco 8742HDC DVR, Onkyo TX-SR333, URC R40 Remote.
Pic of My A/V setup - http://cdn.avsforum.com/f/f1/900x900..._Img_4867.jpeg
Gallery - http://www.avsforum.com/g/a/2082686/randywalter...
RandyWalters is offline
Reply Flat Panels General and OLED Technology
Samsung Un55fh6030 55 Inch Slim Led Hdtv , Panasonic Viera Tc P60s30 60 Inch 1080p Plasma Hdtv
Gear in this thread - P60s30 by PriceGrabber.com
