LG 55EA9800 55" OLED Owner's thread - Page 152 - AVS Forum | Home Theater Discussions And Reviews
 1157Likes
post #4531 of 7374 Old 06-25-2014, 09:41 AM
Foxbat121's Avatar
Quoted: 698 Post(s)
Liked: 401
Most TVs only allow ARC on one of the HDMI inputs. On this TV, it is clearly labeled on the HDMI port 1.
Foxbat121 is online now
post #4532 of 7374 Old 06-25-2014, 09:55 AM
Theplague13's Avatar
Quoted: 102 Post(s)
Liked: 328
Originally Posted by Vegas oled View Post
What is your opinion of the Darbee with this TV, is it worth it?
I love Darbee! It really is the only thing that could make such a perfect picture that tiny bit more perfect. It's almost impossible to explain it, but somehow it manages to do exactly as advertised and "lift a veil" off the image, restoring detail you've never seen before without introducing any artifacts (if left at a reasonable setting. There's no reason to Jack it up too high). I mean you can't expect miracles; it's subtle, but I can sit closer to the screen with it than I could without it for example, which feels like I'm getting some of the benefits of a higher res (darbee combined with oled kind of does feel like a higher res to me).
mr_rhythm and vaktmestern like this.
If I sow a wind now, I will reap a storm.
Theplague13 is offline
post #4533 of 7374 Old 06-25-2014, 10:00 AM
Quoted: 102 Post(s)
Liked: 328
Thumbs down
It just isn't something I've ever needed so I never bothered except to test it once. The last tv I used it on was a Sony XBR5 (non smart).
post #4534 of 7374 Old 06-25-2014, 10:00 AM
5x10's Avatar
Quoted: 606 Post(s)
Liked: 386
The oled has really shown me the limitations of current feeds(cable, Netflix, etc)
I wonder how long its going to take to get 4k into households as I don't even think my dish provider is broadcasting in 1080(I think it's 720)
5x10 is offline
post #4535 of 7374 Old 06-25-2014, 10:05 AM
Foxbat121's Avatar
Quoted: 698 Post(s)
Liked: 401
Dish providers are known to broadcasting in HD Lite (in between 720p and 1080i). Most cable companies aren't any better.
post #4536 of 7374 Old 06-25-2014, 10:12 AM
5x10's Avatar
Quoted: 606 Post(s)
Liked: 386
Thanks, I can really tell a difference between dish and Blu ray, compared to my plasma
5x10 is offline
post #4537 of 7374 Old 06-25-2014, 10:15 AM
Ken Ross's Avatar
Quoted: 5717 Post(s)
Liked: 6076
Not exactly. If they actually broadcast something in-between 720p and 1080i, your display wouldn't know what to do with it. You'd more than likely get an 'unsupported resolution'.
In actuality it's the bitrate that generally suffers with these providers, but Directv has done a much better job over the last couple of years. I don't know about Dish.
I came from FIOS to D* and notice no significant drop in PQ.
Ken Ross is offline
post #4538 of 7374 Old 06-25-2014, 10:16 AM
aaronwalker1974's Avatar
Quoted: 12 Post(s)
Liked: 30
I have a Darbee hooked up to this set as well. It is subtle, but definitely improves the picture quality.
mr_rhythm likes this.
aaronwalker1974 is offline
post #4539 of 7374 Old 06-25-2014, 10:19 AM
Ken Ross's Avatar
Liked: 6076
I've never understood why most ISF techs, including Kevin Miller who ISF's all my displays, dislike Darbee. I've always found it gives that little added 'something'.
However on the negative side, I have had issues with HDMI handshakes with the Darbee.
Ken Ross is offline
post #4540 of 7374 Old 06-25-2014, 10:22 AM
Foxbat121's Avatar
Quoted: 698 Post(s)
Liked: 401
No, the actual set top box re-scaled it to output whatever resolution your TV wants to. See here http://en.wikipedia.org/wiki/HD_Lite
There was a class action lawsuit filed against DirectTV a few years back for this exact reason. There were a lot of such discussion here in AVS as well. These days, all providers alter broadcast streams one way or another. If you want best PQ, you need to get an antenna to get OTA (that is assuming your local station didn't shave off too much bandwidth for sub-channels).
post #4541 of 7374 Old 06-25-2014, 10:23 AM
markjl's Avatar
Quoted: 18 Post(s)
Liked: 25
I'm debating about hooking up a sound bar with this TV. Does anyone know if the optical out outputs stereo if the source into the 55EA9800 is from an HDMI connection? I've read where many TV's don't pass a dolby digital or DTS signal through the optical out connection. I'm thinking of using the Paradigm soundscape sound bar which only accepts optical in and supports dolby digital and dts.
markjl is offline
post #4542 of 7374 Old 06-25-2014, 10:34 AM
Foxbat121's Avatar
Quoted: 698 Post(s)
Liked: 401
If the TV won't pass certain signal (DD or DTS), it will says so with EDID and the source device will not output such format in general. PCM 2.0 stereo guarantee works. Whether or not this TV will pass or even accept DD 5.1 remains to be tested. I have no optical device and can't tell you how this TV reacts.
post #4543 of 7374 Old 06-25-2014, 11:01 AM
markjl's Avatar
Quoted: 18 Post(s)
Liked: 25
Thanks for the reply. I'll give it a try tomorrow night. If it doesn't work I'll have to try and sneak in one of those big ugly receivers with a bunch of wires and speakers under my wife's nose.
markjl is offline
post #4544 of 7374 Old 06-25-2014, 12:11 PM
Ken Ross's Avatar
Liked: 6076
The difference is really more bit rate than resolution . Some providers starve certain channels with low bitrates. There was someone on AVS that used to measure these bitrates by channel and provider.
Now with that said, I always compare OTA PQ with the same broadcast channel on my service provider. With both D* and FIOS, I could see no difference on a 64" screen. Years ago, with D*, I could.
Ken Ross is offline
post #4545 of 7374 Old 06-25-2014, 12:17 PM
tgm1024's Avatar
Location: Sorry, chances are excellent that you're an idiot.
Quoted: 2460 Post(s)
Liked: 2231
Originally Posted by aaronwalker1974 View Post
No IR on my set. Mfg date is Feb of this year. I played 4 hours of Forza last night that has a static hud on the screen. I ran some slides this morning and no IR.
Static HUD has already been shown to be a differing case. This is not a plasma situation, and may in fact be more related to the electrical characteristics of the backplane. Slacker, ynotgoal, and xrox understand the possibilities (possible or not) of this issue the best.
vinnie97 likes this.
Thought #EAA: I wonder how many people know that no one ever says "What we've got here is a failure to communicate." in the movie "Cool Hand Luke" (1967).
tgm1024 is offline
post #4546 of 7374 Old 06-25-2014, 12:18 PM
Foxbat121's Avatar
Quoted: 698 Post(s)
Liked: 401
I guess with both sat companies switched over to H.264, the need to squeeze more bandwidth is no longer that important. Cable companies should do the same but most resisted because they still have tons of old boxes that can't handle it. FiOS did switch certain channels to H.264 last year.
post #4547 of 7374 Old 06-25-2014, 12:27 PM
Ken Ross's Avatar
Liked: 6076
What's also interesting is that depending upon the service provider, mpeg4 channels may require an mpeg4> mpeg2 conversion (or the reverse). This too can degrade PQ.
Ken Ross is offline
post #4548 of 7374 Old 06-25-2014, 12:38 PM
vinnie97's Avatar
Quoted: 213 Post(s)
Liked: 1014
That's transcoding, which is always bad. I'm all too familiar with it in the audio compression realm. It's used unscrupulously to make it look like a higher bitrate source when the audio quality itself (and/or a spectral analysis) reveals quite another story.
vinnie97 is offline
post #4549 of 7374 Old 06-25-2014, 12:42 PM
Foxbat121's Avatar
Quoted: 698 Post(s)
Liked: 401
Premium channels like HBO are primarily delivered in H.264 from the provider IIRC. My Cox provides H.264 on couple of these channels. Transcoding is inevitable. The so called rate shaping on almost all cable providers is just that.
post #4550 of 7374 Old 06-25-2014, 02:14 PM
Rf13's Avatar
Quoted: 445 Post(s)
Liked: 247
the ISP/tv providers in my area are aggressively converting everything to digital. i think with the pending att/direct tv deal and google stirring things up, none of them want to be left behind or lose dominance.
Rf13 is offline
post #4551 of 7374 Old 06-25-2014, 03:46 PM
5x10's Avatar
Quoted: 606 Post(s)
Liked: 386
Add me to the list of letterbox ir
Stopped a movie and the blu ray player screen pulled up in light blue
I could see the faint line on the top of the screen, couldn't see it in the bottom as there were varying colors
About to leave the house, I'm going to run some white screens to see if it's still present
5x10 is offline
post #4552 of 7374 Old 06-25-2014, 04:58 PM
Quoted: 102 Post(s)
Liked: 328
Damn. Sorry to hear it.
I see it more in certain spots as well though, and I think it correlates to the panel's near-black issue, because on my panel there is a spot that lightens before the rest when turning up the brightness in the lower right corner, and that is exactly where the "IR" (I don't know what to call it) first becomes visible when it happens. Whoever it was that said turning the brightness up and down affects parts of the screen seperately, that's exactly how they all are and I think the issues are related.
post #4553 of 7374 Old 06-25-2014, 05:19 PM
vinnie97's Avatar
Quoted: 213 Post(s)
Liked: 1014
Pixel jogger is another solution that's good for the problem. I find I only have to run it about the length of the offending movie to get the screen back to near baseline.
vinnie97 is offline
post #4554 of 7374 Old 06-25-2014, 07:01 PM
5x10's Avatar
Quoted: 606 Post(s)
Liked: 386
First thing I did when I came home was to turn on the exact same screen I saw the ir on
It's not there anymore, so I ran some slides(off of youtube), including grey(only a single shade and still didn't see it
Was making myself dizzy getting close to the screen trying to find dead sub pixels
Only found 2 dead blue ones
I started the movie and am going to let it run for another hour or so, then I will put the same colored slides to see if it's there
If I'm not seeing it in content, I'm ok, if it starts to become noticeable, then I have an issue
Will report back
5x10 is offline
post #4555 of 7374 Old 06-25-2014, 07:28 PM
vinnie97's Avatar
Quoted: 213 Post(s)
Liked: 1014
Run enough letterbox movies in succession, and you will. It's part of the maintenance that ownership of this set requires.
vinnie97 is offline
post #4556 of 7374 Old 06-25-2014, 07:33 PM
Quoted: 102 Post(s)
Liked: 328
You'll probably be okay, for now. But every time you watch some consecutive hours of LB you'll have to deal with it again. What annoys me is this small line in the bottom right that I incurred pre-300 hours, is completely burned in and never goes away. It's approximately 6 inches of the letterbox bar. It's pretty faint depending on the color behind it, hard to capture on camera but it shows on grays and I see it in content about 5% of the time. When I run the slides it fixes it up till the one peice of line and that's it. That was from the first time I incurred the wear.
Moral of the story: you may want to hold off on those movies until you put a few hundred hours on the panel.
post #4557 of 7374 Old 06-25-2014, 07:42 PM
5x10's Avatar
Quoted: 606 Post(s)
Liked: 386
Any other colors to look for dead pixels?
I did red, blue, green, and white
I received 5 blu ray movies today, 4 of which have lb
Looks like I'll be seeing some ir in the near future
5x10 is offline
post #4558 of 7374 Old 06-25-2014, 07:48 PM
Quoted: 102 Post(s)
Liked: 328
This is what I'm saying. So 5x10 is in the IR camp. Because it has already happened to him, unfortunately we can surmise it will happen again and again when he watches LB material. I forget if he said the manufacture date of his panel, but I find myself doubting that there are panels which are completely free of the issue. Maybe ones that are more or less resilient to it, sure. But completely devoid? How can it be? Unless they completely changed the manufacturing process, on a product that is all but discontinued...
post #4559 of 7374 Old 06-25-2014, 07:55 PM
Quoted: 102 Post(s)
Liked: 328
There are 4 subpixels. They are Red, Green, Blue, and white. This means that for every pixel each of these colors acts independently. You can check only those four, anything else will be a mixture of more than one subpixel.
post #4560 of 7374 Old 06-25-2014, 07:57 PM
Vegas oled's Avatar
Quoted: 1050 Post(s)
Liked: 749
How many hours on your panel? Why would you do this b4 running 300 hours break-in? I hope your warranty will cover you if you get true burn-in because LG will not.
Vegas oled is offline
Reply OLED Technology and Flat Panels General
Lg 55ea9800 Oled Hdtv , Lg
