Question about OLED not being industry standard - AVS Forum
post #1 of 9 Old 01-22-2014, 08:26 PM - Thread Starter
tubers's Avatar
Guys, I read something like this about a year ago from some poster on the net;
The truth about why OLED isn't usually used professionally is because it is very expensive to make and use content that takes proper and full advantage of the very wide color gamut and huge contrast of OLED.
There's is much comfort with sRGB limitation since it's cheaper.
sRGB content appears "off" because the OLED display is basically interpolating the limited data of colors and contrast
Is this correct?
tubers is offline
post #2 of 9 Old 01-22-2014, 11:09 PM
rogo's Avatar
Quoted: 35 Post(s)
Liked: 382
OLED is used professionally in many (most?) broadcast trucks and facilities at this point. Sony sells broadcast-quality monitors that replaced their old CRTs (which have become pretty obsolete in the digital era) and those are used worldwide.
So I have no idea what this means.
There is no difference in HDMI cables. If you can see the picture without visible dropouts or sparklies, the cable is working at 100%. No other cable will display a better version of that picture. You're simply wrong if you think there is a better digital cable than one that is already working.
rogo is offline
post #3 of 9 Old 01-23-2014, 07:05 AM
8mile13's Avatar
Quoted: 95 Post(s)
Liked: 190
Once professional folks replace their CRT monitors, most of them will buy a OLED monitor. SO there is at least one place were OLED stuff becomes the standard smile.gif
8mile13 is offline
post #4 of 9 Old 01-24-2014, 08:48 PM - Thread Starter
tubers's Avatar
but why is there barely any push outside sRGB/Rec 709 content (color space/gamut) w/c doesn't take advantage of the OLED's color space.
Are there any strong evidence that OLED is indeed more professionally used than Adobe RGB panels (afaik OLED is capable of more than that).
@8mile13
Oh, so CRT is still the "it" thing? Any evidence of this?
I hope someone could help me learn more.
Color Space
What is the maximum color space that BluRays are capable of using
Is bandwidth a limitation (HDMI)
true 6 bit and 8 bit.
This was kind of helpful to me:
tubers is offline
post #5 of 9 Old 01-24-2014, 10:16 PM
rogo's Avatar
Quoted: 35 Post(s)
Liked: 382
I don't understand what you're asking. Content that's broadcast is done in Rec. 709. That's the standard.
In TV production? This is just one example: http://broadcastengineering.com/remoteob/tndv-adds-sony-oled-monitors-mobile-production-trucks
But there are many places where the Sony OLEDs are deployed. They're only a couple of years old, so they aren't exactly ubiquitous, but they are getting quite popular.
rogo is offline
post #6 of 9 Old 01-25-2014, 01:00 AM
Chronoptimist's Avatar
Liked: 203
Because all the current delivery mechanisms are designed for BT.709. (Broadcast/Blu-ray/etc.)
When you are mastering content, you have to master to a standard spec.
You cannot master content to a specific display (e.g. your OLED monitor) because it will look wrong on every other display out there.
With photo/print editing, you control the entire output chain yourself.
Your output gamut is only limited by the printer that you are using - you just need an ICC profile for it, which is basically a file that tells your editing software exactly what the output limitations are. (either provided by the print shop, or measured yourself if it's a printer you own)
Displays are individually profiled, so the software (e.g. Photoshop) knows exactly what its color gamut is, and can map the image values to it accordingly.
Because the display and the printer are both profiled (and often the camera too) the editing software is able to simulate the printed output, and you can edit your image to look its best on that one specific printer and paper type.
Print used to have the same gamut limitations as displays currently do, where you had to master your content to a specific spec too. (e.g. FOGRA, SWOP etc.) Well actually it depends where you're getting your printing done - it may still apply.
Well technically there is xvYCC to expand the gamut, and it is claimed that Sony's new "mastered in 4K" series of discs are taking advantage of this, but what I have seen suggests that there is not actually any worthwhile extended gamut information on these discs.
Blu-rays are 8-bit.
I think these limitations are because support for things like xvYCC and 10-bit or greater color were optional rather than being required, so not all players would be able to handle it.
tgm1024 likes this.
Chronoptimist is offline
post #7 of 9 Old 01-25-2014, 11:39 AM
8mile13's Avatar
Quoted: 95 Post(s)
Liked: 190
I do not know that. Surely when there is not enough money available folks will stick with CRT monitors.The way i understand it CRT monitors are (were) highly regarded and (LED) LCd monitors were not considered to be good enough as replacement. OLED on the other hand is considered to be good enough/or even better than CRT. Therefor eventually OLED monitors will be the standard for professionals.
8mile13 is offline
post #8 of 9 Old 01-27-2014, 03:05 AM
Artwood's Avatar
Liked: 197
At least someone will have sense enough to not make LCD their standard.
Artwood is offline
post #9 of 9 Old 04-09-2014, 12:34 PM - Thread Starter
tubers's Avatar
Thanks for everyone's answers smile.gif Sorry for the late reply.
tubers is offline
Reply Flat Panels General and OLED Technology
User Tag List
