Looking for High Quality 32"-36" 1080p TV - AVS Forum
post #1 of 7 Old 01-25-2014, 11:34 AM - Thread Starter
sdg4vfx's Avatar
Liked: 94
Looking for a very good 32"-36" 1080p TV. (32" is preferred.) Something that can be calibrated to be color accurate for working on and QC'ing broadcast design work. For the "big" station we have a 65" VT60 and it's great but Panasonic doesn't make any small plasma TVs.
Any recommendations would be greatly appreciated. For the Calibrators out there - would be happy to pay a "consulting" fee for your input.
sdg4vfx is offline
post #2 of 7 Old 01-26-2014, 05:55 AM
irkuck's Avatar
Quoted: 21 Post(s)
Liked: 60
Please address relevant forum.
irkuck
irkuck is offline
post #3 of 7 Old 01-26-2014, 03:53 PM - Thread Starter
sdg4vfx's Avatar
Liked: 94
Sure - which forum would that be?
sdg4vfx is offline
post #4 of 7 Old 01-26-2014, 09:01 PM
"Don't PM Me Bro"
RandyWalters's Avatar
Quoted: 74 Post(s)
Liked: 464
Probably the LCD forum since that's the only type of TV available in the 32" to 40" range. It may be a bit of a challenge to find a "good" LCD in this size range, but i'd also check to see what the serious gamers are using and see if any of those TVs fill the bill.
Randy
TC-P55ST60, TC-P50GT50, TC-P46G10, TH-42PZ700U, TH-42PX50U, HP LC2600N, TiVo Series3, TWC Cisco 8742HDC DVR, Onkyo TX-SR333, URC R40 Remote.
Pic of My A/V setup - http://cdn.avsforum.com/f/f1/900x900..._Img_4867.jpeg
Gallery - http://www.avsforum.com/g/a/2082686/randywalter...
RandyWalters is offline
post #5 of 7 Old 01-26-2014, 09:38 PM - Thread Starter
sdg4vfx's Avatar
Liked: 94
Was hoping (in this forum) to get info re any OLED 32" TV's I maybe unaware of ...
A gamer/computer monitor is an RGB resolving panel, I need a standard broadcast (rec709, YUV signal processing) panel.
I've also posted in the LCD forum - will hope for responses there.
sdg4vfx is offline
post #6 of 7 Old 01-26-2014, 11:09 PM
irkuck's Avatar
Quoted: 21 Post(s)
Liked: 60
It is good to read about structure of forums and make quick look into the content before posting. Then you would learn there are no 32" OLEDs on the market and thus suitable forum for your question is LCD. However, the question "When 32" OLED panels may appear" would be a valid one here. The problem then is nobody knows the answer, not only when but if they ever appear.
irkuck
irkuck is offline
post #7 of 7 Old 01-30-2014, 07:30 AM
tgm1024's Avatar
Quoted: 233 Post(s)
Liked: 639
You've specified a monitor, but it's worth saying anyway that the general rule of thumb is that it's difficult if not impossible to find a high quality "TV" in small sizes.  So you're right in limiting your search criteria.  Every manufacturer seems to think that if you're going to spend money on something that you also somehow must require size, and that's always been a broken notion.
IF what you want is truly that level of configuration, then you'll have the most luck looking for a computer monitor I think.  You might or might not need to look for some kind of studio reference monitor.  And you might need to ask a calibrator.  There is a Display Calibration forum here, but I can't for sure if they are the folks or not....they'll tell you quickly.
Display Calibration
BTW, I think folks here (myself included) can get overly pedantic at times.  IMO, your question allowing the inclusion of OLED options is fine and this sub-forum is indeed the place to ask.  Put OLED in top-most post.
WARNING: You have now entered a no @#$%tard zone. Please gather your anti-vaccine propaganda nonsense and slowly back out the way you came in.
tgm1024 is online now
Reply Flat Panels General and OLED Technology
User Tag List
