OLED power consumption - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By vinnie97
post #1 of 5 Old 06-18-2014, 08:47 PM - Thread Starter
*UFO*'s Avatar
Quoted: 418 Post(s)
Liked: 333
Looking at the current crop of OLED tv's out, it seems their power consumption is very close to that of plasma's. Are more power efficient OLED's possible or is it just the nature of the technology? The current OLED's use roughly 300 watts of power, which is very close to the 340 watts my plasmas use. Meanwhile, a comparable sized LCD uses less than half the power, and sometimes only a fraction of that. If OLED is inherently power hungry like plasma, that leaves OELD out of the race for me .
*UFO* is offline
post #2 of 5 Old 06-18-2014, 09:37 PM
vinnie97's Avatar
Quoted: 213 Post(s)
Liked: 1012
Haven't connected my Kill-A-Watt yet but I highly doubt OLED uses anywhere near as much power as plasma. For one, they produce almost no heat in comparison. There are also the following three findings, the first from FlatPanelsHD:
Before calibration (2D), it measured 113W. After calibration (dialing down no doubt), a mere 76W.
Here's what SoundAndVision had to say:
Originally Posted by S&V
The LG OLED drew considerably less power than my reference 65-inch Panasonic does, depending on the source. With a checkerboard pattern, the Panasonic drew 3.8x the power (roughly adjusted to account for the size difference—45 W/sq.ft. for the Panasonic from 563 W total, 11.7 W/sq.ft for the OLED from 105 W total). With a 30% brightness window pattern, the difference decreased substantially, to 1.2x more for the plasma. This is a major advantage for OLED.
Finally, HDTVTest's readings:
Default [Eco] mode 103 watts Calibrated [ISF Expert1] mode 71 watts
rogo likes this.
vinnie97 is offline
post #3 of 5 Old 06-18-2014, 11:01 PM - Thread Starter
*UFO*'s Avatar
Quoted: 418 Post(s)
Liked: 333
They are not measuring a full white screen, which is what draws the most power. LG and Samsung both spec their 55" OLED panels as using around 300 watts max, which would be the case on a full white screen with brightness at max. The difference in screen sizes causes a huge jump in power draw. A 65" OLED is going to draw nearly twice as much power.
*UFO* is offline
post #4 of 5 Old 06-18-2014, 11:29 PM
vinnie97's Avatar
Quoted: 213 Post(s)
Liked: 1012
Full white field is not really a realistic measurement of actual power usage anyway, so I'm not sure what's the point? Gen 2 has reportedly improved efficiency, so perhaps we should wait before prematurely judging real-world usage.
vinnie97 is offline
post #5 of 5 Old 06-19-2014, 03:45 AM
slacker711's Avatar
Quoted: 363 Post(s)
Liked: 350
The power consumption for an OLED is usually spec'ed with 40% of the screen on. Television/movies will likely come in below this figure. OTOH, if you are thinking about using your television as a monitor, the power consumption will be higher than a LCD right now.
You can expect the numbers to improve over time as LG Display uses more efficient materials. Samsung just improved their material set in the S5 and saw a 20% improvement in power consumption.
slacker711 is offline
Reply OLED Technology and Flat Panels General
