Time For Major Upgrade... Samsung 65" 4K? Please help. - AVS Forum | Home Theater Discussions And Reviews
Old 06-29-2014, 05:18 PM - Thread Starter
R0CK632's Avatar
Quoted: 43 Post(s)
Hey Guys just looking for some suggestions on a new tv. Currently Have a 7 Year old 52" Samsung LCD 1080p and Am looking to get some new technology and better picture quality. I have currently been looking at the Samsung UN65HU8550FXZA 4k TV. I sit approximately 7-8 feet from the TV. Is it worth getting the curve? Is it worth upgrading to this tv? Is 65" Too large and maybe go with a 55"?. Do you have any other Televisions you might recommend instead? I have always had Samsungs. Thanks a lot for all your help.
Samsung UN65HU9000
Pioneer VSX -524 -K
Sony PS3
R0CK632 is offline
Old 06-29-2014, 08:28 PM
Morning5's Avatar
Quoted: 327 Post(s)
Liked: 108
Hi,
almost everyone agrees that OLED tvs have the best picture quality. Even better than the great Pioneer Elite Kuro.
Samsung made an OLED tv but its no longer in production. I would suggest waiting for the 2014 LG OLEDs that are going to be released very soon.
Morning5 is offline
Old 07-03-2014, 07:30 PM
Yamaki's Avatar
I think 65" at 7 - 8 feet may be a bit overwhelming. Here's a good article that may help you with your "size problem".
http://www.crutchfield.com/S-iWKqFvI...placement.html
The 8550 series Samsung TV's have some excellent specifications and with more and more 4K content coming through Netflix and local cable (Comcast says they will be hooking us up to 4K content this Fall) it's a good bet to future proof a bit with a 4K TV. LED LCD technology has improved considerably lately and is getting very close to plasma with respects to black levels. Adjusting them to your liking may take a while (some would suggest looking up the settings - some TV's have up to 60 variables!) but it's worth it in the end. I watched two identical size TV's, both from Samsung, side by side. One was an LED, the other was a 4K LED and with the same feed, the 4K looked much crisper with well defined images and absolutely NO motion issues. I even tweaked them to my liking and the 4K unit still looked better.
The curved units didn't impress me and that's only because for more money I saw no discernible difference in picture quality.
Good luck with your decision!
Michael
Aerial Acoustic 8s/McIntosh D100 MC252s MC501s MR85 MX119/Oppo BDP-95/Sony 4K
Yamaki is offline
Old 07-04-2014, 07:10 PM
GregLee's Avatar
Quoted: 825 Post(s)
Liked: 262
I just replaced a 6 year old Samsung 50" 720p plasma with a 50" HU8550 4K. This is a TV mostly my wife watches. This is not too much like your situation, but I did wind up with the same model. My wife and I are both happy with the picture, which has lots of punch, good color, barely acceptable black level, poor off axis viewing.
We don't use it for 4k, but only satellite 1080i/720p/480i input. For that, the resolution is quite good.
The step up HU9000 model, aside from being curved, supposedly has 2 picture enhancing features, but I haven't heard anything about whether they actually show an improvement. I didn't consider it, because my wife insisted on a 50" size.
Greg Lee
GregLee is online now
Old 07-04-2014, 07:25 PM
Stonedcl's Avatar
Quoted: 51 Post(s)
I just got a 65 inch 8550 and sit about 8-9 feet away and I think it is a little too big. I went in the store looking for a 60 inch 8000 series . I ended up seeing the picture on the 8550 and was blown away only problem is they did not have this TV in 60".. They ended up giving me a great deal on the 8550 , I seen the 60" 8000 going for right under 2k and I got the 8550 for $2500. (Well it was $2999 with a 5 year warrenty) so I had to take it. I hope I will get used to the size..
Stonedcl is offline
Old 07-04-2014, 08:48 PM
tgm1024's Avatar
Location: Sorry, chances are excellent that you're an idiot.
Quoted: 2458 Post(s)
Liked: 2231
Don't worry...You absolutely will. :-)
tgm1024 is offline
Old 07-04-2014, 09:35 PM
Adamd's Avatar
Quoted: 594 Post(s)
Liked: 375
If you have a big budget I would look at the sony x950b price is 8k but you could get it for around 6.5k for the 65.
Adamd is offline
Old 07-05-2014, 02:12 AM
irkuck's Avatar
Quoted: 255 Post(s)
Liked: 148
Your questions regarding curved&4K are answered by renowned expert:
@curved:
In my living room at home, even on a 65-inch screen, the curve didn't have any major effect on the picture aside from reducing reflections somewhat. When seen from the sweet spot in the middle, or even a couple seats to either side, the minor distortions introduced by the curve don't really register unless you're looking for them. Yes, if you move farther off-angle the screen's unusual shape becomes more apparent, as it does if you sit closer. But from my "the daddy seat" at a standard seating distance--remember, most people, including me, sit around 9 feet from their TVs at home--the curve is subtle at best.
@4K:
For comparison purposes, I arranged all four 4K sets so they were as close to the same seating distance as I could make them: between 77 and 87 inches (roughly 6.5 to 7.5 feet, which is quite close for 65-inch TVs)....
Perhaps the best test was the 4K version of "The Counselor" played on the Samsung, versus the 1080p Blu-ray of the same film played on the other sets. I stared hard and some extra detail was apparent in the 4K version...
These areas looked great on the Bu-ray, but on the 4K version they were ever-so-slightly sharper in my side-by-side, theatrically close lineup. The differences in detail were so subtle that in the vast majority of scenes I couldn't tell the Samsung playing 4K from the others. I also asked three other colleagues to weigh in and only one was able to successfully identify the 4K TV from the others. When I moved the couch back to about 8.5 feet, the differences disappeared.
The conclusion is inescapable: for your viewing distance 7-8 feets both cuved @ 4K are still total gimmicks and you can blindly forget them. Especially when you take into account that the tests above were done with the highest quality content available and reviewer was staring as hard as possible to pick up any difference.
irkuck is offline
Old 07-05-2014, 05:07 PM
GregLee's Avatar
Quoted: 825 Post(s)
Liked: 262
@4K:
... and reviewer was staring as hard as possible to pick up any difference.
But we can tell from the description that reviewer wasn't actually "staring as hard as possible to pick up any difference." Not any difference -- just differences in detail. This is a biased comparison. I'd be interested to see the results of a carefully done unbiased comparison to see whether people can distinguish a 2k from a 4k TV at reasonable viewing distances. Until then, I remain agnostic about the matter.
Greg Lee
Old 07-06-2014, 12:01 AM
ll Viper ll's Avatar
Quoted: 94 Post(s)
Liked: 82
how is it a biased comparison? the person citing the cnet review (david katzmier's) may be biased but the actual article is word for word...so I think you're the one who's coming off a little biased. I think (hope) the average AVS user can read the straight excerpt without being influenced by the loads of 'bias' you say are seemingly framing it
ll Viper ll is offline
Old 07-06-2014, 09:16 AM
GregLee's Avatar
Quoted: 825 Post(s)
Liked: 262
It's biased because the reviewer is looking only for a difference of detail. That's not just observing -- it's pursuing a theory based on what he thinks he knows about how the set is physically constructed. And the reviewer knows, as we know, that he's not going to see a difference of detail, because of the distance and the way human vision works. Why bother to even look? He's just trying to confirm his prejudices. What can it prove?
Greg Lee
