Thin Vertical Lines on Samsung UN55D7000 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 15 Old 08-12-2014, 11:09 PM - Thread Starter
Liked: 0
Unhappy Thin Vertical Lines on Samsung UN55D7000
I've had my Samsung LED TV for about 2.5 years (out of warranty). Recently out of nowhere it's started to display thin vertical lines down the screen. There are 30+ lines in the middle of the screen and a few around the left/right edges.
Depending on what color is shown the lines become more noticeable. For brighter colors - mostly green and some shades of red/blue/yellow - the area of the line becomes a dark color. Other colors - it either disappears or blends in as an off-color of whats shown.
Attached a picture and found a video of the same issue:
Seems to slowly be getting worse / more noticeable. I've been researching but cant quite seem to figure out what happened or how to fix it. Tried calling Samsung but they weren't any help since its out of warranty.
Any options or ideas on how to fix it?
Name:	2014-08-10 20.00.32.jpg
kazed is offline
post #2 of 15 Old 08-13-2014, 06:04 PM
tgm1024's Avatar
Location: Sorry, chances are excellent that you're an idiot.
Quoted: 2455 Post(s)
Liked: 2230
I saw damage once online that was caused by someone spraying the screen with water that then dripped downward to the connections & LED's that then (once current was applied) caused a reaction that corroded the contacts. I could see how this might look like what you're seeing depending upon what is corroded.
In any case, my first guess is that it's not fixable other than to replace the panel....and if the TV is more than a couple years old I would be inclined to have this be a replacement of the TV.
Thought #EAA: I wonder how many people know that no one ever says "What we've got here is a failure to communicate." in the movie "Cool Hand Luke" (1967).
tgm1024 is online now
post #3 of 15 Old 08-13-2014, 06:15 PM
danielb6752's Avatar
Quoted: 25 Post(s)
Liked: 30
https://www.youtube.com/watch?v=AzpFNRXsKjw
You could try popping the back off and seeing if any ribbon cables are loose (unplug it first!) but otherwise yes, bad panel. I had a a 55D7000 that went thru 3 panels in 18 months due to vertical lines appearing; Samsung finally swapped it out for an ES7100.
danielb6752 is offline
post #4 of 15 Old 08-13-2014, 09:35 PM - Thread Starter
Liked: 0
Ah bad news. Were you under warranty every time it was replaced?
kazed is offline
post #5 of 15 Old 08-13-2014, 09:47 PM - Thread Starter
Liked: 0
There wasn't any water damage or physical damage (that I know about at least). It has been mounted on the wall in a safe spot for some time now. It'll be my last Samsung TV thats for sure. Question for you - when I go into the tv settings and set color to 0 (which turns it to black/white display) - there are no noticeable issues. Would I still see something if it was a corroded contact issue?
kazed is offline
post #6 of 15 Old 08-13-2014, 09:49 PM
Quoted: 25 Post(s)
Liked: 30
No, technically it was out of the initial warranty + any repair warranties, but Samsung's customer service reps were able to extend the warranty and authorize the replacement... but that was just a 3 month extension, not 2-3 years.
post #7 of 15 Old 08-13-2014, 09:57 PM
krismate's Avatar
Liked: 25
Do you say this simply because you're having an issue with it? There's a chance with every single product you buy, in this day and age, for something to go wrong. If consumers blacklisted manufacturers every time they had a problem with one of their products, there would be no one left for them to buy from.
TVs (and every other big product) are more mass produced than ever. Of course, with the overall quality of components being lower, some will not last as long as others. This should be expected.
krismate is offline
post #8 of 15 Old 08-13-2014, 10:15 PM
tgm1024's Avatar
Liked: 2230
Actually this is interesting information. This might well be a motherboard issue. If your TV is using an RGB stripe subpixel layout, it will be achieving the gray levels by using all three colors. If the grays are always intact, I believe it no longer means that there are subpixel vertical lines not properly "connected". Frankly, I'm not sure what to say here. Perhaps some kind of capacitor malfunction when the RGB subs aren't all driven?
I did a google image search a few different ways for TVs with vertical lines and didn't see precisely what your issue was, but I did see (potentially) semi-similar problems. I would schedule a repair to make sure, but post in some repair forum first. Perhaps here: badcaps forum --- Troubleshooting TVs and Video Sources
post #9 of 15 Old 08-15-2014, 04:06 AM
tom669's Avatar
Quoted: 149 Post(s)
Liked: 139
This is an extremely common issue with D-series Samsung TVs. I think about half of all the faults with this TV are bad LCD panels. The other half, usually bad LED backlight... that is fixable but is very expensive and labour intensive so in most cases is not worth it.
tom669 is offline
post #10 of 15 Old 03-01-2016, 09:22 AM
Guzo's Avatar
Liked: 5
I have the same issue, but not as bad, it's on the left side.
You can especially see it in Green pure screen and everything that is a solid colour.
(see screenshot)
When I turn off all colours there are no lines whatsoever.
I did a pixel scrambler thing to remove Burn in picture just for fun and it seemed to change the lines a little (no make them disappear), but it might be only in my head.
I wonder if it's not interference from something outside of the TV, like my speakers on the side.
Guzo is offline
post #11 of 15 Old 10-01-2016, 05:56 PM
Liked: 0
Has anyone had luck fixing this issue, or does anyone know the cause of it? I have a Samsung un55d7000 that started showing vertical lines on the edges about 8 months ago and it has progressed across the screen like other pictures shown. Any help would appreciated. Thanks!
Kayla is offline
post #12 of 15 Old 10-02-2016, 02:09 AM
M_D
Liked: 0
s
I have the same issue after my son sprayed all over the LED screen and now from middle it's all wide Black lines which i don't know how to fix it. so should i have to replace the panel or cleaning those connector can work.
M_D is offline
post #13 of 15 Old 10-02-2016, 02:10 AM
M_D
Liked: 0
M_D is offline
post #14 of 15 Old 10-02-2016, 03:34 PM
tgm1024's Avatar
Liked: 2230
If it's a single-edge connected panel, like I'm lead to believe is the vast majority of them, then the contacts are extremely thin. You could theoretically do some kind of micro soldering job, but I really doubt 1. anyone could do it and 2. it'd be worth the effort in figuring out if it was the problem or not.
I'm thinking that if the TV is more than a few years old and only of medium quality, then get a new TV altogether. If you want to pay a lot, then full panel replacements can and are done, but I fail to see the point in it unless the repair cost is a fraction of what the TV is worth.
It's conceivable that it's not that however. Water can theoretically leak down to various control boards, and once that happens I imagine all hell could break loose in very unpredictable ways.
I wish I could be more help, but I'm already terribly far into guessing territory already.
post #15 of 15 Old 10-03-2016, 12:58 AM
Quoted: 51 Post(s)
vertical lines are infamous problem not only with samsung leds but with their pdps as well. mine ps51f8500 also suffered from that back in June and there are no replacement panels available anymore
vavan is offline
Reply OLED Technology and Flat Panels General
