Better to attach HDMI sources to TV or Receiver? - AVS Forum | Home Theater Discussions And Reviews
 3Likes
  • 1 Post By jb99p
  • 1 Post By Foxbat121
  • 1 Post By RandyWalters
post #1 of 7 Old 08-27-2014, 07:27 AM - Thread Starter
FragTek's Avatar
Quoted: 17 Post(s)
Question Better to attach HDMI sources to TV or Receiver?
Is one way better than the other (in terms of picture quality / input latency)? Obviously not having all of the HDMI cables coming up to the TV is a plus if you have them all plugged in to your receiver but if there is a technical reason why it's better to have them run to the TV instead, then I am ALL EARS!
I'm awaiting delivery of a 65" Samsung H8000 TV and want to make sure I absolutely maximize all potential from the TV. Does the video quality suffer at all if it's routed through a surround sound receiver (mid-grade Sony 5.2 receiver)? The one thing I am also curious about is if attaching devices through the receiver instead of TV adds any additional input latency? I like to play a few fast paced shooters on the PS4 and if going through the receiver is adding any additional latency I'd like to know so that I can hook it straight to the TV instead.
Thanks in advance for your replies. Cheers.
FragTek is offline
post #2 of 7 Old 08-27-2014, 07:34 AM
jb99p's Avatar
Liked: 4
Attaching your devices through the receiver will not degrade the picture qualityat all, the video signal is just passed through (unless your receiver is set todo upscaling or other "image enhancements"). As far as impute leg itshouldn’t add any and if it does it will not be noticeable. I run my PS3 andXbox 360 through my receiver and no issues. Beside you will get better shouldthat the cheap speakers that come with flat screens.
FragTek likes this.
jb99p is offline
post #3 of 7 Old 08-27-2014, 07:37 AM
Foxbat121's Avatar
Quoted: 698 Post(s)
Liked: 384
The biggest problem attaching HDMI sources to TV is the audio. Majority of TVs will only allow you pass 2-ch stereo PCM audio through TV's HDMI port. Some allow DD 5.1 audio. Some may even allow DTS 5.1. But none allow passing of HD audio from BD discs.
So, attaching HDMI to AVR is the only logic choice.
FragTek likes this.
Foxbat121 is online now
post #4 of 7 Old 08-27-2014, 07:38 AM - Thread Starter
FragTek's Avatar
Quoted: 17 Post(s)
Thanks for the reply JB. I wanted to put some of my questions to bed. I have ALWAYS connected my sources to a receiver and then just a single link from receiver to TV and never had a problem but I figured it was time to ask just in case.
FragTek is offline
post #5 of 7 Old 08-27-2014, 07:40 AM - Thread Starter
FragTek's Avatar
Quoted: 17 Post(s)
Ahhhh, didn't think about passing the audio back to the receiver and what limitations could be presented.
Perfect. I'll keep on keepin' on like I have since forever.
FragTek is offline
post #6 of 7 Old 08-28-2014, 09:12 AM
"Don't PM Me Bro"
RandyWalters's Avatar
Quoted: 461 Post(s)
Liked: 748
Routing all your sources through the A/V receiver is best to get the best audio signal from them all, but by sending all those sources to the TV over a single HDMI cable presents picture settings issues on your video sources since they all have to share whatever settings you have on the TVs HDMI input that you're using. For instance, my Tivo HD and TWC Cisco DVR have similar enough signals that they can share the same picture mode and settings and look equally good, but those settings don't look good at all on my Blu-Ray so for that i need to use completely different picture settings.
I recently upgraded my surround sound receiver (replaced an old Onkyo TX-SR605 w/2 HDMI inputs with a new TX-SR333 w/6 HDMI inputs). Previously i had my Tivo HD and Cable DVR connections going directly to 2 of my Panny Plasma TV's 3 HDMI inputs and sending audio from the TV's optical output to the 605 receiver, but my Blu-Ray player's HDMI was routed through the receiver to get the good audio then from the receiver to the TV's 3rd HDMI input with it's own separate picture mode and settings to suit the Blu-Ray player on that input.
But now i'm experimenting with routing all my sources through the new 333 receiver and using it as a switcher, then sending all sources to the TV with one HDMI cable and sure enough, Blu-Ray looks bad with my Tivo/DVR picture settings so i've tried two methods to get around this:
(A) Everything still routed through my receiver with one HDMI cable going to the TV, but behind the TV i tried a 1x2 HDMI Splitter, sending one lead to the TV's HDMI-2 with Tivo/DVR settings and sending the 2nd lead to HDMI-1 where i have optimal Blu-Ray settings. So when i'm watching Tivo or TWC DVR i use the TV's HDMI-2 input, but when i switch to Blu-Ray i use the TV's HDMI-1 input. This works well.
http://www.amazon.com/gp/product/B00...prd_ttl_sol_12
(B) Another thing i tried on my Blu-Ray player (which only has an HDMI output and does not have an optical output) is to connect HDMI directly to the TV's HDMI-1 input (bypassing the receiver) but using an HDMI-to-Optical extractor in-line to send digital audio to the receiver's w
http://www.amazon.com/gp/product/B00...?ie=UTF8&psc=1
Soulburner likes this.
Randy
Sony 55W800B, Panasonic TC-P55ST60, TiVo Series3 & Premiere, TWC Cisco 8742HDC DVR, Onkyo TX-SR333 AVR, URC MX-890, MX-780, R40, MX-450, MX-500 Remotes.
Pic of My A/V setup - http://cdn.avsforum.com/f/f1/900x900..._Img_4867.jpeg
Gallery - http://www.avsforum.com/g/a/2082686/randywalter...
RandyWalters is offline
post #7 of 7 Old 08-28-2014, 09:26 AM
"Don't PM Me Bro"
Quoted: 461 Post(s)
Liked: 748
Routing all your sources through the A/V receiver is best to get the best audio signal from them all, but by sending all those sources to the TV over a single HDMI cable can present picture settings issues on your video sources since they all have to share whatever settings you have on the TVs single HDMI input that you're using. For instance, my Tivo HD and TWC Cisco DVR have similar enough signals that they can share the same picture mode and settings and look equally good, but those settings don't look good at all on my Blu-Ray so for that i need to use completely different picture settings.
I recently upgraded my surround sound receiver (replaced an old Onkyo TX-SR605 w/2 HDMI inputs with a new TX-SR333 w/6 HDMI inputs). Previously i had my Tivo HD and Cable DVR connections going directly to 2 of my Panny Plasma TV's 3 HDMI inputs and sending stereo from the TV's optical output to the 605 receiver and letting the receiver decode the stereo signal, but my Blu-Ray player's HDMI was routed through the receiver to get the good surround sound audio then from the receiver to the TV's 3rd HDMI input with it's own separate picture mode and settings to suit the Blu-Ray player on that input.
But now i'm experimenting with routing all my sources through the new 333 receiver and using it as a switcher, then sending all sources to the TV with one HDMI cable and sure enough, Blu-Ray looks bad with my Tivo/DVR picture settings on that one HDMI input so i've tried three methods to get around this:
(A) Run everything through my receiver then when i switch from Tivo/TWC DVR to Blu-Ray mode i change the TV's picture mode from Custom to Cinema where i have BD-specific picture settings, but i prefer to use a Custom mode for BD and not Cinema so this didn't work out too well for me. It may work better on non-Panasonic TVs though if they have suitable picture modes for each source, especially if that TV's remote has a dedicated Picture Mode button to quickly change to a different mode (Panasonic remotes have no such button). Dunno if Samsung has such a button or not.
(B) Everything still routed through my receiver with one HDMI cable going to the TV, but behind the TV i tried a 1x2 HDMI Splitter, sending one lead to the TV's HDMI-2 with Tivo/DVR Custom mode settings and sending the 2nd lead to HDMI-1 where i have optimal (but different) Custom mode Blu-Ray settings. So when i'm watching Tivo or TWC DVR i use the TV's HDMI-2 input, but when i switch to Blu-Ray i use the TV's HDMI-1 input. This works well.
(C) Another thing i tried on my Blu-Ray player (which only has an HDMI output and does not have an optical output) is to connect HDMI directly to the TV's HDMI-1 input with BD-specific Custom mode picture settings (completely bypassing the receiver) but using an HDMI-to-Optical audio extractor in-line to send digital audio to the receiver's optical audio input. This works well also.
It was a little challenging to create the macros on my URC R40 learning remote to handle all this switching but once done it all works seemlessly. I'm still experimenting and so far methods B & C both yield excellent results.
Randy
Reply OLED Technology and Flat Panels General
