Panasonic CES Teaser - Page 4 - AVS Forum
Closed Thread
post #91 of 157 Old 01-08-2005, 03:38 PM
jcpzero's Avatar
Originally posted by Knievel
Hopefully the new consumer models will have improved memory's. I sure hope so because I am still on the fence between Panasonic and NEC.
The NEC also offers more/better stretch options. I hope this detail is also improved on the next Pannys.
JCPZero
Tips for Searching AVS:
Change showing threads from default of last 2 days to last 100 days (lower right section of page)
Use Search This Forum (Current) box (upper right section of page)
Type in model number, manufacturer name or other search term.
jcpzero is offline
post #92 of 157 Old 01-08-2005, 05:28 PM
jrock65's Avatar
Why can't you set the Vivid and Cinema settings so that it'll be "usable", even if it's different from Standard?
jrock65 is offline
post #93 of 157 Old 01-08-2005, 05:52 PM
Knievel's Avatar
For example the vivid mode is the torch mode you see in the stores. No matter how low I turned the contrast(0) and picture(3) (0-63 scale) the picture was still to bright and grainy to watch.
The Mind is not a Vessel to be filled but a Fire to be Lit.
Knievel is offline
post #94 of 157 Old 01-08-2005, 06:09 PM
rogo's Avatar
Quoted: 102 Post(s)
Liked: 472
The 50 and 500 look a bit different. The 50 is matte, the 500 a bit glossier. The 50 looks like someone dented the top edge, the 500 doesn't (IIRC). They both look better than the existing Viera with the swath of cheap, grey curve on the bottom.
There is no difference in HDMI cables. If you can see the picture without visible dropouts or sparklies, the cable is working at 100%. No other cable will display a better version of that picture. You're simply wrong if you think there is a better digital cable than one that is already working.
rogo is online now
post #95 of 157 Old 01-08-2005, 07:00 PM
wojtek's Avatar
Are the bezels black?
wojtek is offline
post #96 of 157 Old 01-08-2005, 11:37 PM
rogo's Avatar
Quoted: 102 Post(s)
Liked: 472
Generally.
rogo is online now
post #97 of 157 Old 01-09-2005, 01:32 AM
PerryU's Avatar
Rogo, did you see the 42PD50? Is it as silver-ugly in person?
Anybody have any news on the 37 ED?
"I'm more of an idea rat..."
PerryU is offline
post #98 of 157 Old 01-09-2005, 07:23 AM
amirm's Avatar
Quoted: 712 Post(s)
Liked: 408
Originally posted by nessus
I do not remember Panasonic referring to a feature like sub-pixel control before which indicates these models are indeed comprised of "8th" generation glass.
Sub-pixel control is unrelated to panel technology. The current displays already have access to individual color components. What I read here is that Panasonic scaler now uses subpixel addressing as additional measure of anti-aliasing. It is an interesting marketing technique to couch such a feature as increasing resolution. Sub-pixel filtering simply smoothes out high contrast edges. Instead of going from a white pixel to black for example, the display will now go from white, to blue, to black. Stand back far away enough and the edge would have smoother transitions. I guess since an additional sub-pixel is used here, one can say that in some situations, there is a 33% increase in effective resolution but the color pixels are obviously not the same as having additional triplets.
Microsoft clear type uses similar technology btw to get you smoother edges on fonts (a control panel setting for your desktop). But we don't say it increases resolution :).
Today is my free day to actually look around the show. I will stop by the Panasonic booth again and check out these displays and hopefully find someone knowledgable to ask questions.
Amir
Amir
Founder, Madrona Digital
"Insist on Quality Engineering"
amirm is offline
post #99 of 157 Old 01-09-2005, 07:28 AM
RichB's Avatar
Quoted: 199 Post(s)
Liked: 237
amirm,
Thanks for that information on Sun-Pixel display. I just bought a 657UY and was wondering what was going on here. Suddenly there was a genearation 8 panel. There is also no consistency on the color reproduction coming out of Panasonic: I have read 36 Million, 1 Billion, and up to 8 billion in various documents about the 65.
Looking at the panel, it appears the there is only one 65. When you get the Onyx, you get the scaler/tuner box for about 8K.
-- Rich
Oppo Beta Group
Oppo BDP-105D | Oppo HA-1 | Oppo PM-1 | Parasound A51 | Revel Salon, Voice, Studio | Velodyne HGS-15
RichB is offline
post #100 of 157 Old 01-09-2005, 08:07 AM
mangopony's Avatar
adjust the dynamic, cinema, and standard to..zero..on all settings..they are now all equal..try it..Of course, the..auto..will adjust to available light. You can now set the 3 settings (dynamic, cinema, and standard, to your preference for different source material..dvd..Directv..cable..using the auto setting if the lighting conditions are varying within the room. By the way, we get a little too excited about 36 billion colors or 1 billion or whatever. Enjoy the picture and forget the numbers. Buy the way, the settings (dynamic, cinema, and standard) are someones' idea (at Panasonic) of 3 possible options for a consumer. In other words, gives him 3 choices without getting involved in making individual changes to brightness, picture and so on. My final settings are not too many 'clicks' away from these. Of course, we all see things somewhat differently. But these factory settings are close and a good guide.
mangopony is offline
post #101 of 157 Old 01-09-2005, 08:07 AM
jrock65's Avatar
amirm,
Can you confirm that the preliminary price for the 50PX500 is $5500? Thanks.
jrock65 is offline
post #102 of 157 Old 01-09-2005, 08:24 AM
wojtek's Avatar
Amir
Amir, thanks for the excellent explanation (also thanks to another poster who drew the parallel to Cleartype). I somehow suspected that this "resolution increase" is marketing BS. One more proof that in order to learn the truth, one must come to avsforum.:)
Having said that, the overall PQ resulting from the improved sub-pixel control may be better in the new Pannys and more like the result of Fujitsu's AVM.
wojtek is offline
post #103 of 157 Old 01-09-2005, 10:51 AM
subysouth's Avatar
Any idea why the newest Panny ad info isnt restating some of the ad jargon used on the 7th gen commercial models such as "Real Black Drive System" and "MACH" glass? A lot of it might be jargon but I would be comforted to know that all these improvements(or better) in the 7th gen commercial models are carried into the "8th" gen consumer models.
ss
subysouth is offline
post #104 of 157 Old 01-09-2005, 03:17 PM
amirm's Avatar
Quoted: 712 Post(s)
Liked: 408
I went by the Panasonic booth but unfortunately, there was no one to talk to. So no more info about sub-pixel technology.
However, I did get to see the V50 and V500 side by side. Sorry to say (since it costs more and available later), the 500 is much prettier. The 50 has silver speakers below it, ala Sharp LCD. Indeed, if you like the look of the Sharp LCDs with the speakers beneath them, you will be right at home with the 50 series. The 500 on the other hand, has curved silver bezel below it that looks much prettier to my eye.
Picture quality of course, was identical on both. The material being played alternated between decent and poor. There was a ton of contouring at times with severe aliasing of diagonal lines on a gird pattern in one of the clips. I am faily confident the former was in the source (MPEG-2 quanitization artifacts) to some extent but the latter, is hard to say. Hopefully the new sub-pixel filter didn't cause the stair-stepping on those clips. On good sources, the picture was quite nice.
Amir
Amir
amirm is offline
post #105 of 157 Old 01-09-2005, 03:43 PM
rogo's Avatar
Quoted: 102 Post(s)
Liked: 472
I felt like the junk was almost surely in the source. Some of the clips ran elsewhere and appeared equivalently bad.
I tend to think the sub-pixel stuff is a lot like ClearType and similar things. I also tend to think that at normal viewing distances it's not going to matter a whole lot.
rogo is online now
post #106 of 157 Old 01-09-2005, 04:28 PM
GFish4's Avatar
I wonder what the dimensions of the TH-37PX50U series will be if the speakers are located on the bottom like the Sharp series.
GFish4 is offline
post #107 of 157 Old 01-09-2005, 05:12 PM
jrock65's Avatar
Does the PX50 have a black bezel, with silver speakers on the bottom?
Like the 32LX50?
http://www2.panasonic.com/webapp/wcs...tGroupId=30958
jrock65 is offline
post #108 of 157 Old 01-09-2005, 08:57 PM
amirm's Avatar
Quoted: 712 Post(s)
Liked: 408
Yes, it looks like the 32lx50 although the picture there is at an angle, making it look somehwat more pleasing. It is just a silver vertical bezel with holes in it for the sound to pass through.
Amir
Amir
amirm is offline
post #109 of 157 Old 01-10-2005, 05:27 PM
db_racer's Avatar
Looks like cnet.com's ces coverage verifies the new 42 hd model will not have any resolution increase and will remain standard 1024 x 768
A shame, I was hoping they would show a real 30% resolution increase as the press releases indicate. Most be sub pixel marketing hype.
db_racer is offline
post #110 of 157 Old 01-10-2005, 06:38 PM
rogo's Avatar
Quoted: 102 Post(s)
Liked: 472
"Looks like cnet.com's ces coverage verifies the new 42 hd model will not have any resolution increase and will remain standard 1024 x 768"
It's 12+ months away to 1366 x 768 or 1280 x 720 at 42 inches.
rogo is online now
post #111 of 157 Old 01-10-2005, 07:11 PM
subysouth's Avatar
It's 12+ months away to ........or 1280 x 720 at 42 inches.
Now thats something worth waiting for, any confirmation on that Mark or just rumor mill?
ss
post #112 of 157 Old 01-11-2005, 05:10 PM
BruZZi's Avatar
Originally posted by GmanAVS
BruZZi, many thanks for the clarification.
Do I understand correctly, if using the "glass" as the yardstick for panny sets, then the "new" 8th gen consumer models in fact will use the current 7th gen commercial glass... and that calling the "new" consumer models "8th" gen is just a marketing ploy?
Gianmarco
I don't think those Models announced are 8th Generation Panels .
Panasonic introduces new Generation Displays first in Japan (obviously :D) then USA and other Markets.
I don't see any info on their Japanese site about new Displays.
Sub-Pixel Control is also available on the Onyx Series. (I almost sure I saw somewhere mentioning the 7g Commercial Series having the same feature - Can't find the link :( ) .
And both Onyx and "7UY" Models are capable of displaying up to 8.6 billion colors.
BruZZi is offline
post #113 of 157 Old 01-12-2005, 12:08 AM
rogo's Avatar
Quoted: 102 Post(s)
Liked: 472
Suby -- Major mfrs. are getting prepared to move higher resolution plasmas down to lower sizes. Beyond that, it's hard to say more right now because of the sheer number of variables.
rogo is online now
post #114 of 157 Old 01-12-2005, 06:07 AM
nessus's Avatar
OK. Not to try and pin you down regarding these variables but can you provide any speculation about what the higher resolutions might be for panels in the 50" - 65" range, a time frame for their introduction and the initial pricing?
nessus is offline
post #115 of 157 Old 01-12-2005, 07:10 AM
thebishman's Avatar
Mark,
I also would very much like to 'hear' what you may know re: 1080P plasmas in the 60-65" size range. Time frame in particular.
Bish
thebishman is offline
post #116 of 157 Old 01-12-2005, 07:41 AM
hoodlum's Avatar
I would be very suprised to see 1080p in the 50" size, at least not in the near term. I see them starting at 60" and above and then gradually working down in size.
At 10'+ viewing distances from a 50" plasma you will be hard pressed to appreciate the additional pixels in 1080p vs a 720p plasma.
hoodlum is offline
post #117 of 157 Old 01-12-2005, 02:54 PM
jrock65's Avatar
However, the Panasonic website says that it is the "8th Generation Panel".
http://www.panasonic.com/consumer_el...05/product.asp
Maybe it's just some marketing thing.
jrock65 is offline
post #118 of 157 Old 01-12-2005, 03:32 PM
rogo's Avatar
Quoted: 102 Post(s)
Liked: 472
hoodlum, the reason the 65-inch plasma from Panasonic is 1366 x 768 is because the 50-inch plasmas is 1366 x 768. Once one domino fallls, the other one will fall too. Maybe not instantly, but in the near term....
nessus, the pixel count will be 1920 x 1080. It's likely those models will push the lower resolution ones aside after not too much time.... They will probably co-exist for a sub as Samsung will do with its DLP units -- some 720p, some 1080p at the same screen sizes.
rogo is online now
post #119 of 157 Old 01-12-2005, 06:49 PM
hoodlum's Avatar
If they are able to do 1080p at 50" then true 720p at 42" should be a lot easier. Could there be a true 720p 42" coming in the near future?
hoodlum is offline
post #120 of 157 Old 01-12-2005, 07:34 PM
subysouth's Avatar
Agreed and good question.
ss
Closed Thread Flat Panels General and OLED Technology
User Tag List
