Panasonic 8th generation PWD commercial displays now available:) - Page 7 - AVS Forum
post #181 of 630 Old 06-24-2005, 01:16 PM
housecor's Avatar
The big question: What about subpixel control? The new 8th gen consumers have it but I've yet to see any confirmation on the 8UK's...
Cory
housecor is offline
post #182 of 630 Old 06-24-2005, 01:23 PM
valkyrie's Avatar
Agreed, this is an important question, though not a deal-breaker for me. The increase in brightness, the 8th-gen glass, and the darker bezel make it worth the $100 or so I expect it to be over the 7UY. Now, if the price difference is $500, I'm going with the 7-series.
valkyrie is offline
post #183 of 630 Old 06-24-2005, 01:36 PM
yobob's Avatar
Originally Posted by PerryU
Oh, and looks like they're going to the black, round stand instead of the duck feet! That's an improvement, imo.
Hmmmm, I wonder. I compared the two op manuals.
7UY pedestal stand part numbers: TY-ST05-K, TY-ST07-K
8UK pedestal stand part numbers: TY-ST07-K, TY-ST08-K
I don't know what this means, if anything. :confused:
yobob is offline
post #184 of 630 Old 06-24-2005, 01:41 PM
yobob's Avatar
I did a search for this in the op manual, and came up with a zero.
But then again, I did the same for the PX500 and also came up with a zero.
Maybe the 8UK brochure will tell. Or maybe the website.
FWIW, the 8UK op manual does mention 3:2 pulldown, and how to turn it on/off. Again, zero for the PX500.
yobob is offline
post #185 of 630 Old 06-24-2005, 03:22 PM
Brucer's Avatar
Originally Posted by subysouth
Thats definitely not an 1/8" bezel. It looks much more like the 7UY than different IMO.
ss
Sure it is. Look closer at the picture. 1/8†frame wrapped around the glass. Just as the enhanced manual cover pic showed, that I attached earlier..
Brucer is offline
post #186 of 630 Old 06-24-2005, 03:47 PM
BruZZi's Avatar
The TY-ST05K is identical to the TY-ST07K.
I'm still looking for info/pic of ther TY-ST08K.
BruZZi is offline
post #187 of 630 Old 06-24-2005, 03:50 PM
yobob's Avatar
So. . . . maybe it's duck feet after all? Or maybe a choice????
yobob is offline
post #188 of 630 Old 06-24-2005, 04:43 PM
jcpzero's Avatar
Check the pic on the front of the operators manual. The (only) 1/8th inch bezel was smoke and mirrors.
I guess the bezel is technically 1/8", but in reality the picture does not extend all the way bezel. So there is an 1/8" outer bezel, then an inner bezel, then black glass, then the picture itself.
Any comments from present 7uy - how reflective is the most interior "black" section of glass? The amount of black glass on the 8uk appears to be about double the width of the 7uy model.
JCPZero
Tips for Searching AVS:
Change showing threads from default of last 2 days to last 100 days (lower right section of page)
Use Search This Forum (Current) box (upper right section of page)
Type in model number, manufacturer name or other search term.
jcpzero is offline
post #189 of 630 Old 06-24-2005, 05:55 PM
PerryU's Avatar
Sorry, but if that's 1/8", then the panel's only about 10" across. Looks more like 3/4" minimum to me, plus the inch or so of black glass.
edit: Brucer, if you lighten up that picture you posted, you'll see quite clearly that there's a dark grey bezel just like on the 7UY, though a little thinner and possibly darker. That's what the "Panasonic" is written on.
"I'm more of an idea rat..."
PerryU is offline
post #190 of 630 Old 06-24-2005, 06:24 PM
Brucer's Avatar
Previous generations the front housing was called the escutcheon. [1st pic]
Here's the G8 in silver [not bad looking, if they offer that]. [2nd pic]
Brucer is offline
post #191 of 630 Old 06-24-2005, 07:54 PM
subysouth's Avatar
see
Thats the way it looks to me too. Its a bait and switch :p .
ss
subysouth is offline
post #192 of 630 Old 06-24-2005, 08:30 PM
jcpzero's Avatar
Previous generations the front ‘housing’ was called the ‘escutcheon’. [1st pic]
Brucer: Where are you guys finding the 8uk photos? One seemed to have a dark grey / black housing and your picture shows silver (unless the silver is a photoshop edit to highlight the 'escutcheon')
JCPZero
jcpzero is offline
post #193 of 630 Old 06-24-2005, 08:52 PM
Brucer's Avatar
Exactly, I 'chopped' it to highlight....and since there is two model numbers ending...UKJ and ....USJ [blacK & Silver]
Brucer is offline
post #194 of 630 Old 06-24-2005, 09:48 PM
PerryU's Avatar
Okay folks. Here's the pic posted by Panasonic Plasma, allegedly of the PWD8UK, lightened up a little bit. Seems to me this clearly shows:
- Glass with image area surrounded by a black area
- Escutcheon slightly smaller than the 7UY
- Bezel, as in a 45% angle, around the edge of the Escutcheon. $$ to doughnuts that bezel measures 1/8".
Actually looks pretty cool... though still not a major departure from the 7UY.
PerryU is offline
post #195 of 630 Old 06-24-2005, 10:04 PM
Brucer's Avatar
No, There is no 45 degree bevel, just bad lighting in the photo.
This image is clearly defined in both my attachments as well as the owners manual
http://service.us.panasonic.com/OPER...H37PWD8UKJ.PDF
In Adobe, place your magnifier on the image in the Upper Left Corner and blow it up full size, it is an accurate and clear representation of the Photo provided by user Panasonic Plasma
Brucer is offline
post #196 of 630 Old 06-24-2005, 10:26 PM
PerryU's Avatar
Brucer, have you seen it in person? Because none of these images are "clearly defined" enough to be unambiguous, imo. I think I see a bevelled edge, no matter how much I blow it up, but it could be a lighter trim, or a trick of the lighting. Guess we'll have to wait for better pics, or a live viewing. Not that I'll lose any sleep over it.
G'night.
PerryU is offline
post #197 of 630 Old 06-24-2005, 10:48 PM
BruZZi's Avatar
BruZZi is offline
post #198 of 630 Old 06-24-2005, 10:56 PM
jcpzero's Avatar
- Bezel, as in a 45% angle, around the edge of the Escutcheon. $$ to doughnuts that bezel measures 1/8". ;)
If you zoom in using adobe acrobat on the manual, you can see the structure better than the picture. You can also compare to the 7uy (like bruzzi's images are from the manuals, you can zoom in on the manuals themselves).
Probably need to wait until someone sees in person - but I am curious if the larger area immediately surrounding the glass picture is also "glass" and therefore has the same reflective properties as the image portion of the tv - or if it actually something covering the glass and therefore more of a matte finish.
JCPZero
jcpzero is offline
post #199 of 630 Old 06-25-2005, 02:15 AM
Sgt_Strider's Avatar
What's the resolution for the 8 series?
Sgt_Strider is offline
post #200 of 630 Old 06-25-2005, 04:58 AM
optivity's Avatar
Originally Posted by chill903
optivity:
I haven't been following your consumer Panny thread(s) closely, but why is the industrial's lack of a cable card a "deal breaker" for you? Are you trying to move away from having any other components in your system except your DVD player/HTPC/etc.?
Exactly. If you’re married to a CATV provider…, which I am at least for the short-term, you will discover that there is a noticeable improvement in picture quality when removing an external STB from your home-theater mix. I’ve used a number of different SA STBs for the past four years but nothing (e.g. STB --> component or HDMI) compares to the picture my PDP renders once I had a CableCARD installed.
We all have deal breakers based on our individual needs (add in WAF and life is really difficult). I personally can't get over the Panny consumer lack of per input memory settings and no 3:2 pulldown.
JCPZero
I hear you there… (especially with the WAF ;) ) We all have our priorities and unfortunately with HIGH technology there are always trade-offs to be considered. When I first became serious about buying a PDP last fall, I discovered this Forum. Initially, I was going to purchase a 50†7UY but eventually determined a consumer TV was a better fit for me. I’m concerned about what I’m going to do with a 50†panel (5) years down the road after I buy my 65†SED TV. :D A consumer TV with speakers, tuners and CableCARD makes it a lot easier to move the panel to the MBR and the 36†HD-ready CRT-TV to bedroom #2.
optivity is offline
post #201 of 630 Old 06-25-2005, 05:14 AM
JWhip's Avatar
Quoted: 57 Post(s)
Liked: 138
I'll keep the commercial display as I prefer the DVR. The cable card is of no use to me without recording capablity. HD looks great through the 6412 I have and identical to OTA. I really do not care about how SD looks. I have a 50 &Uy and pout my 42" PWD4UY in the bedroom. I have small Boston Acoutics on a shelf under the plasma. They work great and you don't even see that they are there.
JWhip is online now
post #202 of 630 Old 06-25-2005, 04:09 PM
Joe Murphy Jr's Avatar
"I’m concerned about what I’m going to do with a 50†panel (5) years down the road after I buy my 65†SED TV."
Let's hope that 7x" SEDs are available long before you can afford one (like, say... 2007, when I want to get one :) ).
The most efficient path is seldom a straight line.
Joe Murphy Jr is offline
post #203 of 630 Old 06-25-2005, 06:20 PM
PerryU's Avatar
The two announced so far (TH37PWD8UK and TH42PWD8UK) are ED, 852x480.
Which you would know if you'd done even a tiny bit of research, like reading the press release linked in the first post of this thread.
PerryU is offline
post #204 of 630 Old 06-25-2005, 06:24 PM
BruZZi's Avatar
FINALLY...
The operating Manuals now include a description of the Hidden Menu and how to access it. ;)
Check Out the all-new BruZZi's Panasonic Plasma FAQ
Links to Plasma Stands, Wallmounts, Murals, Lifts, Speakers, Frames, Bezels & Motorized Artwork.
Also links to Audio/Video/Computer Faqs, Comparisons, Info, News, Reviews, Shootouts, Tutorials, Tweaks and Many More.
BruZZi is offline
post #205 of 630 Old 06-25-2005, 08:35 PM
mrscintilla's Avatar
The two announced so far (TH37PWD8UK and TH42PWD8UK) are SD, 852x480.
Didn't you mean ED? SD means standard definition.
mrscintilla is offline
post #206 of 630 Old 06-26-2005, 12:32 AM
It amazes me that there are pricks like you that even attempt to respond to my post.
The first post of this thread doesn't list the resolutions for the models. The link in the first post was not a direct link to the press release that mentions the resolution of the first two models shown. Before you attempt to act like a smart ass, make sure you get things straight before you make some BS about the first post having all the information I need :rolleyes:.
post #207 of 630 Old 06-26-2005, 04:59 AM
JWhip's Avatar
Quoted: 57 Post(s)
Liked: 138
ALL Panny commercial plasmas that are designated PWD are ED panels. The HD panels carry the designation PHD.
JWhip is online now
post #208 of 630 Old 06-26-2005, 08:12 AM
PerryU's Avatar
Yup; fixed now. Sorry about that.
PerryU is offline
post #209 of 630 Old 06-27-2005, 11:48 AM
yobob's Avatar
After all the semi-positive stuff I've read so far, I went back and re-read the "black-strobing" thread here, and wonder if Panasonic has fixed it with the 8UK. Hope so.
But then, there's always some new bug that creeps in to a new model run, seems like. Guess I'm feeling sorta pessimistic this morning.
yobob is offline
post #210 of 630 Old 06-27-2005, 12:20 PM - Thread Starter
jrock65's Avatar
I kind of feel like plasma evolution (at least with Panasonic) is really slowing. There's practically no difference between the 7UY and the 8UK.
Going from 5UY to 6UY you got more colors, greysteps, and brightness. More colors and greysteps going from 6UY to 7UY as well.
But 7UY to 8UK seems like pretty much the same panel.
Honestly though, these plasmas are good enough already. The main "next" thing will probably be 1920x1080 resolution.
jrock65 is offline
Closed Thread Flat Panels General and OLED Technology
User Tag List
