Green line on my Philips Plasma??? - AVS Forum
post #1 of 3 Old 01-07-2006, 03:15 PM - Thread Starter
ThunderStick's Avatar
Just bought a 42" Philips plasma HD. I have Comcast cable and Im watching ESPNHD Tampa Bay vs Redskins. On the right edge of the screen there is a vertical green line during the game. It goes away during commercials when it shrinks down from widescreen. I noticed it during the NCAA basketball game earlier too.
I looked through the settings and cant find a remedy. My computer monitor has the option to "center" your screen so the edge borders are even but my tv doesnt have that.
Can anyone shed some light on my problem??
ThunderStick is offline
post #2 of 3 Old 01-07-2006, 04:04 PM
mlandau's Avatar
shift your picture by using the arrow buttons on the remote. Your picture is off center. There is mention of it in the owner's manual.
mlandau is offline
post #3 of 3 Old 01-07-2006, 04:35 PM - Thread Starter
i feel like an idiot, it was so simple. i just used the right arrow button and it shifted over. I even shifted it up a bunch because i noticed the ticker that runs across the bottom was a little cut off.
Thank you mlandau, you totally rock!
GOOOO SEAHAWKS!!!!!
Closed Thread Flat Panels General and OLED Technology
User Tag List
