Best Buy, $800 LCD/Plasma suggestions - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 09-07-2008, 03:16 PM - Thread Starter
Kuroi Kaze's Avatar
Need a good HDTV somewhere between 42 and 37 for the bedroom.
This TV will be hooked up as a computer monitor so 1300 or better resolution will probably be necessary.
The TV needs to be sold at best buy and priced somewhere in the $800'ish range if possible.
TV will likely see use for gaming and movies as well, but not heavily. Mostly television usage.
View distance is only 10-15 feet.
Subtitles are likely be to used on this TV often.
I appreciate any and suggestions.
Thank you for your time.
Kuroi Kaze is offline
post #2 of 5 Old 09-07-2008, 04:15 PM - Thread Starter
Kuroi Kaze's Avatar
actually the 42LG30 for $800.
any thoughts?
post #3 of 5 Old 09-08-2008, 05:15 AM
SVTruong's Avatar
panasonic 80u or the samsung 450
SVTruong is offline
post #4 of 5 Old 09-08-2008, 05:29 AM - Thread Starter
Kuroi Kaze's Avatar
both of those are low-res at this price point.
1300 or better, please unless you think 1024 is suitable for using as a computer monitor. i imagine even 1300 will be strained vs. 1900.
post #5 of 5 Old 09-12-2008, 12:23 AM
skeelo58's Avatar
I'm not sure you understand resolution....
The 1st number is not the important number in the equation. The 2nd number is what you should be looking for. 1024x768, 1366x768, 1920x1080 are pretty much the only resolutions you are going to see on TV's. And if you are looking for a TV for 800, that is 1080p, then I will tell you that you are not going to find a quality TV. You will more than likely have to settle for some Dynex POS or something like that.
720p, 1080i, 1080p. Those are your resolutions. Not 1300, 1024, or 1900
skeelo58 is offline
Reply OLED Technology and Flat Panels General
