Vertical TV installation - how to change image to vertical display? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 06-28-2009, 10:06 AM - Thread Starter
wsanchez's Avatar
Hi,
I'd like to install a LCD vertically instead of horizontally. I've search through the forums and have found no mention of the converter box that I'd need to accomplish this. I apologize for the newbie question, but what device do I need to accomplish the rotation of the image from horizontal to vertical? I imagine that it'd have to be a scaler of some sort.
TIA,
William
wsanchez is offline
post #2 of 8 Old 06-28-2009, 12:42 PM
chadmak09's Avatar
Originally Posted by wsanchez View Post
Hi,
TIA,
William
are you gonna use this for a computer monitor or TV watching?
If you are going to use it as a computer and are using windows,
go to display settings,
then click "advanced settings"
then click your video card properties (GEForce6150SE in my case)
then click start NVIDIA control panel (in my case)
then click Display
then you should see a rotate display option.
but this only if you are using it with a computer with windows and the same video card as I..
there may be an option in the television properties.
chadmak09 is offline
post #3 of 8 Old 06-28-2009, 03:45 PM
"Don't PM Me Bro"
RandyWalters's Avatar
Quoted: 498 Post(s)
Liked: 766
Hi,
And no mention of what kind of source or computer you'll be using, nor any details of the reason that requires vertical mounting?
Randy
Sony 55W800B, Panasonic TC-P55ST60, TiVo 2-Tuner Premiere, TWC Arris DCX3600-M 6-Tuner DVR, Onkyo TX-SR333 AVR, URC MX-890, MX-780, MX-450, MX-500 Remotes.
Pic of My A/V setup - http://cdn.avsforum.com/f/f1/900x900..._Img_4867.jpeg
Gallery - http://www.avsforum.com/g/a/2082686/randywalter...
RandyWalters is offline
post #4 of 8 Old 06-30-2009, 10:23 AM
allisgreen's Avatar
I have always wanted to flip my 52 lcd to portrait orientation and play a pinball game on it.
allisgreen is offline
post #5 of 8 Old 07-07-2009, 12:26 AM
Norde's Avatar
Do you want to convert an existing monitor or buy a new one?
If it's a new one, several manufacturers make a commercial display that shows portrait or landscape.
For example:
"For a variety of environments, LG's sleek 720p 42-inch class and Full HD 1080p 47-inch class LCD monitors (models M4212C* and M4714C*) offer widescreen HD capable monitors for use in almost any environment from corporate reception areas to education settings. With display options in portrait and landscape mode, and Split Zoom capabilities for video wall applications (5 x 5 max), these models provide a versatile alternative to projectors and standard CRTs that both students and executives can enjoy."
Norde is offline
post #6 of 8 Old 06-20-2012, 02:14 AM
vian80's Avatar
Hi.. Any recommended software that able to help me by using 1 computer to display 2 -3 vedio files at the same time on Veritcal TV ?
vian80 is offline
post #7 of 8 Old 06-20-2012, 07:12 AM
coolscan's Avatar
Quoted: 18 Post(s)
Liked: 88
Check out this software and see if you can make it do what you want. Never tried it myself. Please report back if you try it. http://discoverybiz.net/enu0/dbzn/index.html
coolscan is offline
post #8 of 8 Old 06-20-2012, 08:22 AM
olyteddy's Avatar
Quoted: 523 Post(s)
Liked: 911
Just use 3 instances of your favorite video player like VLC or MPC-HC.
🔥🔥🔥 Sent from my Samsung Note 7 Using Ove Glove™ 🔥🔥🔥
olyteddy is offline
Reply OLED Technology and Flat Panels General
